Dell E172fpb
  • techbrat
    • Nov 2009
    • 13
    #381
    Re: Dell E172fpb
    well; I did read all 18 pages. The found one very good picture but it is too small to see all the line tracing. I need a super large image of a good board showing all 4 transistors.
    I checked the fuse for continuity and it shows continuity? is that the way the fuse should be tested?
    • techbrat
      • Nov 2009
      • 13
      #382
      Re: Dell E172fpb
      if this picture was a little bigger and zoomed in a lot closer. I could see the detailed line tracing!
      • PlainBill
        • Feb 2009
        • 7034
        Re: Dell E172fpb
        Yes.
        PlainBill
        • PlainBill
          • Feb 2009
          • 7034
          Re: Dell E172fpb
          Try clicking on the thumbnail in post 120.
          PlainBill
          • techbrat
            • Nov 2009
            • 13
            #385
            Re: Dell E172fpb
            well I completely give up on this board.
            if anyone wants to repair this power board give me your email or something and I'll mail it to you.
            None of the caps are bad and the fuse shows continuity.
            the traces lifted around the transistors and its becoming a pain to do this because it did not work. none of the transformers were making any noise or humming. But seriously. after 3 sets of transistor installs. I GIVE UP
            • Mohonri
              • May 2009
              • 13
              #386
              Re: Dell E172fpb
              It's possible that one or both of the FU9024N transistors on the board have failed as well. If one of those fails to a short, the entire board shuts down. I don't recall how they are labelled on the board (and I'm 1400 miles away from mine), but they have the same package as the 2SC5707's.
              Can I assume that you resoldered all the legs of the transformers when you replaced the transistors?
              • techbrat
                • Nov 2009
                • 13
                #387
                Re: Dell E172fpb
                Yes; you are assuming right! I just soldered some caps on a 1000watt power inverter that we overloaded. First time worked like a charm. Its this lcd power board that will not work for me no matter what I do.
                • EGuevarae
                  • Nov 2008
                  • 1336
                  Re: Dell E172fpb
                  The very few units I've repaired from this model, had the 2 FU's, the 4 c5707's & the fuse repaired even if they were good (some 07's dead, some not ...), had any suspicious looking solder point reflowed and the transformers were resoldered even if they looked like new.
                  There are 10 kind of people in this world: those that understand binary, and those who don't.
                  • ASUS ROG Maximus IX Code
                  • Intel Core i5-7600K 3.8GHz
                  • 16gb GSKILL TridentZ RGB DDR4-3200
                  • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                  • Windows 10 Pro x64
                  • GeForce GT1050
                    2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                  • minimad5
                    #389
                    Re: Dell E172fpb
                    Hello everyone
                    As you can most probably see i'm a newbie here and would like to ask afew questions as i have also come under the bug of the Benq.
                    firstly i would like to ask, would it affect the voltage if i externally mounted the transistors on heatsinks ?
                    as i intend to use rather bulky TIP3055 transistors to replace the standard c5707's.
                    I'm not amazingly good when it comes to electronics but i presume rightly or wrongly that these will do the job.
                    the only other transistors i have at hand are TIC106M, TIP121 and TIP2955 but again i could be wrong, i cannot use these within the monitor as they will simply cook due to higher Voltage or Amps.
                    Would i also need to replace FU9024 ?
                    As my monitor comes on for afew seconds and simply goes black, but with the green power button
                    Thanks for reading
                    and Thanks for any responses
                    Mark
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Re: Dell E172fpb
                      Originally posted by minimad5
                      Hello everyone
                      Thanks for reading
                      Mark
                      If you had the flu, would you ask the doctor to remove your appendix?
                      The 'two seconds to black' symptom indicates the transistors are probably fine. Certainly, you should at least test them before blindly replacing parts.
                      How are the caps? Have you resoldered the transformers? Are all CCFLs working? Are there any shorted diodes? All of these should be tested. And lastly, the problem with the Benq board was not the specs on the transistors, it was the crappy soldering on the transformers. The transistors were the victims, not the culprit.
                      PlainBill
                      • YourBrainiacs
                        #391
                        Re: Dell E172fpb
                        OK, I am a nexperienced electronics and computer technician. A customer of mine )who is very important to my business) gave me an E172FPb to repair. The symptom was the very common on for about 2 seconds, then blank screen with the green light staying on. Power supply voltages were good, caps all looked perfect, there was a little discoloring around the output transistors and only one of the transformers. Cleaned up all the solder connections around the inverter section, replaced the driver and output transistors, and the problem persisted. After much deliberation and testing, I found that only one of the CCFL lamps was firing. (Should have checked this first......) Turned out that the top lamp section (there's two lamps in there) was cooked. When I took it apart, you could visibly notice burning around both lamp ends on one side. Replaced the lamps and the monitor runs perfectly. So, if you're having the shutdown problem after two seconds, please check your lamps!!!
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          Re: Dell E172fpb
                          More than once it has been suggested on the forum, either by PlainBill, myself and others, to test the lamps and the inverter separately to isolate the problem. Look around and you'll find references to the case mod kit used to test lamps.
                          But good advice to new members
                          • GeForce GT1050
                          • whone
                            • Nov 2009
                            #393
                            Re: Dell E172fpb
                            Hello!
                            I have been reading all these pages now trying to find a solution for my broken monitor Dell E172fpt made by lite-on. The issue is that one ic placed on ic801 on the powerboard is blown up, the partnr is LTA201P or TA201P. I have been searching for schematic on the monitor and the ic, since the ic is hard to find i must find a replacement for it and therefor a datasheet on the ic.
                            Is there any one who can help me?
                            Thanks in advance.
                            Best regards Whone.
                            • Rogerbird1
                              • Jan 2010
                              #394
                              Re: Dell E172fpb
                              I have been reading this thread for 2 days now, I have a Dell 15" monitor I am trying to fix. I found the 3A fuse bad, replaced it and am only getting 9v to the PWM IC pin 9. The backlights come on for a few seconds and go out. When they go out the Pin 9 climbs in voltage. The Power Led stays Green. I have plugged in different CCFLs and no difference.
                              This is the 2 lamp version of the BENQ board.
                              The C5707 transistors all measure good. I have resoldered the board.
                              Suggestions on what to do next?
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Re: Dell E172fpb
                                Measure the resistance of the transformer secondaries.
                                PlainBill
                                • pconn5
                                  #396
                                  Re: Dell E172fpb
                                  Hey, I'm new here. I have a Dell E172FPb 19" monitor with a bad psu/inverter board. I tried soldering the 4 transistors that need replacing but the traces on the board were just fried so there was no way of getting them connected. I want to try and use the monitor for a project, it just needs the display and not the back-light with it. Does anyone know/can find out what the voltages are for the 10 pins that go out to the benQ logic board? So I can use and external power source (most likely a computer psu).
                                  Thank you for any help!!
                                  pconn5
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Re: Dell E172fpb
                                    pconn5
                                    Why not pull the fuse that provides power to the inverter and then measure the voltages yourself?
                                    PlainBill
                                    • pconn5
                                      #398
                                      Re: Dell E172fpb
                                      I'm at school and don't have access to a multimeter right now, or really any time in the near future so I can't really do this. Also the board has breaks in the circuit so I am guessing that they voltages would be off or missing all together.
                                      • DJ XtAzY
                                        • 7
                                        #399
                                        Re: Dell E172fpb
                                        Hi! I attempted to repair this by replacing the 4 trannies. It worked for one day and then it died because Q759 is burnt and discolored. The other 3 is fine. So I replaced that one. When I power it up, it would light up but after about 10 seconds, it shuts off, including the green power button. While it's on I can hear a hissing sound from the board, not sure which part it is coming from. Also I measured the outputs for the backlight and it reached up to 400V??? That's not normal right? I also get no voltages at time for the 2 diodes (D751 and D761). None of the FETs are shorted from my multimeter. Fuses are fine. No bulges from any caps. Already re-soldered the transformers and other joints which i think it could be a dry-joint. Any ideas?
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          Re: Dell E172fpb
                                          Use a paper or plastic tube (the paper tube from the center of a roll of paper towels would be ideal) as a sort of stethoscope to identify the source of the hissing sound. It could be a bad transformer or a loose wire to a CCFL.
                                          PlainBill
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
