ViewSonic VA1912wb
  • ubotts
    • Jul 2011
    • 57
    ViewSonic VA1912wb
    Hi I changed all eight caps on powerboard and I get the same problem a steady amber light and black screen fuses r good what should i check next its also connected to computer thanks in advance 4 any help
    It seems a few of these monitors have similar problems,did anybody have any success fixing them??
  • jsog
    • Feb 2011
    • 220
    Re: ViewSonic VA1912wb
    Are these pictures before the capacitors were replaced?
    • ubotts
      • Jul 2011
      • 57
      yes
      • jsog
        • Feb 2011
        • 220
        General questions:
        What brand and series of replacement capacitors were used?
        Are they all in the right way, polarity-wise?
        Are you sure all the cables are reconnected correctly?
        What happens when the power button is pressed?
        • jsog
          • Feb 2011
          • 220
          Wait--isn't this just a duplicate of this thread?
          • PlainBill
            • Feb 2009
            • 7034
            Right you are. Now I can ignore both of them.
            PlainBill
            • ubotts
              • Jul 2011
              • 57
              im new 2 the site give me a break
              • lostone
                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                by lostone
                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                05-19-2024, 11:40 AM
              • shahnld
                Sony kdl 65xg9505 green amber blinking
                by shahnld
                Good Day.
                I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                01-03-2024, 03:05 PM
              • huzo
                HP 470 G5 blinking amber light no power
                by huzo
                The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                I've tried flashing the bios...
                interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                06-08-2023, 04:08 PM
              • StefanNg
                Viewsonic VX2718-PC-mhd SG2701B01-8
                by StefanNg
                Hi, Badcaps.
                I am troubleshooting a monitor
                Viewsonic VX2718-PC-mhd.
                Panel model SG2701BSG2701-8
                Symptoms is no image.
                This panel has 2 panel board connected by a U-ribbon.
                When I disconnected the ribbon, I get a perfect half screen image.
                I took some test point voltage, when ribbon disconnected.
                HVAA 8.38v
                FVDD12 1.21v
                FDD33 3.3v
                VIN 11.79v
                VAA 16.85v
                VGHF 30.16v
                VGL -8.02v
                CK1_I ~ CK8_I 1.403v
                CK1_L ~ CK8_L 8.26v
                When I connect both panel board
                HVAA, VGHF, and CKx_L...
                05-17-2025, 01:43 AM
              • m041633n
                GDM50 LA-L241P Rev 1.0 - 2 Amber and 7 White Led Fix Needed
                by m041633n
                Hello Everyone!
                I would like to know the Jumper location for the 2 Amber 7 White Led Blink Code error. According to Dell 2,7 Led codes are for display or the Display cable failure. I didn't changed the display nor the cable. The issue happens only when restarting the machine from windows and from the BIOS. And when opening and closing the lid the display turns off and never turns back on. But the machine is working! I confirmed it by pressing the CAPS Lock key. Does anybody has this issue and fixed it by jumpering some fet near the display connector on the motherboard. If So Please Help...
                03-31-2025, 08:35 AM
