AS1100 , Yamaha amp , schematic please to identify component
  • zen
    • 511
    Hi all
    Repairing the RIGHT channel output board .
    Replaced the 2 output devices & now working through circuitry .
    Discovered D130 ( S202 ) measuring O/C , but suspect there may be something special about it , as same diode on LEFT channel board is measuring 900 one way & 600 the other , on diode setting .
  • zen
    • 511
    Re: AS1100 , Yamaha amp , schematic please to identify component
    It's a Current regulative diode , type S-202T , manufactured by Semitec .
    Yamaha part number ZE906900
    • redwire
      • 3912
      I would say it has gone open-circuit.
      S-202T is a current-regulator diode (basically a JFET) 100V 2mA rated.
      So I would expect a diode-drop in one polarity and low resistance sorta constant current in the other direction. It depends on your multimeter how much current it passes on diode-test.
      The datasheet doesn't shows forward direction it needs at least 1.7V-2.3V to begin regulating (pinch off). Internally the gate and source are tied together to make a 2-pin part.
      • zen
        • 511
        Thanks for the additional info
        Have ordered one just in case .
        • zen
          • 511
          Can confirm after receiving a new diode that previous reading mentioned is correct for this type of device .
          • zen
            • 511
            Rebuilt Right channel , but still not powering .
            Only yellow LED flashing , with no AC being released to mains transformer , due to protection relay not clicking over .
            • zen
              • 511
              Trying to isolate this down , but not easy .
              Pulled out power board & linked out relay contact , allowing supply to main transformer .
              I increased AC supply gradually using Variac .
              Right channel heat sink became fairly warm , & slightly hot .
              Disconnected Right channel audio board & tried again , to see if unit would power , but no .
              Suspect still an issue somewhere on Right channel ,& due to protection circuitry being very sensitive , won't allow me to power the amp with just left .
              Doesn't help that someone else has worked on this before me .
              • debidoobs
                Yamaha delay D1500, zener diode broken with no marking
                by debidoobs
                im actually trying to save a d1500 delay from yamaha. I found the service manual but schematic is missing and BOM list is a bit unclear as components listed have no reference linked to the pcbs... In my case, one zener diode was broken (114 code on the pcb in attached file) and couldn't be repaired : it was a zener type package. In the BOM list i found 3 reference on this board : 1S555 (can be replaced by 1N4148), RD4.7EB2 (approx 5v rectifier), RD7.5EB3 (approx 7v rectifier)...
                Actually the cathode goes to VCC of sram M5M5118P, without this diode missing, i have...
                04-24-2024, 09:01 AM
              • hobostove
                Corsair RM1000e - Help identify 5VSB Zener diode
                by hobostove
                Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                There's a 22ohm resistor that's melted and open, but it still has the bands.
                The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                It looks like the diode connects the source and drain of a TNY284...
                03-27-2025, 02:25 PM
              • dj8452000
                How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                by dj8452000
                I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                02-18-2025, 08:28 AM
              • eccerr0r
                old X58 triple channel board... memtest86 memory speed?
                by eccerr0r
                Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                06-28-2025, 09:06 AM
              • jjne
                AUO M270QAN01 - identify diode?
                by jjne
                I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
                Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
                ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
                01-24-2024, 08:39 PM
