Recapping a Cerwin Vega Crossover help
  • Sinnyone
    • Feb 2022
    • 12
    I have included a few pics of the caps on my crossovers on a pair of Cerwin Vega 311p speakers. They are well over 40 years old, so I thought new caps might help with their sound, and would be fun also. So, I have attached pics of the caps, but was wondering. Is it better to replace the caps, what caps would be best, and should I just buy a new crossover at parts express or something like that. The problem wikth buying a whole new crossover is i dont know where these particular speaker drivers fall off or which crossover to get. Im good at electrical work and soldering so no problem there. Anyway, what do you guys think. And, can you make heads or tails of the capacitors. The boards are not the same in each speaker. One has two inductors while the other crossover has only one inductor. Its weird. Below is a link to all the pics of the boards and components. Any advice, hints, suggestions, ideas. Give it all to me. Thanks
    jim
    https://imgur.com/a/53T54Wv
  • redwire
    • 3906
    Re: Recapping a Cerwin Vega Crossover help
    I see a 1.5uF 200VDC and 3.5uF film capacitors, and another small one underneath, and some others as well.
    Those caps look fine and if they test reasonable, I would leave them alone. If they were bi-polar electrolytics then I would replace them as they are crap for fidelity and aging. There are many audiophile boutique film caps that I don't feel are worth the money, they'll sound the same. Dayton Audio appear to be low cost chinese capacitors. I use Solen.
    You can change the inductors from ferrite to air-core for a bit less distortion. Solen is in Canada but Parts Express carries them.
    Problem is measuring the old parts you need an inductance meter or the wrong values will upset the crossover points.
    Passive crossovers are a pain to work with, parts love to rattle and buzz and fitting larger parts is no joy.
    • Sinnyone
      • Feb 2022
      • 12
        AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
        The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
        10-01-2024, 01:07 PM
        ASUS D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR Notebook Specification for Upgrade or Repair
        This specification for the ASUS D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR boardview and D515DA R7-3700U, 15.6" FHD vIPS, 512GB SSD, 8GB RAM, VEGA 10, W10H, 1YR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
        09-06-2024, 10:50 PM
      • proxneo
        Recapping Sony ICF-SW55 - verifying cap values
        by proxneo
        Dear reader
        I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
        At the moment, I have selected replacements based on the following list of values:
        3 x 470uF 10VDC
        3 x 4.7uF 35VDC
        4 x 47uF 50VDC
        8 x 22uF 6.3 VDC
        1 x 220uF 6.3VDC
        5 x 100uF 6.3VDC
        Which...
        06-21-2023, 12:38 AM
      • odtech
        Gigabyte RX Vega 56 8Gig component ID help
        by odtech
        So I have this Gigabyte RX Vega 56 8Gig that has a open capacitor near the VRM's. The capacitor is visibly damaged. It seems the schematic and boardview for it is not available.
        Does someone happen to have one to check the capacitance of that cap?
        C708 as in the picture. Unfortunaly the original backplate with the stickers on is not with the card so I can't tell the exact model....
        04-16-2025, 05:18 PM
      • PennyLane
        Trying to locate a capacitor for a Skytec Crossover filter
        by PennyLane
        Hi
        I'm trying to locate what i believe to be Radial Electrolytic Capacitors 100v 82uf Non-polar for a Skytec Crossover filter.
        02-19-2025, 06:47 AM
