car amplifier strange short on main 12V
  • disorder
    • Sep 2015
    • 156
    • france
    hello,
    i have on issue that i don't understand on a car amplifier
    i have a short between positiv 12V and ground but during 3 seconds then the resistance rise , and if i change black and red probes i have short too , same rising.
    put on 12V power il have 12V line stable, i consume some amp and then 0amps. the led not shine and no other line is open. mosfets on first stage have 12V on middle pin and ZERO volt on other pins.
    can you give me some tricks ?
    thx
  • petehall347
    • Jan 2015
    • 4427
    Re: car amplifier strange short on main 12V
    its capacitors charging up .that is normal
    • disorder
      • Sep 2015
      • 156
      • france
      ok, now after this test with power supply, the short is gone.
      the amp stay with green light
      what the hell is that !!!??
      • petehall347
        • Jan 2015
        • 4427
        post some pictures and tell us make and model and actual fault
        • disorder
          • Sep 2015
          • 156
          • france
          hello
          some news, i don't know why but now the amp start normally, no short, no protection mode
          but i have left outpout doesn't work ; i have the sound only if i put the volume really high but the outpout volume is low.
          right outpout works normally
          i will try to check this line...
          i have to do some research on google to find how to test that
          • petehall347
            • Jan 2015
            • 4427
            swap inputs see what happens
