Samsung 2493HM issue
--- begin sig file ---
--- end sig file --- -
Re: Samsung 2493HM issue
Ok, i replaced the two fuses on the power board and i am back where i started. Meaning, i get a solid blue led and no picture. Im posting two pics of the opposite sides of the semi-assembled boards. The metal shielding is blocking access to the pins on those chips that i need to test. Is there a possibility of not connecting some of the components to do the test or will that yield inconclusive results?Comment
Leave the power boad face down. Unscrew the logic card and turn it face up (leave screws out). Put a piece of cardboard underneath the logic board so it is not touching the metal shield.
Leave the connections in place.
Now measure the voltage regulators on the logic card. You can still use a screw hole (GND) for the black probe.--- begin sig file ---
--- end sig file ---Comment
you can use the screw holes or the metal shields of the VGA, DVI or HDMI connectors.
i usually stick the negative lead of my DMM into the holes intended to fasten the VGA or DVI cable to the socket.
oh and you might wanna get the keypad out of the casing and connect it up.. otherwise you won't be able to turn it on (most monitors stay in off-mode when the button board isn't connected)
edit: in theory you should be able to use the whole metal cage as ground too. It should be grounded through the various screws of the PSU board and others.Last edited by Scenic; 02-24-2011, 01:39 AM.Comment
Ok, sorry for the delay. I forgot to hook up the control panel. Thats why i didnt get any readings at first. On the red circled chip i got 5.22, 0, 5.22 on the three pins starting from the top in the image. On the yellow circled chip i got 2.52, 0, 3.31 on the three pins starting from the top in the image.Comment
The yellow readings looks correct.--- begin sig file ---
1) Okay, with power off and lcd unplugged, put your multimeter on 200 ohms (if manual), and measure the red circled component to see if it is shorted.
Measure the resistance between pin 1-2, 1-3, and 2-3. List all the ohms measurements. A reading of 30 ohms or less suggests the voltage regulator is shorted.
2) Can you post a clear focused picture of just the red circled component? Clear enough that we can see/read the part number.
3) What is the board designation for this component? That is, what is the PCB marking for this component? Is it something like U102?--- begin sig file ---
If you have a manual ranging multimeter, set it to 200 (two hundred) ohms. Touch the black and red probe together. It should read 0.3 or 0.4 ohms. If it is higher than 1.0 ohm, there is something wrong with your multimeter.
If your multimeter reads "1" or "OL", it means the measurement is outside your chosen range. Don't confuse "1" on the left hand side of this display with 1.0 on the right hand side. The first means out of range and the second means 1.0 unit of your measurement.--- begin sig file ---
I have a sense that I'm not getting the message through.
Setting your multimeter on 200 ohms and getting a reading of "1" on the left hand side IS a reading. It implies the reading is > 200 ohms. That implies the voltage regulator is not shorted.
However, the DC voltage readings suggests it is "failing high". Normally a voltage regulator takes a voltage in (say 5V DC) and outputs something lower like 3.3V or 1.8V DC depending on the regulator.
With the part number you gave (6P741), I cannot find a datasheet to verify what should be the correct voltage. That is why I asked for a clear close up picture of the component.--- begin sig file ---
by KjellAfter installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...08-01-2025, 09:15 AM -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by NairolfHello,
I have a Samsung DM32D display.
When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
Here’s what I have tried so far:- Disconnected the cable between the mainboard and the power supply → the backlight turns on.
- Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
- Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
From these tests, I suspect the problem might be on the mainboard. Could anyone...3 PhotosYesterday, 03:47 AM -
by vincentedelHello,
I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...-
by ManucslHello.
My TV is a QE65Q800TATXXC Samsung TV.
Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
Any ideas to check would be very appreciated 😊
After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump... - Loading...
