Re: Chimei CMV 221D - doesn't power on
Are you applying a video source to the VGA input? I've seen these not respond without it.
You must have the 5v and 12v from the power supply. If the main switcher is running, you should have both voltages.
What cap brand/series did you use to replace the little one I suggested before? For some reason it is -very- picky about that cap. That's why I suggested FC or FM. I had a nearly identical unit with a new Rubycon YXG there and it would not run. Replaced with an FM and it took off right away. It was a 22uF @ 50v, correct?
Toast
It very well could be a bad logic card. Before replacing it, here are some points to check.
F1 (left side near the connector to the power supply) Check the resistance.
U6 (upper left corner) What is the part number? Check the voltage on the three legs (the tab is connected to the middle pin). Use the mounting screw near the top center as ground.
U7 (middle of board) Same steps as U6, but voltage may be different.
PlainBillLeave a comment:
edit:
Although it doesn't turn on with the power button. The screen that is.Last edited by funkster; 12-06-2010, 10:48 AM.Leave a comment:
When you say no activity from the front power light, does that mean not even an amber stand by light?
Al.Leave a comment:
I can verify that it is reading correctly for 250Vx1.414Leave a comment:
1) What were you checking when you shorted out the supply? You may have shorted one or more of the semiconductors.
2) Did you go back and verify that you installed the caps correctly?
3) I believe the Delta power supplies have several SMD fuses underneath the board. Check around and look.
4) Post a photo of the bottom of the power board.
5) Do you get any activity from the power light?
1) I'm not sure, but there are two voltages going to the other main board, Two +5V pins, and a +13.8V pin. I may have shorted them out togther or one of them to another pin beside it. I had replaced the F102 fuse which was underneath the board and have reverified that it's okay and the voltages are reading good.
2) Yes.
3) Once again I can only seem to find the F102 fuse. The other fuses F100, F101 and F200 that are on the top of the board are also okay.
4) Check.
5) No Power LED activity.Last edited by funkster; 12-06-2010, 10:29 AM.Leave a comment:
The little cap next to the blue cap near the transformer. Start up cap.
IIRC 22uF @ 50v. Panny FM or FC.
ToastLeave a comment:
If you see the power LED come on, then most likely you have some or all of the secondary voltages (5V DC and 19V DC).
If the power LED does not come on, then check carefully check (high voltage alert) the main filter capacitor (the big one) for mains x 1.414 DC voltage.
That is, if you live in the USA, 120V x 1.414 = 160 to 165V DC.Leave a comment:
5) Do you get any activity from the power light?Leave a comment:
Hi, a few weeks back I found my Chimei 221D LCD Monitor not able to power up in the morning after I left it in standby mode with my computer on. The power light doesn't light up at all when pressing the power button to turn the screen on.
I took the initiative to open it up and have a look for blown fuses, they all checked out with my multimeter. I also noticed that the Capacitors where hissing. The power board is a DAC-19M009, and the main board is a a170e2-e03-h-s6
I tried to test the voltages going to the a170e2-e03-h-s6 main board and they seemed okay, but then I accidentally shorted out 2 of the voltages and blew the 4 amp "W" F102 fuse nearby. So I went and bought a replacement kit for the DAC-19M009 board off ebay, it came with the 4amp "W" Fuse, replacement capacitors except for the big 120uf 400V, and replacements for the AOP605 MOSFETs.
I waited about 3 weeks to revieve them, then took out my trusy old soldering iron and went ahead and replaced the capacitors, 4 amp fuse, and MOSFETs. I went ahead and plugged the power in and still it work power up
The only thing I managed to fix was the hissing from the old capacitors
Can anyone be of any help? Is it possible to use a "a170e2-e03-h-s6" main board from a different brand? because I have searched for it and have found people sell them, but they had no chimei version. If I did replace that wouldn't it just change the what it is detected as, and also change the menu etc?Last edited by funkster; 12-02-2010, 08:51 AM.Tags: None
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
