Power button on Behringer Xenyx 1204USB mixer dead ?
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 335
    • D12
    Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
    I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
    • Jul 2011
    • 6070
    Re: Power button on mixer dead ?
    It depends on the configuration of the switch and what it controlling
    • redwire
      • 3912
      It's not a problem with the power switch, that is all or none for power. Some power is present if the phantom red LED is on, so the switch is not to blame.
      Your electronic expert friend would have to take it apart to find the problem.
      • Thermaltake
        Brain badcap
        • Aug 2015
        • 335
        • D12
        Re: Power button on Behringer Xenyx 1204USB mixer dead ?
        He fixed it. Told me that secondary power unit on power supply died.
        • Thermaltake
          Brain badcap
          • Aug 2015
          • 335
          • D12
          Oh forgot to say thanks for the schematics.
          Still can't figure out where that secondary power unit is I am looking at open power supply.
          P.S
          A year ago we changed all caps on the power supply there were a lot of trashy caps on it. Second picture is with all new caps. I use only rubycon, nichicon and nippon caps.
          • spiros.p
            • Dec 2020
            • 89
            • Greece
            same psu as qx1622 i own .the psu gets very hot during operation.and the crap caps died slowly take other components with it.i recap with quality brands dril some extra holes to the case for good ventilation and the psu runs cooler and sounds better.under the board is clearly separated the primary and secondary side.
            • Thermaltake
              Brain badcap
              • Aug 2015
              • 335
              • D12
              It wasn't the caps, caps are ok. I replaced them last year with all new caps and high quality ones(Nippon, rubycon, nichicon) as you can see on the second picture in my previous post. But something other on PSU died.
              Can you take a picture where did you drill that holes if it's not a problem. I also notice that section where the PSU is, is getting hottish but I thought that holes where the faders are and that side holes on the metal case are enough for it to cool.
              • spiros.p
                • Dec 2020
                • 89
                • Greece
                just drill front the metal unter the rount plastik 8 to 10 mm holes.and few left and right from the existing holes on booth sides.from inside you can glue some moschito net to prevent come inside smal insects.my behry mixer is not on my place right now.with multimeter check the secondary components carefuly.first make sure you have power to the big capacitor.take care there is danger voltage.check ic2 and all diodes.and the 3 transistors.some members here may have more sugestions.
                • lti
                  • May 2011
                  • 2557
                  There's a 7805 and two transistors on the heatsink in the second picture, so it looks like they're using linear regulators after a switching power supply. Those regulators might be the "secondary power unit," and it would explain why it runs so hot. It's just a cheap way of making a multi-output regulated power supply (and it filters ripple a little, but a decent modern power supply shouldn't need linear regulators for filtering in audio equipment).
                  • Thermaltake
                    Brain badcap
                    • Aug 2015
                    • 335
                    • D12
                    Ha, I am not much into it. But I get what you are saying approximately.
                    I was wondering maybe it went down just because I switch both buttons at the same time few times....
                    • Thermaltake
                      Brain badcap
                      • Aug 2015
                      • 335
                      • D12
                      Hi, I forgot to inform. Friend fixed the PSU, he told me secondary part on PSU died and he fix it. Now mixer is working again
                      • themosttogain
                        HP Envy 13-BA1565na with intermittent power button
                        by themosttogain
                        Hope someone can give me some suggestions on this because i'm at my wits end with it...
                        I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                        Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                        07-12-2024, 03:03 AM
                      • TimeRabbit07
                        Asus FX517ZC charges but power button does nothing
                        by TimeRabbit07
                        Hi all!
                        I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
                        Here are its various numbers and identifiers:
                        Model short: FX517Z
                        Model long: FX517ZC-HN114W
                        SN: NANRCX01S57842E
                        CN: 3SDB 12M
                        MFD: 2022-10
                        Motherboard model: DA0NJLMBAE0 REV E
                        Symptoms:
                        The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
                        History so far:
                        The...
                        09-04-2024, 05:48 PM
                      • Andreasbest
                        Dell Latitude 7410 dead and amber light as long power button is pressed.
                        by Andreasbest
                        Hello.
                        I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
                        Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
                        Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
                        Fact #3 i tried hard reset with cmos/main battery disconnected and power...
                        12-21-2024, 02:02 PM
                      • reessi
                        Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                        by reessi
                        With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                        No corrosion any where!
                        Tried a replacement power button off ebay and the same.
                        Very occasionally it will work with the power button connected!
                        Same results with or without the battery.
                        Can it be a fault with the Audio board or the mainboard?
                        The touch Id assembly connects through the Audio board first then to the Mainboard.
                        Flex...
                        06-26-2024, 03:31 PM
