Dell E152fpb power LED blinking on and off
  • smd
    • Jul 2011
    • 12
    I have a dell LCD monitor model E152fpb. When I connect to power it starts blinking on and off. The back light comes on momentarily then goes off. Which components do I check? Any help will be appreciated.
  • Demix
    • Jul 2009
    • 72
    Re: Dell E152fpb power LED blinking on and off
    Hey there smd. First things first open up the monitor and check the capacitors on the inverter/power board. Look for any bulging/leaking caps. That would probably be the first step. Also once you have the monitor open, get some pictures of it on here. One of the top and bottom of the Inverter/power boards. That way others may be able to spot problems that we would miss if we can't see what you're seeing. Also an extremely helpful guide to the two seconds to black problem can be found here - thanks to retiredcaps
    https://www.badcaps.net/forum/showthread.php?p=133261
    also when you upload pictures be sure to have them as attachments rather than inline or it will cause slower loading for the people trying to help you, sorry I cant be more helpful, but I will try and answer whatever questions you have until one of the skilled members of the forum arrives hehe :P
    • PlainBill
      • Feb 2009
      • 7034
      These monitors have a history of bad solder joints on the inverter transformers. When they fail, the driver transistors short, which can overload the power supply and result in the symptoms you see. As Demix indicated, bad caps can also cause this.
      PlainBill
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • noipi
        DELL INSIPRON 14 No power blinking orange/white
        by noipi
        i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
        05-06-2025, 08:08 PM
      • Borse2008
        by Borse2008
        • There’s
        07-15-2025, 04:55 AM
      • Mark01
        Dell Optiplex 7490 AIO - red power led after flash
        by Mark01
        Hi guys,
        This is my first post! 🚀
        I have no idea what I’m doing, but I’m learning by trial and error.
        I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
        07-04-2025, 12:54 PM
