Samsung 2493HM issue
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung 2493HM issue
    Originally posted by werthles
    Now i just need to find out what kind of fuse they are.
    It is hard to tell from the angle of the pictures, but they (the fuse values) are usually written write on the board.
    --- begin sig file ---
    --- end sig file ---
    • werthles
      • Feb 2011
      • 24
      Yeah, i figured out what kind they were. I checked the bridge rectifier and its good. I should have the fuses in a week or so. Ill post pics of my setup for testing out those chips when i get the fuses.
      • werthles
        • Feb 2011
        • 24
        Ok, i replaced the two fuses on the power board and i am back where i started. Meaning, i get a solid blue led and no picture. Im posting two pics of the opposite sides of the semi-assembled boards. The metal shielding is blocking access to the pins on those chips that i need to test. Is there a possibility of not connecting some of the components to do the test or will that yield inconclusive results?
        • retiredcaps
          • Apr 2010
          • 9271
          Leave the power boad face down. Unscrew the logic card and turn it face up (leave screws out). Put a piece of cardboard underneath the logic board so it is not touching the metal shield.
          Leave the connections in place.
          Now measure the voltage regulators on the logic card. You can still use a screw hole (GND) for the black probe.
          • werthles
            • Feb 2011
            • 24
            Ok, here is my problem. As you can see from the pics, this is the only way i can set it up where i got the wires hooked up (except the speakers, which i hope is ok for the test). Can i still use the screw holes on the logic board as a ground?
            • Scenic
              o.O
              • Sep 2007
              • 2642
              you can use the screw holes or the metal shields of the VGA, DVI or HDMI connectors.
              i usually stick the negative lead of my DMM into the holes intended to fasten the VGA or DVI cable to the socket.
              oh and you might wanna get the keypad out of the casing and connect it up.. otherwise you won't be able to turn it on (most monitors stay in off-mode when the button board isn't connected)
              edit: in theory you should be able to use the whole metal cage as ground too. It should be grounded through the various screws of the PSU board and others.
              • werthles
                • Feb 2011
                • 24
                #27
                Ok, i tested all the pins on those chips and i get no reading whatsoever. I used the metal shielding as the ground. Am i supposed to get at least some sort of reading?
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Is the power LED on? If yes, you should defintely get a reading with your multimeter set on 20V DC.
                  • werthles
                    • Feb 2011
                    • 24
                    #29
                    Ok, sorry for the delay. I forgot to hook up the control panel. Thats why i didnt get any readings at first. On the red circled chip i got 5.22, 0, 5.22 on the three pins starting from the top in the image. On the yellow circled chip i got 2.52, 0, 3.31 on the three pins starting from the top in the image.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      Hmm, can you recheck the voltages for the red circled chip again? The readings you have provided don't seem right.
                      The yellow readings looks correct.
                      • werthles
                        • Feb 2011
                        • 24
                        #31
                        I just checked again, same results.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          1) Okay, with power off and lcd unplugged, put your multimeter on 200 ohms (if manual), and measure the red circled component to see if it is shorted.
                          Measure the resistance between pin 1-2, 1-3, and 2-3. List all the ohms measurements. A reading of 30 ohms or less suggests the voltage regulator is shorted.
                          2) Can you post a clear focused picture of just the red circled component? Clear enough that we can see/read the part number.
                          3) What is the board designation for this component? That is, what is the PCB marking for this component? Is it something like U102?
                          • werthles
                            • Feb 2011
                            • 24
                            #33
                            I was unable to get any reading under 200 ohms. I set it to 20k ohms and i got the following readings:
                            1-2: 3.15
                            1-3: 2.19
                            2-3: 10 (and constantly rising)
                            Ill have to look up on how to get my camera to be able to focus on those chips
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #34
                              1-2: 3.15
                              1-3: 2.19
                              Just to clarify your multimeter's operation ...
                              If you have a manual ranging multimeter, set it to 200 (two hundred) ohms. Touch the black and red probe together. It should read 0.3 or 0.4 ohms. If it is higher than 1.0 ohm, there is something wrong with your multimeter.
                              If your multimeter reads "1" or "OL", it means the measurement is outside your chosen range. Don't confuse "1" on the left hand side of this display with 1.0 on the right hand side. The first means out of range and the second means 1.0 unit of your measurement.
                              • werthles
                                • Feb 2011
                                • 24
                                #35
                                Im just gonna replace that one capacitor that i snagged from another system and see if that does anything.
                                • werthles
                                  • Feb 2011
                                  • 24
                                  #36
                                  I just tested my multimeter, it works fine. I still could not get a reading off of those chips when the multimeter was set to 200 ohms. I only saw result when i switched it to 20k ohms.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    I have a sense that I'm not getting the message through.
                                    Setting your multimeter on 200 ohms and getting a reading of "1" on the left hand side IS a reading. It implies the reading is > 200 ohms. That implies the voltage regulator is not shorted.
                                    However, the DC voltage readings suggests it is "failing high". Normally a voltage regulator takes a voltage in (say 5V DC) and outputs something lower like 3.3V or 1.8V DC depending on the regulator.
                                    With the part number you gave (6P741), I cannot find a datasheet to verify what should be the correct voltage. That is why I asked for a clear close up picture of the component.
                                    • werthles
                                      • Feb 2011
                                      • 24
                                      #38
                                      Sorry about that. I have been trying to figure out why i cant get my camera to get a close up of that specific chip. I will play around with it some more.
                                      • werthles
                                        • Feb 2011
                                        • 24
                                        #39
                                        I tried to get my camera to focus on that chip and to no avail. Ill note what numbers i see around it. Maybe IC304 is its part number.
                                        • jetadm123
                                          • 2169
                                          #40
                                          The 6P741 appears to be too small for a voltage regulator. Probably a special function chip.
                                            09-07-2024, 05:50 AM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some timeβ€”like after playing a gameβ€”the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                          • Manucsl
                                            QE65Q800TATXXC Samsung TV Issue
                                            by Manucsl
                                            Hello.
                                            My TV is a QE65Q800TATXXC Samsung TV.
                                            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                            Any ideas to check would be very appreciated 😊
                                            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                            02-19-2025, 07:47 AM
                                          • FourRunner
                                            Display issue Samsung TV UA65JS9000W
                                            by FourRunner
                                            I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                                            10-03-2024, 07:05 PM
                                          • ScHAmPi
                                            Samsung UE48JU7000 screen issue after backlight replacement
                                            by ScHAmPi
                                            Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                                            I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                                            07-15-2024, 05:41 AM
