Denon avr-x2000 no sound on main zone
  • budwich
    • Jul 2015
    • 3097
    Re: Denon avr-x2000 no sound on main zone
    no confusion, just wanted to be sure of the timeframes and actions. You might consider redoing the update process.
    • gvse
      • Jan 2021
      • 12
      Here is the current summary:
      1. Analog audio: (direct or any other mode) - no sound on main zone. Zone 2 good.
      2. HDMI: All ports works for video. The audio doesn't work irrespective of AVR or TV. Tried with 2 different hdmi sources and same results.
      3. Network player: Works only on zone 2.
      4. Tuner: Works only on zone 2.
      5. OPT1: No sound
      6. GUI: Works intermittently.
      Running through all the paths, especially analog pass through and hdmi with TV audio .. both take completely different paths and both do not work. Wondering if there is some sort of muting that is happening because of a DSP or some other issue ?
      • budwich
        • Jul 2015
        • 3097
        AND, your test tones don't work... :-).... :-(
        • Gumboil
          • Jun 2025
          • South Africa
          Check if the small rectangular voltage regulators on top of the the HDMI board (U3601-U3605, EX3AV written on top) are OK. Each is responsible for an essential voltage for the HDMI chipset. See service manual p.142.
          Im going to revive this, seems more info and replies on this one than on mine. Anyway...I pray someone cane help me to get me receiver back up and running. Same model as OP, only thing is, I have no sound on any channel, even direct does not work. I have done this as well, and is within spec as per the service manual. My GUI also seems to be a bit off, a bit lazy if I can say that. Wierd thing is, when accessing the menu, on the display on the reciever goes dim, but only when selecting certain sub menus or items. If I go back to the sub menu above that it foes to normal brightness again. Any advice would be appreciated pls.
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
          • dansity
            Denon AVR 1912 no sound
            by dansity
            As a foreword I'm relatively novice with component level audio gear repair. My amplifier stopped producing sound and I currently have no funds to buy a new one so I need any help to repair it. I know "no sound" is one of the most common problem but there were other symptoms so some of you seasoned repairman might able to pinpoint the stuff I have to check. I did download the service manual from manualslib the "no sound checklist" is a bit intimidating.
            So i bought it working. First symptom: speaker protection relays on the audio board were clicking...
            05-06-2024, 10:16 AM
          • Gumboil
            Denon AVR-X2000 no sound
            by Gumboil
            Good day all
            My first post on the forum, tried to find a introduction page, but couldnt. So thank you for having me here.
            After spending most of the past 2 days Googling and watching Youtube videos, I came across the forum, in the hopes that I could get some assistance with the above mentioned amplifier. As I do most days, I switched the unit on yesterday morning, got the relay clicks as per normal, but no sound from any of the speakers. Tried "Audio Direct' and the same issues there. In a panic state, I did a factory reset, without any luck. Then disconnected all...
            06-08-2025, 02:43 PM
          • Z2yzx
            Denon AVR S720W Main Speaker no output.
            by Z2yzx
            Hi everyone!
            Does anyone out there have any insight as to why my AVR will not output sound through main speakers or head phones?
            Here is the info:
            Unit powers up normal
            Relays click
            Zone 2 works fine 100% of the time.
            Main Zone sometimes works fine like .05% of the time.
            Sometimes I can plug headphones and hear scratching sound via the headphones. Once that happens I can unplug the headphones and the main speaker zone works fine.
            is there something I can inspect?
            I have somewhat moderate skills with electronics....
            12-19-2023, 01:34 PM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
