Dell 2007WFP Constant On/Off
  • marce002
    • May 2018
    • 316
    • Argentine
    #41
    Re: Dell 2007WFP Constant On/Off
    Originally posted by Dumah Brazorf
    Make a blob of solder over all the resistor.
    If you don't have flux it's time to have some. It will last for lifetime.
    Over the ofending 272 resistor only? Or over the whole set of resistors in thar area covered by that white glue?
    Marcelo J
    • Ghesil
      • Dec 2018
      • Romania
      #42
      Thanks.
      It worked for me as well it seems.
      I didn't have an SMD resistor so i kludged a normal 1/4 watt trough hole instead then fixed it with hot snort.
      • theplop
        • Sep 2019
        • 7
        Originally posted by POM_MJ
        I've the same issue one, and fixed by myself.
        1. I've remove all glue circled in the picture.
        2. replace the chip resister code 272 (2.7K, 0603, arrow pointed).
        hope this reply could help.
        ps. original pictures are from this thread => https://www.badcaps.net/forum/showthread.php?t=10658
        I had the same issue as others in the thread, monitor would turn off and on randomly. I assumed it was a capacitor. I replaced the resistor as suggested in this thread, and it has been working like a champ since!
        So, thanks guys!
        Pics attached.
        • atewari5
          • Jul 2020
          My monitor is having the same issue. while trying to replace chip resistor I messed up the board. Can I just remove the board all together from monitor as I dont use USB port anyways?.
          • KpaL
            • Jan 2021
            • Finland
            #45
            My dell works again!! Removed that broken smd resistor. Didn’t have 2,7k resistor so now there is 1.2k and 1.5k trough hole resistors in series.
            Used some hot glue to secure those resistors in place.
            • raddocki
              • Mar 2021
              • germany
              #46
              I did it exactly!
              • BustinCaps
                • Mar 2016
                • 43
                I fixed my 2007 WFP monitor by replacing the 2nd from the top resistor under the white silicon. It was a 10K resistor (01C) that was blown. Anyone having problems with this monitor should check all resistors and caps under the white silicon. Any one of them could be bad.
                • remaker
                  • Nov 2008
                  • 5
                  #48
                  This was EXACTLY my problem. My 2.7k resistor was actually showing wandering resistance when measured - it kept changing!
                  I unsoldered it and tore the pad. I then traced the pcb traces and connected the resistor (only 2.2k) to the transistor and IC directly for better mechanical strength.
                  I tore off some of the excess heat sink tape between the power supply and chassis to add back in some thermal mass for those resistors to replace the removed glue.
                  So far, so good. I would have NEVER found that failed resistor. Thank you, everyone!
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • Akhlz001
                    by Akhlz001
                    Yesterday, 07:15 PM
                  • master3112
                    by master3112
                    07-29-2025, 01:55 PM
                  • YOUCEF4787
                    Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                    by YOUCEF4787
                    I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                    Initial Problem:
                    The laptop was completely dead, no signs of life, no power LED.
                    Action Taken:
                    I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                    Current Situation & The Main Issue:
                    The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                    Today, 12:19 PM
                  • diamon
                    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                    by diamon
                    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                    Pictures of these boards:
                    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                    Dell...
                    02-28-2024, 12:51 PM
