Re: Chimei CMV 221D - doesn't power on
Thanks once again all you guys, I have ordered the 10 pack of regulators recommended on ebay by PlainBill. Should we consider this thread solved until they arrive which should be in around 1-2 weeks?
a) I failed the ESP class in school...
a) There's this funny little field in the Member Profile form called LOCATION.
b) The cross reference info might help someone find the part. I found it on a RC model site.
d) All the ones on eBay (no matter what country) seem to come out of Hong Kong.
e) I AM Moriarty
ToastHowever, in the spirit of the season, here are the responses.
a) ALL guys fail intuition. Marriage solves that. I know no matter what goes wrong, it's my fault.
a) Yes there is. And you and I are nice enough to have filled in that field. Others haven't. I considered asking Topcat to make that field mandatory, but decided not to go there.
b) I found the specs by Googling the original part number. This gave that information that it was a 1A regulator. After that, there are dozens of sources.
d) Almost everything comes out of Hong Kong. According to the WSJ, next year they are going to start shipping babies to the US. Walmart is already planning on stocking them.
e) So who died at Reichenbach Falls?
PlainBillLeave a comment:
e) I AM Moriarty
ToastLast edited by Toasty; 12-08-2010, 02:48 PM.Leave a comment:
ST Micro. - LD1117AS33TR
DigiKey has it:
http://search.digikey.com/scripts/Dk...=497-1228-1-ND
as does Mouser:
http://www.mouser.com/ProductDetail/...XsRjw3YqNjM%3d
Toast
What!!!! You didn't read Sherlock Holmes when you were a kid?
DigiKey has it:
as does Mouser:
ToastLast edited by Toasty; 12-08-2010, 10:20 AM.Leave a comment:
I thought I'd be a bit daring and bridge the two U6 & U7 +3.3V middle pins together with a wire so as to elevate the other from roughly 3.1V to 3.3V and the screeen shows picture now
My question is, is it okay to run like that, or should I get a replacement? & if I get a replacement can someone help me find an equivalent chip from ebay?
http://shop.ebay.com.au/i.html?_nkw=....c0.m270.l1313
Oh and thanks all your guys for your kind help these past days. *cough* where do I send the cheque haha
Some of the parts on eBay are correct, you want a part rated at 1A, not 800mA. Also, it must be the SOT-223 package, not TO-220 or some of the others. This auction combines factors I consider important - Correct part, Excellent feedback rating, low shipping cost.
Oh, and do NOT try using the monitor until the parts come in. There is always a chance of corrupting one of the memory chips on the logic board.
I thought I'd try and desolder the two U6 & U7 chips and swap them to see if it is indeed faulty and to see if the voltage changes to the other. As soon as I change it and plug the power back in, bingo the power light turns on & also screen turns on nowI measure the voltages and for some reason both now are reading 3.3V, even the one that was reading 2.41V.
I then quickly plug in the DVI cable to see if it shows anything on the screen, but just my luck it only shows white on the screen now, no menus or anything
edit: to be exact the one that was fauly is now reading 3.17V, and then other now 3.26V
Al.
sorry i missed your editLast edited by alexanna; 12-08-2010, 03:50 AM.Leave a comment:
Oh and thanks all your guys for your kind help these past days. *cough* where do I send the cheque hahaLeave a comment:
Even though, I hadn't disconnected them, I reseated them and measured some pins for resistance from the logic board to the screen and it seems okay. Still white screen though. Perhaps the U7 now at U6 position is still faulty reading @ 3.17V?Leave a comment:
white screen => recheck your cable connections from the logic card to the lcd panel. Make sure both sides are connected properly.Leave a comment:
edit: to be exact the one that was fauly is now reading 3.17V, and then other now 3.26VLast edited by funkster; 12-08-2010, 12:06 AM.Leave a comment:
edit: I don't have any kind of thermometer to measure its temp, although while I ground myself and touch both U6 & U7 to compare, U7 seems ever so slightly warmer.
edit2: If I was to replace it with an equivalent from on of these: http://shop.ebay.com.au/i.html?LH_Av...1&_sop=2&_sc=1
Is it likeley that it could be fixed? Or is it likely that other components are fried in that circuit as well?Last edited by funkster; 12-07-2010, 10:33 PM.Leave a comment:
Okay after realising that I was looking at the wrong board lol
F1 checks out as a short, so that must be okay.
U6 Part no. is "AMC1117" "-3.3 F0628J" The voltages from left to right pins are 0V, 3.27V, 4.99V.
U7 Part no. is the same as U6, voltage readings from left to right pins are 0V, 2.41V, 4.77V.
F1 (left side near the connector to the power supply) Check the resistance.
U6 (upper left corner) What is the part number? Check the voltage on the three legs (the tab is connected to the middle pin). Use the mounting screw near the top center as ground.
U7 (middle of board) Same steps as U6, but voltage may be different.
U7 Part no. is the same as U6, voltage readings from left to right pins are 0V, 2.41V, 4.77V.Leave a comment:
What cap brand/series did you use to replace the little one I suggested before? For some reason it is -very- picky about that cap. That's why I suggested FC or FM. I had a nearly identical unit with a new Rubycon YXG there and it would not run. Replaced with an FM and it took off right away. It was a 22uF @ 50v, correct?
ToastLeave a comment:
It very well could be a bad logic card. Before replacing it, here are some points to check.
PlainBill
I can't seem to find these labels anywhere?Leave a comment:
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
