debug bang and olufsen beomaster 3300 amp model: 2953
  • miketurbo
    • Nov 2021
    • 6
    greetings from Westport CT.
    I have recently purchased a circa 1986 beosystem 3300.
    it worked gloriously for a few hours. then no sound and smell of burnt electronics from the beomaster 3300 amp model: 2953
    attached is a bit of the schematic, I have the full pdf schematic if needed.
    all, functions aside from sound output seem to still work on the unit. (cd/tape/phono change, display volume display, remote control, radio station, on off etc.
    I'm pretty sure the smell was from resistor edit[r122] burning up. (see picture)
    I will replace the resistor, but It seems like this is a symptom of something else.
    lots of questions:
    1) what would cause this, excess current? from where?
    should I replace:
    2) any of the capacitors?
    but how do I know which ones? (none of them are swollen)
    how do you test capacitors while they are in a circuit?
    3) the amplifier IC chip?
    could this be why the resistor burned up?
    4) should I replace the adjacent resistors (207, 206) ? they measure fine with
    the multimeter but they look a bit singed, are they compromised?
    any help is appreciated!
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: debug bang and olufsen beomaster 3300 amp model: 2953
    hmm... actually after second inspection, seems the design differs from the reference design. Hope that's not the reason why the resistor fried...
    • miketurbo
      • Nov 2021
      • 6
      @eccerr0r
      I'm not great at reading/understanding the schematics TBH
      here is the full document if that can help.
      https://beomanuals.com/manuals/Beoma...ice-Manual.pdf
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Kind of weird it worked for a few hours, no magic smoke for the first few hours at all?
        Wonder if it's worth to experiment with just replacing that 100Ω resistor. Past that, seems something wrong with either design or the STK chip...
        • petehall347
          • Jan 2015
          • 4440
          looks like the resistor decided to be a fuse ..there is a short in the output amplifier .
          the manual is really badly copied making it just about impossible to follow it .
          is it a hybrid amp ?
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            I hate STK chip designs...a lot of troubleshooting could end up with "replace STK chip" and not much else you can do about it.
            Looks like B&O just tried to put minimal information on the schematic. As far as I can tell there must be another R205-R208 and associated cap and it's not shown. For curiosity, could you take a picture of the whole board?
            BTW what wattage speakers are you using, how loud are you using them? Not sure if this is the problem, but still think it might be a design defect somehow...
            • petehall347
              • Jan 2015
              • 4440
              • miketurbo
                • Nov 2021
                • 6
                @eccerr0r,
                it sounds like I should replace the STK IC, as well as the blown resistor.
                @petehall347, is it a hybrid (I just looked this up)... it does not have tubes if that is what hybrid amp means...?
                thank you!
                here are some more pictures
                • petehall347
                  • Jan 2015
                  • 4440
                  yes that stk module i meant as hybrid ..
                  its probably shorted internally .
                  now i am confused looking at a datasheet ... maybe the V makes it different ... https://html.alldatasheet.com/html-p...1/STK4151.html
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Yes the V does make it different than X... think the X and the GS are close enough to be equivalent afaik...
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Ah yes I think I see it now, yes there are two sets as I thought. Schematic is confusing.
                      BTW, if you want to try to swap out the 100Ω resistor you should, and see if it works once more, at least temporarily. If it works then you may or may not want to try a small mod to see if it will make it last longer: make it like the reference design.
                      Take a picture of the foil side, might be some surgery needed, have to plan this out...
                        • 31218
                        might want to check those red capacitors in the 1950's style plastic cans too
                        • miketurbo
                          • Nov 2021
                          • 6
                          I swapped out the resistor... no dice
                          I guess the amp chip next?
                          here is a picture of the back before replacing the resistor
                          • miketurbo
                            • Nov 2021
                            • 6
                            ok thank you I will start with these.
                            I just ordered a capacitor tester, I guess you need to pull each one to test properly (?, or use an ESR meter... probably beyond my ability at this point TBH)
                            I've only every known a capacitor was bad by looking at it.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Just make sure the capacitors are not shorted - do not worry about ESR at this point (or for this issue, actually). A simple ohmmeter is sufficient, though you may need to remove them to ensure you're not getting false paths.
                              TBH I don't think they're shorted, and kind of doubt any shorted capacitor could explain this behavior. A shorted STK module could...
                              BTW what is the behavior of the new 100Ω resistor? Does it fry right away or is it DOA?
                              Actually one test that may show some more information: With the DUT off and the 100Ω R122 removed or destroyed, what's the resistance between pins 4 and 7 of the STK module? Make measurements in both directions. Then with the DUT on, what's the voltage at pin 4 and at pin 7 with respect to GND?
                                HP Pro Pro 3300 SFF Pro 3300 G850 Specification for Upgrade or Repair
                                This specification for the HP Pro Pro 3300 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Pro 3300 SFF boardview and Pro Pro 3300 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                09-12-2024, 03:44 PM
                              • ZOrd_Z
                                Bang & Olufsen Beovision Horizon always in standby.
                                by ZOrd_Z
                                I every one!!
                                I have a Bang & Olufsen Beovision Horizon that is always in standby mode ( green light on ).
                                Main board is 715g7132-m0h-000-005k. Corrupted firmware? I have all the ok voltages in psu.
                                Any idea?
                                Thank's...
                                12-12-2024, 11:44 AM
                                DELL Latitude 3300 Notebook 3000 Specification for Upgrade or Repair
                                This specification for the DELL Latitude 3300 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3300 boardview and 3300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3300...
                                09-06-2024, 02:34 PM
                                09-06-2024, 12:30 PM
