Re: Samsung 2493HM issue
Leave the power boad face down. Unscrew the logic card and turn it face up (leave screws out). Put a piece of cardboard underneath the logic board so it is not touching the metal shield.
Leave the connections in place.
Now measure the voltage regulators on the logic card. You can still use a screw hole (GND) for the black probe.
Ok, i replaced the two fuses on the power board and i am back where i started. Meaning, i get a solid blue led and no picture. Im posting two pics of the opposite sides of the semi-assembled boards. The metal shielding is blocking access to the pins on those chips that i need to test. Is there a possibility of not connecting some of the components to do the test or will that yield inconclusive results?Leave a comment:
Yeah, i figured out what kind they were. I checked the bridge rectifier and its good. I should have the fuses in a week or so. Ill post pics of my setup for testing out those chips when i get the fuses.Leave a comment:
Now i just need to find out what kind of fuse they are.Leave a comment:
You obviously want to order replacements (maybe 4 or 5 in case it blows again), but you also want to check out the bridge rectifier as well before installing the new fuses.Leave a comment:
Yeah, im getting no reading on either of the fuses. I tried all ranges of ohms.Leave a comment:
I should explain the troubleshooting process here.
When the LED is green/blue, but you don't see the computer wallpaper with a flashlight, this implies that something is wrong with the logic board. That is why we are checking the voltage regulators on the logic board.
If the LED is green/blue and you can see an image with the flashlight, that implies something wrong with the inverter board or ccfl.
If you have no LED, that implies that there is something wrong with the power supply and/or the logic card.Last edited by retiredcaps; 02-16-2011, 12:43 AM.Leave a comment:
It would also help if you could give us an overall picture of the boards when everything is assembled so we can see how you are testing it using a multimeter. That way, we can suggest test points that are easy to reach for the multimeter probes.Leave a comment:
If you have no LED at all, you probably shorted something out. I wouldn't say it is completely dead, but we will now have to troubleshoot what components are shorted out or blown.
With power off and the lcd unplugged, check the following.
1) Check the two fuses by the AC input. A good use should measure less than 1.0 ohms.
2) There is a bridge rectifier (long black) just below the 2J 474J white capacitor. Number the pins 1, 2, 3, and 4. Set your multimeter on 200 ohms. Measure 1-2, 1-3, 1-4, 2-3, 2-4, and 3-4. Any reading under 30 ohms suggests it may be shorted.Leave a comment:
Well, in trying to test the voltage regulator i got some good sparks flying. Unfortunately how they built this thing it was impossible to fully assemble without the back panel and test the leads. I had to set it up where the logic board and power board were hovering over each other. Needless to say, as soon as i hooked it up i got shocked and i saw some sparks when i was trying to disconnect it. Now, fully assembled, the led wont even light up. Is it completely dead?Leave a comment:
Red circled chip: 6P741
Yellow circled chip: (brand: ST) LF25GKDK7747Leave a comment:
2) What is the part number for the yellow circled component?
3) To measure the DC voltage of a voltage regulator, put your multimeter on 20V DC. Plug in all boards and plug in the lcd into the AC outlet.
Put your black probe on a ground screw on the logic board. Put your red probe on each of the individual pins of the circled components. List the DC voltage for each component and pins.Leave a comment:
2) Still waiting for answers to questions #3 and #4 in post #2.
3) Forum members here like Panasonic FR, FM, and FC (in that order). Other good quality caps are listed in the FAQ section at
https://www.badcaps.net/forum/showthread.php?t=2280
Badcaps.net sells Rubycon.
4) You must use low ESR caps for a SMPS application.Leave a comment:
If i were to replace all the caps, what brand would be preferred/suggested? Thanks in advance.Leave a comment:
Ok, ill take some photos of it once my camera charges up. Ill probably just order some caps and replace the majorit of them.Leave a comment:
This would be a good time to post some good focused photos of the top and bottom of your power board. Photos of the logic and inverter boards would also be good.Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by vincentedelHello,
I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...-
by ManucslHello.
My TV is a QE65Q800TATXXC Samsung TV.
Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
Any ideas to check would be very appreciated 😊
After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump... -
by FourRunnerI purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...1 Photo
by ScHAmPiHi all,
Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...2 Photos - Loading...
