Sony SDM-HS73 dead
  • stevo1210
    • Oct 2006
    • 4156
    Sony SDM-HS73 dead
    I bought this Sony monitor brand new about 7 years ago, I'd have to say it's the best monitor I've ever used!
    Then today it just wouldn't power on... it's as dead as cactus. I haven't done anything to it either. I just moved it from one side of the desk to the other (cables disconnected of course) and now when I plug it in, it won't power on AT ALL.
    No power, no light... just dead.
    Where should I start looking here?
    Thanks.
  • stevo1210
    • Oct 2006
    • 4156
    Re: Sony SDM-HS73 dead
    okay, just cracked the thing open and took a look. I took the secondary side cable off the power board and measured all the voltages... it was getting all 12V and 5V power... no problems there... then I disconnected the AC power cable and plugged the 12V and 5V lines back in and for a split second it came on!
    Then I plugged the 240V AC cable back into the wall and it came to life again! Looks like oxidation or the like on the 12V and 5V cables. So it's fixed again
    Minus two broken mini plastic clips on the way out
    • FIXITNOW
      • Jun 2008
      • 128
      if it starts playing up again replace Cap C207
      use a good low esr version
      • tiritrobo
        • Oct 2011
        I have a similar problem. Mine has all the badcaps replaced but still no image. Just at the first start, without PC connected, i have the litle image with message: PC CABLE NOT CONNECTED. If i plug VGA cable into the monitor with PC on, led start to blink in green continously. The main buttons does.nt work but only the power (led button).
        Any other hints?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4476
          • Italy - Milan
          "Mine has all the badcaps replaced"
          How do you found that those are bad?
          • tiritrobo
            • Oct 2011
            With ESR, of course.
            • tiritrobo
              • Oct 2011
              So, no more lyrics?
                It sounds like it is not detecting the VGA signal so you probably having problem on the logic/scaler board. Not detecting signal can be due shorted protection diodes on the VGA signal line. Get the pin out of the VGA signal pins, then check tose pin against ground to see if the signals has shorted out. Also need to check voltages on the logic board at the regulator IC, etc.
                Service manual, not sure how complete it is.
                Is this the same chassis as yours?
                http://s807.photobucket.com/user/bud...?sort=3&page=1
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4476
                  • Italy - Milan
                  If the mon. wasn't detecting vga signal it showed "no signal".. or at least do not switch off with a blinking led.. or you not explained well, what does if you switch on with the pc connected?
                  • tiritrobo
                    • Oct 2011
                    Like i said before, only when i connect the VGA cable to the computer i have blinking led. In rest, without connection on the VGA port i have (like i said) PC CABLE NOT CONNECTED.
                    • viziks
                      • Mar 2012
                      • 33
                      • India
                      Have you tried changing the PC resolution to a lower one 1024 >< 768? But without another working monitor it may be difficult. You can also try booting the PC into safe mode. Best way to conclusively test is connect monitor to another known working CPU or VGA port of laptop or TV tuner etc.
                      Samir
                        by momaka
                        03-15-2023, 10:17 PM
                      • thstuff
                        Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                        by thstuff
                        A) TV initially dead
                        B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                        C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                        D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                        E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                        12-26-2024, 09:10 PM
                      • FZG
                        Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
                        by FZG
                        Hello there, helpful forum people!
                        I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
                        On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
                        The original part...
                        05-10-2023, 11:54 AM
                      • wattage
                        by wattage
                        Hello Badcaps Community,
                        07-13-2025, 04:41 PM
                      • bohaboha
                        SONY KDL-46R473A ALMOST DEAD NO STB
                        by bohaboha
                        Hello to everyone in this wonderful forum.
                        I have this SONY LCD TV KDL_46R473a
                        PSU GL5 APS350 :1-888-122- 12
                        MAINBOARD FY13_EU IP-012C101-4010
                        black screen ,no STB no life almost death.
                        on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                        Also 3,5,and 12v are on.
                        nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                        don't know what to do next all suggestions and advice are very welcome​...
                        04-24-2025, 04:40 PM
