Optiquest Q9 No secondary Voltages
+ More Options
Posts
  • alexanna
    • Mar 2010
    • 1346
    I have a Optoquest Q9 monitor that has no secondary voltages.
    It uses a SG5841 SMPS controller.
    I have a steady 162volts D.C. at the large capacitor.
    I can follow what I think are a series of startup resistors R812 R814 and R819
    The voltage starts up stable at 162 volts on R813.The voltage through R814 starts to become unsteady jumping from 59volts up to 62volts,and the voltage is really unsteady through R818 jumping from 12volts to 17 volts very rapidly.
    Pin #3 of the SG is the Vin at its very unsteady jumping from 12 to 17 volts rapidly.
    Pin 7 VDD is jumping from 11 to 15 volts .
    Pin #2 is FB and its jumping from 0 to 4.5 volts rapidly.
    There is 50v 10Uf C824 that has been replaced. The voltage on it is jumping from 11 to 15 volts rapidly
    Because of the unsteady voltage at the Vin pin#3 I suspected a problem with the SMPS controller, I have replaced it with one I had from a spare board that was working. It did not make any difference the voltages stayed the same.
    http://pdf1.alldatasheet.com/datashe.../SG5841SZ.html
    What am I missing?
  • smason
    • 1652
    Re: Optiquest Q9 No secondary Voltages
    Is this with a load or no load?
    • alexanna
      • Mar 2010
      • 1346
      No logic board is hooked up,so no load.
      • PlainBill
        • Feb 2009
        • 7034
        Don't forget the inverter is a load. We had one like this with a bad transistor on the inverter Also, check the tertiary winding which provides power for the SMPS controller.
        PlainBill
        • alexanna
          • Mar 2010
          • 1346
          PlainBill
          Please correct me if I am wrong but, I wouldn't think the inverter would be suspect with no logic board connected.
          I did remove the capacitor for the inverter section so I guess that will disable it?
          I have another identical power supply that works; I measured the resistance of the tertiary winding. I did not look it up but I guessed that's the SMPS coil. There was no difference noticed in the readings on either board.
          I do not have a ring tester so I swapped the good coil to the board I am having problems with, No difference in the voltages were noted.
          • jetadm123
            • 2169
            There's also a diode and resistor off the tertiary winding that provide voltage to the 10uf cap. Try checking those two devices.
            • PlainBill
              • Feb 2009
              • 7034
              A properly working inverter would not cause problems. But if one of the drivers were bad, that could cause problems.
              If you look at the schematic of the power supply / inverter of just about any monitor you will see the primary winding, the secondaries, and there is a third winding that provides run power for the SMPS controller. If that is open or shorted, or if the diode is open or shorted you will get the symptoms described.
              PlainBill
              • alexanna
                • Mar 2010
                • 1346
                A little bit of an update,
                I have replaced diodes 802 and 808 these are on either side of Q801 mosfet ,There are two large resistors R821 and R803 and these check OK.I also have substituted a good mosfet Q801.
                I have removed the 24v, 12v and 5v capacitors on the secondary side to try to rule out something on the secondary drawing an excessive load, I am still noticing the voltage fluctuation to pin 3 of the SG component.
                I am noticing something different today. If you look at the picture of the bottom side of the power supply just to the right of the A.C. plug. CR904 and CR901 are clicking, its very noticeable.
                These are BAV99 which are switching diodes, Could this be a clue of anything else to check
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Clicking means the PSU is in protect mode. Be *very* careful - removing capacitors will NOT shut a power supply down guaranteed and could very well fry stuff! It will shut down a well-behaved power supply, true. However, IF the power supply shuts down, ALL rails go down since they're regulated by the same controller, i don't know what you are aiming for here.
                  If you want to disable a voltage rail remove the switching diodes (this will still kick it in protect mode), or better, just unplug whatever is feeding off that rail or cut the trace after the capacitors. If it's not possible to unplug the load, cutting the trace will remove any load and the power supply should come up.
                  A working TV? How boring!
                  • alexanna
                    • Mar 2010
                    • 1346
                    Well what I'm trying to do I figure out why I have unstable voltages on the primary side of the power supply, and why the standby power will not start.
                    I really just don't know he correct way to go about it.
                    • Rtech
                      • Jul 2010
                      • 1095
                      I recently has a fault caused by a bad SG6841,same pinout as your SG5841,and the fault symptom on the controller was 4.52volts on the Vin(pin3),indicating it was shot.On replacing it,and the monitor now working fine, I again measured the Vin to confirm my diagnosis,and then it read 16-18v varying.So your Vin, although varying,the range of that variation seems grossly excessive.
                      • alexanna
                        • Mar 2010
                        • 1346
                        My understanding of how the SMPS works if very fogy .Pin #3 of the SG5841 is fed from R819, And the voltage is jumping all over the place.
                        I have tried to isolate to one side of the P/S, I am unsure if I did it the correct way. Earlier in the process I did remove the photocoupler to see if voltages would stabilize on pin #3 of the SG component.
                        Other than getting grand Uncle Blackbeard's blunder buster out, I'm unsure on what to try.
                        Is there any thing I have missed on the primary side that could be causing this problem?
                        You say The SG5841 and SG6841 have similar pin outs, Could SG6841 be used as a substitute, I notice that part on a lot of used power supplies that I have sitting around?
                        I am totality up to suggestions so if anyone has ideas I am willing to try.
                        • Rtech
                          • Jul 2010
                          • 1095
                          What cct Diagram are you looking at ???,send a url if possible.
                          • alexanna
                            • Mar 2010
                            • 1346
                            Unfortunately I have not found a circuit diagram I am just trying to compare things between a working board and the one that's not working
                            • Rtech
                              • Jul 2010
                              • 1095
                              In that case. looks like a 'swap' job,piece by piece until the culprit can be found.Most input sides have only a few components,so try 2 at a time ,and you should soon locate the faulty bit.Although these transformers rarely go wrong,I certainly would not ignore it,as the tertiary winding is an integral part of the start up.
                              • alexanna
                                • Mar 2010
                                • 1346
                                ^ I was really trying to keep the swap to a minimum, But so far I've done a good job.
                                Working tertiary has been substituted
                                The 2 diodes near the power mosfet
                                The sense resistors check Ok
                                A working mosfet
                                A sg5841 that was working from another board
                                A new run cap
                                There are some glass diodes that appear to be involved D804 and Z802. I have not done anything with these other than compare from board to board.
                                Is there anything I have missed?
                                • Rtech
                                  • Jul 2010
                                  • 1095
                                  Well,then you diconnected the Optocoupler,so perhaps you need to swap it ??Also Earth/Ground problems,can also cause the odd thing,so it must be worth checking the Ground on pin 1.Apart from those I cannot think of anything else at the moment.
                                  • alexanna
                                    • Mar 2010
                                    • 1346
                                    I have substituted a new octocoupler,And checked the ground on pin #1 of SG 5841 The ground is at most 6MV. There is no change in behavior.
                                    When I removed the octocoupler, would that have disabled the secondary side to rule out a excessive secondary load causing the fluctuating voltage I am seeing?
                                    Or is there another way I should go about doing this?
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      I just don't know,with a diagram suggestions are easier,i don't think removing the coupler,would have removed the secondary load.I may have a scrap Optiquest board come to think of it....will have a look tomorrow....please confirm the ID on your Board to ensure I am looking at like for like.
                                      • alexanna
                                        • Mar 2010
                                        • 1346
                                        The part number and revision can be seen in the first photos.
                                        If you need any thing else let me know
                                        • marce002
                                          Macbook Core i7 2010 a1286 820 - 2850A CRAZY JUMPING voltages
                                          by marce002
                                          Hello
                                          Need just to know how do you guys determine what the problem is, when we have some fluctuating volt, to discard a faulty TPS 51125 , or if the issue is after this IC.
                                          CRAZY JUMPING
                                          PP3V3_S5 = 0v to 3.33 v jumping
                                          PPBUS_G3H = 12.4v to 12.48 jumping a little
                                          PP5V_S5 = 2v to 5v aprox, jumping fast
                                          P3V3S5_ENTRIP = crazy jumping from low volt
                                          SMC_PM_G2_EN = jumping 0v to 3.3v crazy
                                          STEADY
                                          P3V42_G3H=3.39V steady
                                          PP5V1_CHGR_VDD=5.06v steady
                                          PPCHGR_DCIN= 18.29 to 18.31 jumping
                                          09-08-2021, 04:08 PM
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                        • gjgib
                                          Help reading schematic voltages input/output
                                          by gjgib
                                          Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                          I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                          I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                          I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                          05-06-2024, 08:11 PM
                                        • RossMoodley1967
                                          HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                          by RossMoodley1967
                                          Hello
                                          Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                          Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                          03-01-2024, 06:07 AM
                                        • karlp028
                                          MSI Z390-A PRO missing VCORE voltages
                                          by karlp028
                                          I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                                          06-23-2025, 01:25 AM
