245BW, can't find problem. No 24 or 6.3V, standby is good.
  • smason
    • 1652
    Re: 245BW, can't find problem. No 24 or 6.3V, standby is good.
    Originally posted by epicelite
    That cap circled in blue, it MIGHT be bad? I can go higher in the uf rating right?
    Umm no, if that's the startup cap, you should replace it with the same value as what's there now.
    • epicelite
      • Jul 2011
      • 58
      Well I don't know what it is but I replaced it with the exact same type.
      One here for $4
      http://www.audiolabga.com/data_html/STR.html
      Can't get it to accept my postal code for shipping calculation though.
      • PlainBill
        • Feb 2009
        • 7034
        Nope it still doesn't work, I refuse to pay $10 for a single IC. >:|
        Especially when it's not guaranteed to be the problem.
        I understand how you feel. There are very few options at this point. I have been unable to locate a schematic for this power supply.
        With an oscilloscope and isolation transformer we could determine if the IC is 'live' or not.
        The symptoms do not match a shorted output diode, but that could be tested. It is the large diode mounted at a diagonal to the right of the standby transformer.
        Replacement power supplies are available for under $55.
        PlainBill
        • PlainBill
          • Feb 2009
          • 7034
          One here for $4
          Strange. Where are you located? And have you tried contacting them either by email or telephone?
          PlainBill
          • epicelite
            • Jul 2011
            • 58
            Well it's too late to call today so I guess I will send a e-mail and try calling tomorrow.
            EDIT: Well now I have to fix this monitor ASAP. I got my Dad a new video card and it won't work with his CRT for some odd reason.
            • Toasty
              • Jul 2007
              • 4171
              #26
              Google: CP08515F
              SearsPartsDirect.com: $2.16
              PartStore.com: $2.18
              veritas odium parit
              • epicelite
                • Jul 2011
                • 58
                #27
                How do you know that's the same thing?
                • Toasty
                  • Jul 2007
                  • 4171
                  #28
                  veritas odium parit
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Well done!!!
                    PlainBill
                    • epicelite
                      • Jul 2011
                      • 58
                      #30
                      I ALREADY FOUND THAT, check out a few posts up.
                      • Toasty
                        • Jul 2007
                        • 4171
                        #31
                        Try reading it this time.
                        veritas odium parit
                        • epicelite
                          • Jul 2011
                          • 58
                          #32
                          That didn't do anything besides waste $8.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Hold it. Something is seriously wrong here. I've been dealing with the same power supply on this thread. The title of this thread indicates you have standby power. In post 1 you said the power light was on, that would indicate the standby supply was working....
                            Awww, crap!!! I'm sorry, I confused the S_B output with the 5.4 main output. Well, we're going to be following an existing trail.
                            First question: Does the power LED respond when you hit the power button - turn on and off?
                            If it does, the second question is: Does the voltage across the 82uF, 450 volt cap jump up to over 350 volts when the power LED is on?
                            PlainBill
                            • epicelite
                              • Jul 2011
                              • 58
                              #34
                              PlainBill
                              Yeah power light turns on and off, and I guess I could check that. I will get back to you.
                              • epicelite
                                • Jul 2011
                                • 58
                                #35
                                ON: 422V
                                OFF: 168V
                                Volt meter on the 1000V setting.
                                SO YOU'RE SAYING I SPEND $9 FOR THAT NEW IC AND SHIPPING AND IT WAS FOR NOTHING!? >:|
                                EDIT: Oops double post. :|
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  ON: 422V
                                  OFF: 168V
                                  Yes.
                                  The next step is to measure the voltages on the main SMPS controller - ICM801. Set your DMM to the 20VDC range, use pin 4 as the ground point, and measure the voltages on every pin of the MC33067P. Report the readings.
                                  PlainBill
                                  • epicelite
                                    • Jul 2011
                                    • 58
                                    #37
                                    Ugh it has like 20 pins!
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Only 16. And I'm only asking you to measure the voltage on 15 of them.
                                      If you would prefer, the power supplies are available on eBay.
                                      PlainBill
                                      • epicelite
                                        • Jul 2011
                                        • 58
                                        #39
                                        Well whats pin 1 and whats ground?
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          Package designation here. Note the notch at one end, some manufacturers have a dimple by pin 1.
                                          Use pin 4 for the ground point of the DMM. Perform the tests with the monitor plugged in, and the power led on (you may have to hook the monitor up to a signal so the monitor doesn't go into standby.
                                          PlainBill
                                          • temyth
                                            Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
                                            by temyth
                                            Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
                                            The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
                                            01-07-2024, 04:50 PM
                                          • gugutm
                                            a1989 820-00850 stuck at 5v 0.041a Help
                                            by gugutm
                                            I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
                                            long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
                                            of course before jumping to conclusion and connected to DFU , i believe i done basic checks...
                                            01-04-2025, 09:35 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
                                          • Yanleb
                                            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                                            by Yanleb
                                            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                                            Disconnecting the main board from the power supply makes the backlight come ON.
                                            I did disconnect the panel cables and the WIFI modules, the board is still dead.
                                            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                                            Thanks.
                                            11-18-2024, 12:34 AM
                                          • dicky96
                                            Air Con PCB repair : some general question
                                            by dicky96
                                            Hi guys
                                            I've been getting more air con controller boards of various brands for repair - mainly the ones from the outdoor compressor unit and I realise I have a lot of gaps in my specific knowledge, while being pretty good at electronic repair in general.
                                            Does anyone know of any good resources for information on this sort of repair? I'm hoping here there will be some guys who are experienced in this. I'd specifically like more info on how the controller PCB works, because I expect they are all pretty much the same, and especially how it communicates with the indoor unit (protocols,...
                                            11-22-2024, 04:40 AM
