Dynaudio focus 400xd schematic & help please
  • zen
    • 511
    Hi all
    With mains applied , i can hear 1 relay click , then a second or so later a second click .
    3.3 volt supplies stable .
    The 36 volts supply rises , then falls away , after second relay click .
    Cannot find any faulty electrolytic capacitors .
    Also spent ages removing that glue manufacturers like to use , that becomes hard & corrosive .
    No obvious short circuit reading .
  • zen
    • 511
    Re: Dynaudio focus 400xd schematic & help please
    Strange that 2 speakers have failed , with exactly same symptoms .
    Must be a common cause .
    These speakers even have a USB port for upgrading .
    • Khron
      • Sep 2006
      • 1350
      • Finland
      That's not a whole lot to go on, though.
      I see a TNY___ chip there, with a small transformer next to it; is that some "stand-by" supply? Do these speakers have some sort of idle-timeout or auto-off/on features?
      But all(?) the electrolytics seem to be Ltec. I believe only Delta, by whatever unholy voodoo magic they do, manage to make them last as long(?) as Japanese capacitors, in their own power supplies.
      "That glue manufacturers like to use"? You mean the dark-cheese / tan coloured one? Was any of that used in here? I'd find it odd, since they used that white silicone / RTV on the top of the power supply...
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • zen
        • 511
        Hello Khron .
        PSU seems good & yes standby supply present.The TNY chip seems to be for that part of circuitry .
        The glue i refer to starts off a white colour i suspect , then due to heat , turns a crispy brown corrosive substance .
        Very common on many active speakers i have worked on . Really surprised all the electrolytic capacitors check out good .
        • zen
          • 511
          Finally customer dropped off remote for the speakers .
          Turns out they were both in standby .
          Remote had battery leakage on contacts .
          Cleaned up & tested .
          • jm1234
            9V relay temperature 40C
            by jm1234
            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
            05-09-2024, 03:03 AM
          • TinkerTron
            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
            by TinkerTron
            Hey everyone,
            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
            Instead, here's what's been bugging me so far:
            The schematic...
            03-06-2025, 02:03 PM
          • atunguyd
            Acer x163w Monitor PSU schematic
            by atunguyd
            Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
            The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
            03-05-2025, 02:08 PM
            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
            by sam_sam_sam
            I was working on this CNC machine today found no keyboard functioning no control relay powering on
            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
            Found shorted diodes on main controller relays there are 3 of them that...
            01-07-2023, 05:43 PM
          • Thetechdude
            MSI Ventus RTX 4080 16G Broadview schematic needed
            by Thetechdude
            Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
            I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
            Thanks.
            07-15-2025, 11:15 AM
