Samsung 740N power problem
  • dminev
    Hi everybody,
    I have Samsung 740N with blank screen. After replace caps 3X820uF with 3X1000uf and blown pico fuse 3A fuse blow again. With no fuse voltage reading is 18,6V on 13V line. I know 18,6V is too high. On pin3 of DM0565R voltage reading is normal 15,6V but on pin4 is imposible measure voltage because my digital multimeter automatically switch off. Any suggestion?
    Sorry for my bad english. This is my first post.
    09-07-2024, 05:50 AM
  • jesterace
    Samsung UE46ES8000 Blown fuse but no other signs of short
    by jesterace
    Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
    09-11-2024, 03:14 PM
  • vincentedel
    Samsung SyncMaster 740n Phase Control Issue
    by vincentedel
    I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
    I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
    04-22-2025, 12:33 AM
    09-06-2024, 11:40 PM
