245BW, can't find problem. No 24 or 6.3V, standby is good.
  • epicelite
    • Jul 2011
    • 58
    #41
    Re: 245BW, can't find problem. No 24 or 6.3V, standby is good.
    Apologies that it took me so long to get around to doing this, but here ya' go!
    Meter on the 20V DC setting.
    1. 5.5
    2. 0.01
    3. 2.7
    4. N/A
    5. 5.7
    6. 0.01
    7. 0.01
    8. 5.5
    9. 5.3
    10. 16.0
    11. 14.4
    12. 0.01
    13. 0.01
    14. 0.01
    15. 0.01
    16. 0.01
    17. 0.01
    18. 15.4
    • PlainBill
      • Feb 2009
      • 7034
      Well, that didn't work out very well. In another thread zulururu has the results and readings from the same pins. Here they are and what the pin does.
      1: 5.05v Oscillator charge
      2: 5.05v Oscillator return
      3: 2.54v Oscillator control current
      5: 5.08v 5.1 V reference
      6: 0.07v Error amp out
      7: 0.07v Error amp - in
      8: 5.04v Error amp + in
      9: 14.60v Enable adj.
      10: 0v Fault input
      11: 0.19v Soft start
      12: 14.06v B output
      13: 0v Gnd
      14: 0.27v A Output
      15: 15.06v Vcc
      16: 5.04v One shot RC
      One obvious problem is somehow you came up with an extra 2 pins. What is worse, zulururu has not updated his thread to indicate if replacing the main SMPS controller has solved the problem.
      I'll be honest, I don't have any solid recommendations at this time, just suggestions.
      You can repeat the measurements.
      The other thread has links to sources for the main smps controller IC.
      Searches for a schematic for this supply have been unsuccessful; perhaps you can have better luck.
      If I had my hands on a dead BN44-00195A, I could confirm that the main smps controller is actually the problem.
      PlainBill
      • epicelite
        • Jul 2011
        • 58
        #43
        Maybe I derped and measured the wrong one, I will check later.
        • PlainBill
          • Feb 2009
          • 7034
          One other point you should check is (CM512?), the long blue cap near the main SMPS transformer. The equivalent cap was the cause of problems on the BN44-00173A power supply. One point, on the other thread, I didn't see any signs of activity out of the SMPS controller, so I wouldn't bother replacing that cap, but if your DMM measures capacitance, it definitely is worth the trouble of removing it and verifying it is good.
          PlainBill
          • epicelite
            • Jul 2011
            • 58
            #45
            Not sure what cap your talking about, and I don't see any other IC's to check on this thing.
            • PlainBill
              • Feb 2009
              • 7034
              Uh, huh. The cap is identified in the picture as Long Blue cap. The IC is identified as This IC and the corner pins are numbered 1, 8, 9, and 16.
              PlainBill
              • epicelite
                • Jul 2011
                • 58
                #47
                Ok I will give it a check.
                Yeah that is the IC I checked, how the hell did I get 18?
                • epicelite
                  • Jul 2011
                  • 58
                  #48
                  Blue thing, starts out at about 34V's and slowly goes down as I measure it. If I stop for a few seconds and come back it starts out at 34V's again.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    1. Does your meter have a capacitance range?
                    2. What are the numbers on the blue capacitor?
                    3. How are you measuring it's capacitance?
                    PlainBill
                    • epicelite
                      • Jul 2011
                      • 58
                      #50
                      Dunno.
                      Can't read them too well:
                      12 U J 630V
                      This is my meter, nothing special.
                      http://www.harborfreight.com/7-funct...01B2163195C&mr
                      • Toasty
                        • Jul 2007
                        • 4171
                        #51
                        That meter does not have capacitance testing ability. (I have one of them.)
                        veritas odium parit
                        • epicelite
                          • Jul 2011
                          • 58
                          #52
                          I have another meter but no leads for it.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Dunno.
                            12 U J 630V
                            Any chance you can get a sharp picture of the numbers on the cap?
                            PlainBill
                            • epicelite
                              • Jul 2011
                              • 58
                              #54
                              Ugh can't find my camera.
                              It says
                              1 2 n J 630V
                              384 MMK(II or possibly an H?)
                              • PlainBill
                                • Feb 2009
                                • 7034
                                It says
                                1 2 n J 630V
                                Thanks for the effort. You have confirmed that it is a 12 nanofarad 5% 630 volt cap.
                                PlainBill
                                • epicelite
                                  • Jul 2011
                                  • 58
                                  #56
                                  So what's next then?
                                  Should I redo those readings from that IC?
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Yes, please. After that, you have several options. Zulururu has a replacement IC on order, until he has received installed it there is no point in your duplicating the effort. If you wish to replace CM512, equivalent parts are Digikey P12114-ND, Panasonic ECW-F6123JL or DigiKey 495-3215-ND, Epcos B32672L1123J000. Each would cost under $1.00, shipping would run under $3.00 by USPS First Class Mail. And I will admit, I don't know if that will work.
                                    I've said this before, troubleshooting this supply presents serious problems. Most SMPS supplies operate in the 70 Khz range; this one runs at 1 Mhz. I seriously doubt any DMM can react to the drive signal. On the other hand, an oscilloscope can easily see the drive signals.
                                    PlainBill
                                    • epicelite
                                      • Jul 2011
                                      • 58
                                      #58
                                      What if I sent you the power supply board? Or at least all the boards, dunno if you could figure the thing out without the LCD screen and backlight.
                                      Shipping the whole thing would be like $25 and I'm too poor/cheap for that.
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        #59
                                        Any progress?
                                        veritas odium parit
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          Originally posted by Toasty
                                          Any progress?
                                          Nothing definitive. I've received the power supply and tested it.
                                          When I used a 2.2K resistor from S_B to PSON to turn the main supply on, it came right up. The power supply is rated at 5.3 volts at 3 amps and 24 volts at 3 amps. I tried various loads, ranging from about 1 amp on each output to over 4 amps on both outputs, and it worked perfectly.
                                          The only conclusion I can come to is there is a short on one of the loads (signal board or inverter), which prevents the main power supply from coming up. I haven't tried shorting either output to see if that is a valid conclusion.
                                          The only obvious problem at this point is a number of the caps had been replaced with NTE caps. A complete recapping would be required before I'd try using it in a monitor.
                                          I did get voltage readings on the main SMPS controller at various loads, and frankly don't understand exactly what they mean.
                                          PlainBill
                                          • temyth
                                            Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
                                            by temyth
                                            Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
                                            The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
                                            01-07-2024, 04:50 PM
                                          • gugutm
                                            a1989 820-00850 stuck at 5v 0.041a Help
                                            by gugutm
                                            I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
                                            long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
                                            of course before jumping to conclusion and connected to DFU , i believe i done basic checks...
                                            01-04-2025, 09:35 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
                                          • Yanleb
                                            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                                            by Yanleb
                                            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                                            Disconnecting the main board from the power supply makes the backlight come ON.
                                            I did disconnect the panel cables and the WIFI modules, the board is still dead.
                                            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                                            Thanks.
                                            11-18-2024, 12:34 AM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
