Could use some help, trying to fix HP 1940 LCD
  • rqbwins
    replied
    Re: Could use some help, trying to fix HP 1940 LCD
    Thank you in advance.I will buy it tomorrow to see how it turns out.
  • selldoor
    replied
    It will be S4 59A but i think it must be obsolete. Other members seem to use the one I mentioned earlier SS24 SMB 40V 2A instead.
    Diode should have a low resistance reading one way and high resistance the other. If it is low ohms both ways or high ohms both ways it is faulty.
  • Nocta
    replied
    Have you checked if your lamps are working right?
  • rqbwins
    replied
    My simptoms are 2 second to black screen.On the attached photo ewerything in white circle is changed, and resoldered all the 16 pins.I am afraid to test eweryting becouse the diode on the back of the panel in the right corner is showing me 0.00 on both readings with my tester.The other diode in the middle is showing 0.143 on one reading.
    On the diode I can read S4 590 or 59A I am not sure
  • jetadm123
    replied
    Originally posted by rqbwins
    Here are the new photos.Hope that you can see better on this pictures
    You never did say what problems you're experiencing. Can you please give us a more detailed description of the problem? Does the power led remain on? Do you get 2 seconds to black? A complete description of the symptoms helps members point out things to check.
  • selldoor
    replied
    That is a much better picture - still cant read what it says on them perhaps you can and post it. Did you check them - The traces nearby would give me some concern - do they
    still conduct?
  • rqbwins
    replied
  • selldoor
    replied
    Picture is poor in comparison with your earlier ones. Cant even read the board numbers
    for the parts. Nevertheless I think thay may be SS24 SMB 40V 2A is that what they look like?.
    Please take note about the resoldering of the boards - if you dont do it it could blow all you have
    put in.
    @Nocta the cap is just below the diode.
  • Nocta
    replied
    Those seem to be caps for me. The one on the bottom of the board says C819.
  • rqbwins
    replied
    There it is
  • selldoor
    replied
    Can you post good clear pictures of the front and back of your boards
    with a close up of the area with the diodes on.
  • rqbwins
    replied
    On the back of the panel I have 2 diodes of the same kind.Can someone tell me what kind of diodes are ?
    I changed the tranzistors and ewerything else but I am having the same problem.
    One of the diodes from the back seems to be blown.
  • rqbwins
    replied
    Thank you for your help.I will post tomorrow how it turns out.
  • jetadm123
    replied
    Thank you for this quick reply.I would like to bother you guys with one more question.Which of the following transistor should I buy?
    1:IRFU9024 IR CI -ROHS-
    2:IRFU9024NPBF TRANZISTOR MOSFET,P I-PAK -55V-11A
    3:IRFU9024N IR HEXFET(R) POWER MOSFET 55V/11A38W -ROHS-
    You can purchase a repair kit from a Romanian seller on eBay:
    http://www.ebay.com/itm/REPAIR-KIT-E...item19cebe40e0
  • selldoor
    replied
    They will probably all work the U9024 is the important bit.
    Where are you looking at them - digikey/mouser/elsewhere.
    If the first two there will be data sheets which will give you an idea of the differences - it is usual package/ size/ manufacture or even just local product identification.
    You need to check that you get one the same size as you have.
    You need to get the correct mounting - surface or through hole
    For example IRFU9024N is the standard the PBF means it is lead free
    I-pak is the package style
    If you look here you can find the package style you need
    http://www.irf.com/package/pkhexfet.html
  • rqbwins
    replied
  • Jasgriff
    replied
    Already answered
  • retiredcaps
    replied
    Can Anybody tell me what kind of transistor is in q885.
    It is might be fu9024 (the same one as to the right of T802 and left of the big cap).
    These Benq boards are infamous for having bad solder joints on the inverter transformers, shorted c5707 transistors, shorted fu9024 mosfets, and blown picofuse.
    See
    https://www.badcaps.net/forum/showthread.php?t=8598
  • rqbwins
    replied
    Hello.Can Anybody tell me what kind of transistor is in q885.Becouse mine was so burned that I could not read the inscription on it.Thank you in advance for your help.
  • playman
    replied
    Update!
    Well I just repacked it and plugged it in for testing, with 2 fingers crossed and other
    hand ready on the socket
    So now i'm just going to fully assemble it and leave it on for awhile, and see if it will continue to work.
    Now I should be able to fix the rest of them.
    thanks every one for inputs and help
    With regards
    Johannes
  • Topcat
    Topcat's Budget Telephone System- Panasonic KX-TA624 Conquest
    by Topcat
    About 10~12 years ago I was given this Panasonic KX-TA624 analog telephone system with its 'master phone' and box full of extension telephones. It's been up in the attic all this time, untouched/unused since I didn't have a land line. It has all the line expansion cards, making it able to handle up to 6 outside lines and 24 internal extensions. I was told this system was removed from a shopping center that upgraded to a VOIP system.
    Why am I wasting my time on this you wonder? Well, I need a phone number for a little venture I'm working on....and I sure as hell don't want my personal...
    10-18-2019, 02:02 PM
  • metinjsh
    HP-1940 2STB
    by metinjsh
    Monitor HP-1940. PSU - BEN 48.L1G02.A01
    Hallo! I carefully check all the tips. At first there were bad transistors C5707 I chaged them, but after few hours problem repeated. I changed all capacitors and resolder transformer solder. And changed transistors again, but two of them all the time "blow".
    Fuse is ok.
    Picture: http://*************/photo/my-images/10/dscf3309s.jpg/
    Some of capacitors are larger then original, but it's just becouse I could not get the right rated voltage so I took higher voltage caps, but the same capacitance
    01-21-2012, 11:33 AM
  • alistair
    HP 1940 Lamps
    by alistair
    i Need to replace the bulbs in an HP 1940 but i cant find the part number anywhere to order them. i tried ordering some standard 19" bulbs but they werent quite right. i repair monitors for a living and im stumped. anyone know the part number?
    03-01-2011, 03:43 PM
  • terminatorX
    Hp 1940 flicker
    by terminatorX
    I have one hp 1940 (Benq 48.L1G02.A00) that when plugged to power starts flicker rather rapidly and just keeps doing that. To mention not connected to PC. The power led is on.
    It's not originally my screen so I can't really say anymore in the symtoms department and I removed the power board from the inside now. Nothing really seems to be blown or damaged, no bulging of capacitators. Is it the usual C5707 transistor problem?
    02-09-2012, 12:45 PM
  • terminatorX
    Bad Hp 1940 and 1955
    by terminatorX
    Hello=)
    I'm new here so please bear with me.
    I'm a newbie in this field....
    I have googled alot and found a couple of threads here but decided to make one thread of my own.
    It's not originally my screen so I can't really say anymore in the symtoms department and I removed the power board from the inside now. Nothing really seems to be blown or damaged, no bulging of capacitators....
    02-08-2012, 03:47 PM
