Planar PL1700-BK - backlights go out
  • De3rcr
    • Apr 2010
    • 94
    I have this monitor and when I hooked it up to a pc it was working then after XP loaded the backlight went out I could still see the image with a flashlight. I'm going to replace the caps first but I have a mixture of different caps.
    Here are the caps on the power board now
    4 x 470uf 25v lelon rxk
    2 x 1000uf 10v elite ej
    1 x 10uf 16v elite pf
    1 x 10uf 100v elite pf
    what I have to replace them are
    470uf 25v nichicon pw
    1000uf 10v panasonic fm or nichicon he
    I have to buy the 10uf ones but digikey has fc's and pw's to replace those. My question is, is it ok to mix all these different caps?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Planar PL1700-BK - backlights go out
    Yes. You notice the manufacturer did that. OK, that's probably going to give you any confidence. But the answer remains the same. In terms of life expectancy there is no difference between Nichicon and Panasonic as long as the caps are good enough for the application.
    PlainBill
    • De3rcr
      • Apr 2010
      • 94
      OK, I'm going to order the 10uf from digikey and post back with what happens.
      • retiredcaps
        • Apr 2010
        • 9271
        Quick test. If you lower the brightness and constrast to 20/20 respectively, does the monitor stay on longer?
        The reason I ask is that most "2 seconds to black" is 2 seconds or less to black. With yours, I know XP takes at least 1 minute to boot and am curious if lowering the settings help the monitor stay on longer?
        Great photos. I'm jealous that I can see grass in the background. Here I just finished shoveling snow and it is piled about 2 feet on one side. Anyone still playing Beach Volleyball on Daytona Beach?
        --- begin sig file ---
        --- end sig file ---
        • De3rcr
          • Apr 2010
          • 94
          I was able to lower the brightness and contrast and was able to get the room where I'm working darker, the backlights do seem to stay longer and they flicker(kinda like a pulse) the whole time until they shut off. they stay on about 2 min. And if I unplug it and let it sit awhile it does the same thing.
          I ordered the 10uf caps and am going to replace all the caps.
          I haven't seen anyone playing volleyball lately, but some people are still working on their tan.
          • De3rcr
            • Apr 2010
            • 94
            OK, I replaced all the caps and now the backlights turn off in about 30 seconds.
            I replaced the caps with
            1000uf 10v nichicon he
            10uf 16v nichicon pw
            10uf 100v panasonic fc
            • retiredcaps
              • Apr 2010
              • 9271
              If you have a fan, trying cooling the power/inverter board and see if it stays on longer.
              • alexanna
                • Mar 2010
                • 1346
                I do not see where you tried substituted one or two good ccfls to see if the back lights will stay on.
                The flickering you mention makes me wonder if a ccfl may be causing your problem.
                Al.
                • De3rcr
                  • Apr 2010
                  • 94
                  Al.
                  Unfortunately I don't have any spare parts to check the ccfl's. I was hoping to maybe track it to the inverter. I'm trying to follow retiredcaps "2 secs to black" post, but I'm not sure I'm taking the right readings with the dmm.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    What about the cooling fan? Backlights on for 30 seconds seems more like thermal related to me.
                    • De3rcr
                      • Apr 2010
                      • 94
                      Tried cooling the board, that doesn't keep the lights on any longer. But if I unplug it then plug it back in the lights stay on for about 5 or 6 seconds.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Okay, list the readings that you are getting when measuring the inverter transformer T901. We will interpret them.
                        • De3rcr
                          • Apr 2010
                          • 94
                          OK, I used the white dot on the transformer as pin 1
                          1-2=open
                          1-3=open
                          1-4=open
                          1-5=.581
                          1-6=open
                          1-7=open
                          1-8=open
                          2-3=0
                          2-4=open
                          2-5=open
                          2-6=0
                          2-7=0
                          2-8=open
                          3-4=open
                          3-5=open
                          3-6=0
                          3-7=0
                          3-8=open
                          4-5=open
                          4-6=open
                          4-7=open
                          4-8=.581
                          5-6=open
                          5-7=open
                          5-8=open
                          6-7=0
                          6-8=open
                          7-8=open
                          hope this is what you needed
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            1-2=open 2-3=0 3-4=open 4-5=open 5-6=open 6-7=0
                            1-3=open 2-4=open 3-5=open 4-6=open 5-7=open 6-8=open
                            1-4=open 2-5=open 3-6=0 4-7=open 5-8=open
                            1-5=.581 2-6=0 3-7=0 4-8=.581
                            1-6=open 2-7=0 3-8=open
                            1-7=open 2-8=open
                            1-8=open
                            7-8=open
                            What scale did you use on your multimeter?
                            The 1-5 and 4-8 reading of .581 suggest the secondaries are okay.
                            I have another test for you to try since you do not have another or spare ccfl. I'll post the instructions in a new post below.
                            • De3rcr
                              • Apr 2010
                              • 94
                              dmm set on 2k
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                dmm set on 2k
                                Okay, that explains the 0. Your multimeter is probably showing 0.x ohm, but the resolution says it is 0. If you remeasure the 0 ohm reading with a 200 ohm scale, it will probably show 0.x ohm.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  This section will probably make it into rev 0.3 of the guide, but right now for those without a spare or good ccfl, here it is.
                                  === snip ===
                                  Pay ATTENTION as there is a VERY HIGH VOLTAGE (600V to 1000V)! As a safety precaution, it might help to have someone around when you are doing this if something screws up.
                                  Alternatively, if you do not have a spare CCFL, try this test for a completely dead non working CCFL.
                                  a) TURN POWER OFF and unplug the monitor and wait 1 minute
                                  b) disconnect all CCFLs expect #1
                                  c) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
                                  d) TURN POWER OFF and unplug the monitor and wait 1 minute
                                  e) disconnect all CCFLs expect #2
                                  f) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
                                  g) TURN POWER OFF and unplug the monitor and wait 1 minute
                                  h) disconnect all CCFLs expect #3
                                  i) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
                                  j) TURN POWER OFF and unplug the monitor and wait 1 minute
                                  k) disconnect all CCFLs expect #4
                                  l) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
                                  If one of the CCFLs does not show "2 seconds to black", it is likely physically damaged (cracked) or the wiring is completely broken to it. Take out that CCFL and inspect it. If all 4 CCFLs do show "2 seconds to black", one or more can still be bad. This test only tests for a completely dead CCFL or completely broken wiring.
                                  Replacing a CCFL is a delicate operation. See "Lamp Soldering Tutorial" at http://ccflwarehouse.com/lasotu.html to see what steps are involved.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    The inverter controller chip is OZ960. Here is the datasheet.
                                    We may need to take measurements later? Note the pins are very close to each other and caution is needed when measuring voltage as it easy to short something out.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      BTW, the test results in post #17 is highly dependent on the inverter controller IC.
                                      I haven't looked through OZ960, but having just one ccfl connected may not be a valid test.
                                      Thanks to alexanna for pointing this out to me.
                                      • De3rcr
                                        • Apr 2010
                                        • 94
                                        === snip ===
                                        OK,
                                        checked the backlights and if you look at my first pic the connectors on the far left and far right don't show any light, but the middle 2 give "2 secs to black" so I guessing I need to order some cclf's. But I can check that chip if needed.
                                          HP Elite Elite 7200 MT Elite 7200 i5-2400 Specification for Upgrade or Repair
                                          This specification for the HP Elite Elite 7200 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7200 MT boardview and Elite Elite 7200 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:44 PM
                                          HP Elite Elite Slice (ENERGY STAR) Elite i5-6500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Elite Slice (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice (ENERGY STAR) boardview and Elite Elite Slice (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Elite Elite 7100 Microtower PC Elite 7100 i3-530 Specification for Upgrade or Repair
                                          This specification for the HP Elite Elite 7100 Microtower PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7100 Microtower PC boardview and Elite Elite 7100 Microtower PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          HP Elite Elite Slice Elite i5-6500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Elite Slice can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice boardview and Elite Elite Slice schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
