Proview pl713s -newbie in distress
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Proview pl713s -newbie in distress
    Originally posted by lasttarget
    Please show me the math you did to find the part AO4606?
    I don't what you are asking, but if you go to ebay.com and put in AO4606 in the search field and sort by lowest price and shipping, you get
    http://cgi.ebay.com/4X-AO4606-Comple...68907984326727
    edit: If you are asking how I got the "AO" part, I simply searched here at badcaps.net for 4060 and found numerous references to AO4060.
    --- begin sig file ---
    --- end sig file ---
    • torin3
      • Aug 2009
      • 178
      Nevermind...I didn't check the next page before posting...
      Last edited by torin3; 01-02-2011, 11:33 AM. Reason: Whoops, question already answered.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
