Vizio LP2626/VMM26-F20I
  • Schaugaard
    • Oct 2011
    Re: Vizio LP2626/VMM26-F20I (after thoughts)
    I had a similar situation, in my case however, c504 was clearly fried. (c504 is a 12pF, 3000 volt ceramic disc capacitor.)
    This monitor was not made to come apart. Don't forget to take out the deep screws. After the screws are out, it's going to take some cautious brute force prying with flat blade screwdrivers (it's good to have several). Start at the bottom speaker grill where the flat spots are and work your way all around. After that, it's downhill.
    Thanks for the above and good luck anyone trying to do this.
    • sportsman99
      • Jul 2011
      • 22
      where was the best place to buy 2 of the 12pf 3kv caps?
      • sportsman99
        • Jul 2011
        • 22
        I replaced both 12pf 3kv caps inline with the ccfl and this did fix my monitor. thanks to all for the input on this post. BTW i have 18 12pf 3kv caps available if anyone should need any.
          Did you test those ballast caps to see if the value has changed or it has leakage resistance? They usually fried with brown marking on the body. In your pictures, they look OK. I get my from MOUSER.
          • huntingoctopus
            • Mar 2012
            I just had mine die and have one black cap if i could buy a few just in case. let me know asap! thanks
            • IRIEBLUES
              • Aug 2012
              Sportsman99,
              reading this thread helps... however, someone like me.... well I know I am having the same issues and not sure what all these caps you guys are talking about.... I'd just like to buy the same parts you bought and hope it works... can you assist?
              • selldoor
                Slow Learner
                • 7870
                #27
                @IRIEBLUES you will probably have to pm sportsman99 if you want to buy some of his caps
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Originally posted by IRIEBLUES
                  Sportsman99,
                  These caps circled in red, they are high voltage capacitors, see if any of them look brown (they are normally blue).
                  Muh-soggy-knee
                  • ivangene
                    • Nov 2012
                    • 4
                    Hi guys - brand new - been reading and searching
                    my question is are the caps at 503 and 504 the same and is that also true on 517 and 519
                    my 504 is crispy!
                    my 503 reads N3 3KV SEC
                    my 517 reads N3 3KV SEC
                    my 519 reads 12J 3KV JNC
                    my thought was 504 might be the 12J 3KV JNC and maybe since 519 looks a little "dark" I would replace both 504 and 519
                    lastly is there an "alternative" cap that will not burn up - this thing was a PITA to open and I would rather not repeat in 6 months
                    THANK YOU for your inputs!!!
                      504 is the same as 519, they are symetrical.
                      I use TDK or MURATA, VISHAY from Digikey or Mouser. Just type in 3pf 3000V (or 6300V) in the search box
                      3pf 3000V, this will be hard to get.
                      12pf 3000v.
                      You can use 6300V instead, they will be larger.
                      http://s807.photobucket.com/albums/y...cpZZ1QQtppZZ20
                      • ivangene
                        • Nov 2012
                        • 4
                        so the link shows all caps removed - were they all replaced with the same P/N (12pf 3KV)
                        I am really electrically challenged so I thank you in advance for "dumbing it down" for me
                          I repalce them with what they should be, two are 3pf, two are 12pf. I replaced tham as a set. So make sure you mark each location to make sure you install the right value at the right location.
                          • ivangene
                            • Nov 2012
                            • 4
                            Thanks so much for the info and reply - I will report back my findings to bring a close to my end of the thread - planning to replace ALL 4 with same as factory
                            • ivangene
                              • Nov 2012
                              • 4
                              WOOOHOOOO!!
                              Thank You - the monitor works perfectly - We bought some caps off ebay out of Canada for about $4 took about a week to arrive, about 5 minutes to install, tested - worked, put it all back together and I have one really happy boy! that is a very nice monitor!!!
                              Thought I would close out my end - so many newb's never come back and thank forum regulars -
                              as for what we did (guess that is important too) I replaced cap c517 and c519 with same size 12pf 3kv caps )only one was "burned"
                              I would like to add - the "ribbon" connector on the power board does NOT unplug!!! - if you want it to be removed you have to unplug it from the other end which required removing the other metal box, pcb and a few wires - then unplug the cable to the power board - use some sort of a marker to mark the placement of the box before removing so it will align with the back when re-installed (its just "taped" in place)
                              Anyhow - hope to use this forum again and thanks!
                              • sportsman99
                                • Jul 2011
                                • 22
                                #35
                                SO i bought another monitor and replaced the 12pf caps the monitor comes on then off again after 3 seconds. i read resistor r525 and and it reads .9 Meg, can anyone tell me if this is a 1.5 meg resistor it is hard for me to read the color bands i would say it is brown/green/green. i did not have the 3pf caps but will get a couple of them but i wanted to replace resistors at the same time. Since they did not seem to read what they should.
                                i did see the pictures posted to this forum, awesome pictures i might add, still unsure of the resistor values.
                                  Does it read the same as R508? Did you test it off the board and your are not touching the meter probes with your hand?
                                  • sportsman99
                                    • Jul 2011
                                    • 22
                                    #37
                                    yes i did read them out of the board and it did read the same as 508. they looked somewhat dark in color but that could have been manufacturing. i read them with a analog meter and a digital meter (same results per say). with pg clips so as not to induce resistance from me. i have been able to keep this monitor up, but after a power cycle it is pot luck weather it comes up or not.. IF anyone has the 3pf caps for sale i could take 4 of them. i replaced the 12pf caps and have extras. i do have another vmm26 monitor i could pull the power supply on and read those resistors.. if any one has additional info thanks for the help.
                                    • sportsman99
                                      • Jul 2011
                                      • 22
                                      #38
                                      Well i decided to pull the power supply out of my working LP2626 monitor and i really like the way they stamped the resistor 508 and 525 it is a 1.5M resistor.
                                        That is correct. I just looked at my board last night.
                                        • kaolin
                                          Just registered so I could see the pictures—thank you for these posts; gave me the extra oompf to go the rest of the way, dismantling (this monitor is the most insane thing I've had to get into! and I thought laptop screens were annoying...). One of the 12J 3KV (C504) was horribly disfigured. Interesting that it seems to be that one in particular across the board...?
                                            Acer Aspire ES1-533-C504 Notebook ES Specification for Upgrade or Repair
                                            This specification for the Acer Aspire ES1-533-C504 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ES1-533-C504 boardview and ES1-533-C504 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 06:27 AM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
