Samsung 231T, recapped, no power, no lights
  • selldoor
    Slow Learner
    • 7870
    #41
    Re: Samsung 231T, recapped, no power, no lights
    I am assuming ref to a 213T is a typo - you can edit it if your quick
    Your right it doesnt have the fuse detail however if you look at the 'silver' ends of the main fuse it has the details on it. Have you tested the fuses? if they are good you dont actually need the detail
    Its always better if we can see your boards as we may spot
    problems
    The suggestion to replace caps after the mosfets is because the mosfets may have failed because as caps fail they put pressure on other components eg mosfets
    so if you have replaced mosfets it makes sense to replace the caps that may have contributed to their demise.
    • RalphSimon
      • Dec 2012
      • 6
      The original post in this thread starts
      My search shows no successful repairs on this particular Samsung 213T Syncmaster LCD model....
      Mine is a 213T. I just assumed KINGOFCOINS had made the typo.
      It appears to me that all the follow on posts are in reference to 213T not 231T.
      [His images are for a 213T. I know nothing of a 231T]
      I assumed everyone else also assumed he meant a 213T not a 231T & ignored the supposed typo.
      • selldoor
        Slow Learner
        • 7870
        #43
        Ok - you will gather I have not read the history - its a bit like looking at pics of other boards.
        Anyway there are two fuses on the Power supply board.
        One is a white ceramic and the other is a Black Barrel
        I can actually read that it is a T3.15A 250v.
        Power off, meter on ohms 200 one probe on each end of fuse
        or each fuse leg what do you get.- Should be the same as
        touching the probes together.
        • RalphSimon
          • Dec 2012
          • 6
          Those PS fuses are OK. 0 Ohm
          However re-reading my initial post I should have clarified I was referring to the SMD fuses F51 & F101 that protect the FETs. Both appear open circuit
          I have tested the 8 FETs
          U52 & U54, U101 & U105 are short circuit
          (The 4 furthest from the connector)
          • selldoor
            Slow Learner
            • 7870
            #45
            I can see SMD F1 but cant make out the two you mention board numbers are too blurry. A good picture would help.
            Is there no markings on them - Looks like there is something on F1 but cant read it
            What are the part numbers on the fets.
            • bluto
              • Oct 2007
              • 560
              #46
              Stop the madness. Its all laid out in my 213T thread. Basically what has transpired is that that the 4 220uf caps on the inverter have failed. The excess ripple causes one or more of the AO4600 MOSFETS to short out. This then causes the fuses to blow. So you need to replace the shorted MOSFETS (SMD can you handle soldering these?), replace the 4 220uf caps and any blown fuses on the inverter (4 amps). Also replace any bludged caps on the power supply while you are in there. I fixed over 30 of these a couple years back and they all came back to life.
              • RalphSimon
                • Dec 2012
                • 6
                Hi Bluto.
                To reiterate, (I have read your thread)
                I have replaced the 6 caps on the PSB & 4 on the inverter board
                I have now identified the 4 shorted MOSFETS U52 & U54, U101 & U105
                & could buy some (obsolete) AO4600s off of eBay. Please advise if I should use a better, newer equivalent MOSFET. I note AO4619 (which you used) & AO4622 are listed as replacements, but even those seem obsolete / unavailable now! Am in UK.
                As for my ability to (un/)solder them, time will tell. I have some braid & isopropyl alcohol
                I have identified that the 2 SMD fuses F51 & F101 are open circuit, but am trying to discover their value so I can replace those too rather than jumper them.
                Thanks.
                • selldoor
                  Slow Learner
                  • 7870
                  #48
                  Originally posted by RalphSimon
                  Hi Bluto.
                  Thanks.
                  Bluto has now said they are 4 A fuses - these may be suitable
                  http://www.ebay.co.uk/itm/10-X-FUSE-...item3cca246825. It is sometimes easier to solder them on top of the
                  existing dead fuses rather than risk damage to the pads.
                  You could also check out the stock at farnells
                  http://uk.farnell.com/jsp/search/bro...D2031%2B204372
                  You will need to get the physical size right. some are 0603 and some 1206.
                  • bluto
                    • Oct 2007
                    • 560
                    #49
                    I might have some AO4619s left if you are unable to procure any. I think either is fine. I did not experience any issues using them alongside the AO4600s. I would practice removing some smds from a dead motherboard first. If you can't do it satisfactorily, then chipquik is definitely recommended to get the old ones off easier.
                    • RalphSimon
                      • Dec 2012
                      • 6
                      Selldoor - Don't know how I missed Bluto's 4A info.
                      Bluto -Thank you for your most kind offer. However >
                      I have already bought on eBay (giorgio11185, China), package deal for 8 only of each, including delivery (8 of each to have some spares!)
                      10PCS AO4600 4600 SOP8 POWER MOSFET TRANSISTORS
                      Item number:390349008895 Sale price:US$5.00
                      10Pcs Littelfuse SMD 0603 4A 4 Amp Fuse
                      Item number:250896762299 Sale price:US$4.00
                      When I'm finished, if there are any left over... as a thank you to this board, anyone here can have them for free.
                      I'll update here as & when.
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • mrtek
                        Samsung UN43NU6950FXZA No power
                        by mrtek
                        Hi
                        Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                        Main fuse = OK
                        Back light LED = OK. Power them with aux power source
                        LED output = OK 156V
                        I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                        Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                        07-20-2025, 08:06 PM
                      • TKF
                        Samsung BN44-00775A no Power No STB or Power lights.Help needed
                        by TKF
                        After a lot or reading and searching I suspected PB Power Board#BN44-00775A but after voltage tests I'm not sure what they indicate or point to.
                        1st I unplugged MB and left only BLs plugged in to see if I got light No BLs come on. So I suspected Black lights but then tested BLs with BL tester they came on. I suspect a short somewhere I started testing at the STB pin 8v/on13v I get 12.80v note no stb lights on
                        I noticed with only MB plugged in MB showed signs on life saw red light on not sure from where and it started warming up.
                        Thanks for any help or ideas or testing suggestions...
                        06-26-2023, 11:05 AM
