Sony GDM-FW900: Help me diagnose why it won't turn on? (Video included)
  • jrodefeld
    • Apr 2020
    • 7
    I have a vintage Sony GDM-FW900 crt monitor that I really enjoy using, but it has developed a problem and won't start up.
    This unit was completely serviced a few years ago by Unkle Vito in Los Angeles and it fully passed all tests, was factory calibrated, etc. There was a faulty part (can't remember exactly which one) that was replaced at another repair shop about a year ago. Other than that, it's been working great.
    I just say all that to say that this unit is probably in pretty good shape since it's been fully serviced and checked recently.
    I'm in a location that doesn't really have any businesses that repair CRTs (that I could find) so I'm wondering if it's something I could potentially do myself?
    I suspect something relatively simple.
    What happens is that when I push the power button, the unit makes four screeching / clicking sounds, then goes into standby. Nothing shows up on the screen.
    There's also a place on one of the boards where there is a flashing blue light that lights up along with the screeching sound.
    Here's a video I recorded of the behavior:
    https://new-content.wistia.com/medias/36c9b89iww
    Any clue what the problem is?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Sony GDM-FW900: Help me diagnose why it won't turn on? (Video included)
    Shorted CRT is my guess. These were known for bad tubes.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Looks like spark gap SG901 is firing off, same as on one of my faulty GDM-FW900 monitors.
      The problem on mine ended up being the tube going bad / leaked air. Not repairable, unfortunately. The thread can be found here:
      https://www.badcaps.net/forum/showthread.php?t=15248
      And the exact issue described here:
      https://www.badcaps.net/forum/showpo...3&postcount=22
      I also already tried changing the flyback transformer on mine and even swapping parts from my other working GDM-FW900.
      So unfortunately, yours is probably dead / unrepairable too.
      That being said, DON'T TOSS IT!
      Try selling it for parts on eBay or elsewhere. The parts from this monitor can be used to revive other Sony CRTs, so it's not a total loss. Granted it might take a while (a year or more) before you find a buyer for the parts, but it's worth it, IMO. Finding used parts for CRTs is becoming harder and harder nowadays.
      • 3dfan
        • Jul 2019
        • colo
        hi, just wondering if you were able to fix that issue?
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          I doubt it.
          This is usually the sign of a CRT tube that has lost vacuum / leaked in air.
          Not repairable, unless you have or know someone that has a large glass furnace and extremely high pressure vacuum pump to re-seal the tube... and even then, I don't think it's something anyone could do "at home", even with these type of tools.
            • 31017
            maybe, but i have had crt sockets with shorts between the contacts and spark ring before
            those widescreen tubes usually fail with a shorted blue gun causing a blue field in the background
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Interesting.
              But most of the failures I've seen mentioned here and on Youtube were usually with that dreaded screeching noise and SG901 firing off.
              The only way I can get SG901 not to fire off on mine is to disconnect the HV anode from the tube. Then the monitor will attempt to turn On for a few seconds... well, at least before the HV on the anode goes too high and jumps to ground somewhere. I haven't made a proper HV load for it yet, though I've purchased the parts not too long ago (it's also for a DIY HV probe with a cubic ton of 1M resistors.)
              Easiest way to see if the tube has gone to air is to put 5V between H1 and H2 (tube heater) pins on the tube with the A-board / tube socket disconnected. If you don't get faint orange glow from the heater, tube has certainly lost vacuum. Mine's that way.
                • 31017
                if the tube loses vac you will see a mottled effect on the face as the phosphor starts to fall off the glass.
                • microso
                  All in one Sony Vaio VPCL22Z1E 3D version no video on main display
                  by microso
                  I bought an all in one Sony Vaio VPCL22Z1E 3D version which does not show anything on the display, instead it works ok on the hdmi output (video and sound).
                  I tested with a flashlight and it seems that it does not display the image without backlight.
                  It doesn't make any sound in the built-in speakers and the headphone output has a very weak level.
                  As an observation, I use a 19.5V power supply with 120W and in the specifications the original one would have 180W.
                  Could this be the reason why it doesn't work properly?
                  Mainboard is V021_MP_3D_1.1 1P-0115J00-8011...
                  12-18-2023, 08:29 AM
                  GeForce RTX2080 Super Aero video gaming card issues help need
                  by sam_sam_sam
                  This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                  Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                  05-07-2023, 08:12 AM
                • jason123
                  Sony STR-DN1050 - No video, no BT, No WIFI, and FM is not changing stations
                  by jason123
                  Hello folks,
                  New to Audio equipment - I got this receiver, I connected speakers and I tried to connect to Bluetooth. My phone would not see the receiver (Receiver flashes the BT as if it's trying to pair). Then I put it on FM radio, I get white noise on the speakers. I click the +/- Tuner button, and it moves from saved station 1 through 28, but the frequency is 87.x MHz not changing. At this point, thinking I may need to do a FW upgrade, I connected an HDMI cable to the TV and TV reports "No Signal" - TV "Kind of" sees the receiver (When connected to greyed out port,...
                  05-27-2025, 07:26 AM
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
                  HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 1000 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                  09-06-2024, 06:20 AM
