Brightening NAD 502 CD player's LED display?
  • JimBanville
    • Aug 2020
    • 118
    I'm a struggling amateur when it comes to electronics. I did successfully replace the burnt out incandescent bulbs in my NAD502 CD player with two LEDs (3V 20mA) in series with a 1K resistor.
    I wanted it to be brighter (twice as bright?) and with a more even light across the display (the edges were dim). I thought of adding more LED's, so I wired SIX of these LED's in series with the same 1K resistor. The light is more even, but the brightness seemed to have dropped quite a bit.
    The factory incandescent bulbs were 16V, 65mA. It appears these bulbs were wired in parallel, so there were four contact point for the two bulbs. I wired my series of LED's across just two of those points.
    Advice? THANKS!
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Brightening NAD 502 CD player's LED display?
    Even a single string of five-in-series should get you MUCH brighter results. But you will need a much lower value resistor (68 ohms for about 15mA through the string of LEDs).
    Or a string of four in series with a 270 (or even 220) ohm resistor. If that's still not enough, go with two parallel strings of 4 or 5 in series.
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • 31111
      you would be better putting a proper led backlight optics assembly in it.
      i have seen on ebay the plastic assembly's with a single white led that gives even light.
      you probably need to trim the size down though.
      got any photo's of the display from the rear?
      • Pipolups
        Corsair K70 LUX RGB dying LEDs
        by Pipolups
        Hi there !
        I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
        Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
        10-08-2024, 11:58 AM
      • THE GTC
        Insignia NS-37D20SNA14 intermittent LEDs
        by THE GTC
        So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
        When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
        11-03-2020, 02:40 AM
      • VitalComputing
        Replacing Mode Indicator LEDs
        by VitalComputing
        I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
        I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
        I thought I could just put a resistor...
        09-17-2023, 04:43 PM
      • jimbofz
        just a quick question do all qled leds appear blue when fault finding ?
        by jimbofz
        i have replaced many leds strips that have changed blue when they are worn
        and the new replacements are perfect white
        but when fault finding do quantum leds always look blue?
        08-28-2024, 06:51 AM
      • Quantum IC
        LEDs for TV Backligth
        by Quantum IC
        Hello everyone
        I'm new to LED strip LED replacement.
        The original LED comes with a single internal LED or chip. I only get at the moment LEDs with two internal LEDs or chips.
        I understand that this is due to the tone of the light they emit.
        My Doubt is:
        Can I use the LED with two internal chips without problem?
        Will there be much difference in the picture?
        I'm going to replace all the LEDs.
        Both LEDs (original and replacement) are 3V and the same size....
        03-04-2022, 04:03 PM
