samsung syncmaster 244T problem
  • jmann
    • Nov 2011
    samsung syncmaster 244T 24" LCD Monitor
    it would not power on at all no lights completely dead
    i replaced all the caps in the power supply board & get a flashing green light where the power button is.
    if i leave it on for about 20 to 30 mins it will work fine has a great picture
    so now i dont know what to do please help thanks
  • retiredcaps
    • Apr 2010
    • 9271
    Re: samsung syncmaster 244T problem
    1) What brand and series of caps did you use for replacements?
    2) When some people mean "all", they mean only the bloated ones. Did you change them all including the smallest caps and biggest one?
    3) This thread is better suited in the "Troubleshooting Computer Displays" forum.
    --- begin sig file ---
    --- end sig file ---
    • jmann
      • Nov 2011
      i replaced every cap on the board even the big one
      i got the caps from jameco
      the 1000uf 35v ones were bad on the board so i replaced them first
      the new ones are made by jackcon
      1000uf 35v
      • s12original
        • Dec 2011
        • 3
        1000uf 35v
        also i would check all diodes
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          1000uf 35v
          The Jackon caps you got are likely not low ESR - that explains why the monitor works when it warms up. When a capacitor is heated, its ESR becomes lower. If the caps are marginal, their ESR may drop just enough for the PSU to start working.
          You need to replace those Jackon caps with proper low ESR ones.
          To do that, you need to do is check the brand and series (series is usually 2 or 3 letter code) of the original caps, find a data sheet for them (or ask here) and then pick a replacement based on that. More specifically, you need to check the ESR/impedance and ripple current rating in the data sheet of the original caps and then pick your replacements so that they have either the same or lower ESR and the same or higher ripple current.
          If you have trouble doing this, just post what brand and series the original caps were and we can suggest a replacement based on that.
          Generally any of these caps will likely work fine (brand and series listed respectively):
          Nichicon PW and HE, Chemicon KY and KZE, Panasonic FR and FM, or Rubycon YXG and ZL.
          • retiredcaps
            • Apr 2010
            • 9271
            That also might explain the flashing green power LED. If the caps aren't working properly, you might get fluctuating voltage to the logic board.
            A multimeter measuring the voltage on the connector between the power and logic board would confirm this theory.
            • lovecd
              • Jun 2013
              • 31
              My 244T won't turn on at all. The main switch at the back is on, however, when try to turn on the power at the front, no light at all. I opened the case and found those 3 capacitors with 1000uf 35v are rounded, so I changed all of them, but has no luck. Still the same sympton, no light at all. Can some one give some advise what else could be?
              Thanks!
                09-07-2024, 05:50 AM
              • howardc64
                Samsung UN55JU650DF network/streaming problem
                by howardc64
                Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                07-09-2025, 12:44 PM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
