Samsung SyncMaster T240 2-second backlight problem
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Samsung SyncMaster T240 2-second backlight problem
    No - I am pretty sure its bad. -Its a well recorded fact that the transformers
    give up. - Very thin wire perhaps wound too tight and the do run hot.
    Best get one on order.
    The fact that they are available on ebay is almost enough to suggest this one breaks down often
    otherwise no-one would bother listing them.
    • Corinth
      • Jun 2012
      • 5
      Thanks, for all your help. Having a sniff, it smells like it's been running hot.
        09-07-2024, 05:50 AM
      • soopacrucial
        Samsung Syncmaster 740BF repair
        by soopacrucial
        Hi folks,
        I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
        Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
        10-29-2024, 02:40 PM
      • unimatrix93
        Replacement transformer for Samsung fridge
        by unimatrix93
        Dear forum
        My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
        No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
        The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
        My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
        07-14-2025, 02:16 AM
        09-06-2024, 11:40 PM
