245BW, can't find problem. No 24 or 6.3V, standby is good.
+ More Options
Posts
  • Yaaman
    • Jan 2014
    • 30
    • United Kingdom
    #101
    Re: 245BW, can't find problem. No 24 or 6.3V, standby is good.
    Hi selldoor
    Not I didn't. I'll try after work. But that in my opinion doesn't explain such a randomness.
    • selldoor
      Slow Learner
      • 7870
      #102
      Can I just check - the bulb in your bulb trick device is a filament bulb? not a powersaver cfl or led. What wattage?
      • Yaaman
        • Jan 2014
        • 30
        • United Kingdom
        #103
        It is good old style 100W incandescent bulb which is now banned in bloody EU. Fortunately I found some on eBay
        • Yaaman
          • Jan 2014
          • 30
          • United Kingdom
          #104
          I've just connected everything together and unfortunately it's not working. Test bulb comes on and after 2s is pulsing quickly.
          • Yaaman
            • Jan 2014
            • 30
            • United Kingdom
            #105
            It doesn't look good. I've got more than one issue.
            I removed solder from pins 12 and 14 of ICM801 - MC33067. With logic board connected test bulb is coming on randomly. But when I use 2k resistor and I start the power supply board with it the test bulb never comes on.
            I don't think the video board is bad as I have short circuit behind the J830 jumper (on the picture). When I reconnect the jumper I can see sparks and board dies.
            I need your help guys.
            • selldoor
              Slow Learner
              • 7870
              #106
              Budm is your best bet but can you put up a picture of the whole of the bottom of the board- cant see one and as the OP posted off site they have disappeared
              • Yaaman
                • Jan 2014
                • 30
                • United Kingdom
                #107
                Yes of course.
                • Yaaman
                  • Jan 2014
                  • 30
                  • United Kingdom
                  #108
                  Ok. I keep working. I've got all 24V and 5.3V now. I thought I swapped the zeners in 24V-to-5.3V section but I didn't. Anyway this part is now fixed.
                  I still need to find out why this power supply randomly making my "trick bulb" to light.
                  With video board connected test bulb always comes on. When I use 2k resistor the bulb comes on only sometimes. I really don't even want to think that the logic board is fried. I prefer to think it is because of the load.
                  Could it be because I used some Panasonic EB which are not low esr caps?
                  How do I diagnose that? Please help.
                  • WiseguyTom
                    • Jun 2014
                    • 3
                    • Belgium
                    #109
                    I had the same problem with my syncmaster 245B (which has a BN44-00195A power supply).
                    Blue light came on but no image on the screen.
                    I was able to fix it and want to share my experiences.
                    At first, the problem was intermittent.
                    Sometimes an image was displayed and then suddenly it went black again.
                    Hitting the back or side of the screen a few times, often brought back the image.
                    But I had to hit it harder and harder to get the image back and after a few weeks I deciced to have a look inside.
                    After visual inspection I saw nothing special, no bad capacitors or resistors.
                    Also the fact that hitting it often/sometimes brought back the image made me believe it's not caused by an electronic component but by something else.
                    But what? A bad or loose transformer was my first guess.
                    I took out a DVM and started measuring on the stand-alone power board.
                    Standby 5.2V was ok. Connected it to the Pwr-On line to activate the other output voltages.
                    Nada, no 24V.
                    Then I started bending the PCB, pulling up one side while holding down the middle.
                    Don't do this with you bare hands or you'll get electrocuted!
                    All of a sudden, the 24V appeared!
                    Then I stumbled on this blog:
                    http://blog.whitesites.com/How-to-Fi...97265_blog.htm
                    Here they mention soldering joins that went bad.
                    So I re-soldered all big end medium joints and that did the trick.
                    So get your soldering iron out guys!
                    Cheers,
                    Tom
                    • temyth
                      Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
                      by temyth
                      Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
                      The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
                      01-07-2024, 04:50 PM
                    • gugutm
                      a1989 820-00850 stuck at 5v 0.041a Help
                      by gugutm
                      I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
                      long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
                      of course before jumping to conclusion and connected to DFU , i believe i done basic checks...
                      01-04-2025, 09:35 AM
                    • psssst
                      Yamaha TSX 120 Standby Problem
                      by psssst
                      Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                      03-01-2024, 07:25 AM
                    • Yanleb
                      UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                      by Yanleb
                      My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                      Disconnecting the main board from the power supply makes the backlight come ON.
                      I did disconnect the panel cables and the WIFI modules, the board is still dead.
                      I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                      Thanks.
                      11-18-2024, 12:34 AM
                    • dicky96
                      Air Con PCB repair : some general question
                      by dicky96
                      Hi guys
                      I've been getting more air con controller boards of various brands for repair - mainly the ones from the outdoor compressor unit and I realise I have a lot of gaps in my specific knowledge, while being pretty good at electronic repair in general.
                      Does anyone know of any good resources for information on this sort of repair? I'm hoping here there will be some guys who are experienced in this. I'd specifically like more info on how the controller PCB works, because I expect they are all pretty much the same, and especially how it communicates with the indoor unit (protocols,...
                      11-22-2024, 04:40 AM
