A Poor Student Needs Help - NEC L70S No Backlight
    This LCD monitor was given to me by my instructor coz' it's lying around in in their attic and was an old model. Since I have no monitor (CMV CT-934D defective main supply regulator) I was very happy to have it but the only problem was when I turned on the power the backlight flash momentarily then black out but the power LED stayed on(green). When I shone flashlight in the screen I could see the icons which means the display is fine and the backlight is defective. Anyone could help me please.
    Re: A Poor Student Needs Help - NEC L70S No Backlight
    Sounds like 2 second to black. See posts #19 and 20 at
    https://www.badcaps.net/forum/showthread.php?t=10419
    2 seconds to black can be (in no particular order)
    a) bad caps
    b) bad inverter transformer
    c) bad ccfls
    d) bad ccfl wiring (especially the return wire)
    --- begin sig file ---
    --- end sig file ---
      Thanks a lot. I will read and follow the instruction in troubleshooting this monitor. Do you have any schematic diagram on CMV CT-934D monitor coz' the PSU components were burned...Here's the attachments...I got the pictures here in this site since it's very similar to the PSU board. And since I have no hd camera to take the pictures.
        Pictures of a similar supply really do not help. Would you turn in a paper written by one of your classmates because 'it was similar to one you would have written'? Even an identical power supply would not have the problem that yours has.
        PlainBill
          It is especially bad if the teacher catches you using HIS photos.
          You don't need a HD camera. I shot those photos of MY board using a Canon A80 (8 year old camera).
            My current camera is a 4 Megapixel Olympus D-580. And that is more camera than is necessary - I have to reduce the pictures before uploading. They are now available (used) on eBay for as little as $19 with free shipping.
            PlainBill
