HP-W2338h ccfl question
  • mu2
    • Oct 2009
    • 217
    I'm trying to bring an HP-2338h widescreen monitor back to life. It had the two seconds to black problem. All power supply caps check good for ESR and value.
    It looks like there is some kind of substance around the lower set of ccfl lamps, maybe phosphor powder? The monitor has two lamps on the top edge and two on the bottom. I can plug two test ccfl bulbs (from a computer light kit) into the lower set of sockets and all bulbs light. The test bulbs are about 300 mm long while the original bulbs are 2.4 mm diameter and 525 mm long. I ordered two bulbs from ccfl warehouse and the new bulbs won't light when used with the original two. I can light the new bulbs with the inverter that came with the light kit but I notice I have to increase the voltage on my power supply and the current is higher than with my shorter test lamps.
    My questions are these. Do you think that the circuit is sensing the two different currents between the bottom and top bulbs and shutting down? Will buying two more bulbs of the same kind solve the turn on prolem? Do these inverter circuits on the power supply typically have enough range in the voltage and current to light a wider range of bulb specs?
    The only numbers on the power supply I could find are 715G2824-1-7 and on a tag on the solder side of the board 8EA42SQWP. The monitor was built in 2009.
    Thanks,
    Mike
  • MOSSEP
    Monitor Audio RSW12 - Green light but no audio
    by MOSSEP
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the...
    01-26-2025, 08:18 AM
  • MOSSEP
    Monitor Audio RSW12 - Green light, but no sound
    by MOSSEP
    Hi
    01-26-2025, 08:33 AM
    by momaka
    03-15-2023, 10:17 PM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
  • mikey5791
    Help on Samsung Syncmaster T220 dead ccfl lamp
    by mikey5791
    This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
    Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
    10-18-2020, 03:17 AM
