Help with Compaq P1220/Mitsubishi 2060u
  • Gooberslot
    • Nov 2011
    I don't know if anyone here knows anything about old CRTs but I thought it wouldn't hurt to ask. My Compaq P1220 blew its HOT which I replaced along with a few other parts that I thought might be bad (all horizontal related). Now the monitor works but the vertical linearity and balance are really messed up. The OSD can correct for most of the problem but there's still a droop or slant towards the right side of the screen. Screen rotation controls don't seem to help much. Any ideas what could be causing this?
    Edit: I don't know if this is related or not but the convergence in the bottom middle of the screen is pretty bad. I'm not sure if it was always this way or not though. It's been a while since I used this monitor.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Help with Compaq P1220/Mitsubishi 2060u
    Physical defect in the deflection coil. Unfixable. The linearity on the other hand could have something to do with the other parts you replaced. Are you sure they were the right ones?
    On the deflection assembly there are some convergence controls. Fire up Nokia Monitor Test, use the magenta crosshatch pattern and have fun.
    A working TV? How boring!
    • Gooberslot
      • Nov 2011
      But it didn't use to be this way. Could the coil have been damaged when the monitor blew out? As for the other parts I replaced, a lot of the info I came across was on russian sites translated with google so who knows. I have the service manual but most of it is way over my head. I mainly used it as a parts list to make sure I was getting the right parts.
      I didn't want to start messing with the physical controls so I used the service menu to make some adjustments. It didn't make much difference, at least at the bottom. I was able to clean up the sides a bit though.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Usually not... but it could have been accidentally knocked when you were replacing parts and might have moved a little from its optimal position, throwing the whole picture off. Actually that would explain the convergence issues too, but it's up to you if you want to attempt moving it or not.
        The physical controls do a better job. Try them.
        • Gooberslot
          • Nov 2011
          Well, I dug my other one out of the garage and did some unnecessary part swapping (turns out that ones problem was a bad power supply but I didn't think to look for that) and it has exactly the same problem. Now I think my cheapo soldering iron may have damaged something. I measured the tip and there was ac voltage present, somewhere between 20-40v. At least that's according to my 2 DMMs, my analog meter shows at most 1v.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            The AC voltage present at the tip is normal for an ungrounded iron. It is high impedance and reduces to next to nothing when the tip is actually touching something... It may cause problems on sensitive logic circuitry like on motherboards, but i don't think it's responsible for the issues you have with your monitor. The irons i've been using so far are ungrounded too.
            • Gooberslot
              • Nov 2011
              Ok, that's a relief although I'm still going to look for a better quality iron. I know most of the parts in that monitor are rated at 200+ V so I figured most things would be safe but I read electrolytic caps are polarized and don't like voltage coming from the wrong side so I thought some of them might have been damaged.
              Also, I should clarify that the second monitor still had the same geometry problems as the first except for the vertical linearity which wasn't that bad on the second. I was also much more careful disassembling the second one to make sure I didn't knock loose anything on the tube.
                HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-12-2024, 03:44 PM
                HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                09-12-2024, 03:36 PM
                HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                09-12-2024, 03:30 PM
                HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
