Yahama RX-V1400RDS in 30 seconds Standby repair
  • samtron786
    • Aug 2016
    • 161
    • germany
    Yamaha RX-V1400RDS (titan) THX Select Receiver with 7 power amplifiers and room acoustic analysis / equalizer
    After being switched on, the device jumps to standby for approx. 30 seconds and does not work anymore and you have to switch it on again and after 30 seconds the same problem
    thank you
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8179
    Re: Yahama RX-V1400RDS in 30 seconds Standby repair
    I think you have to explain your problem in much better detail. Did you try different output modes, or other settings? Does it display an error message? etc.
    • samtron786
      • Aug 2016
      • 161
      • germany
      Hello.
      I have a Yamaha RX-V 1400RDS here, the receiver is about 5 years old.
      The receiver can no longer be switched on.
      At first it started after being disconnected from the network and then ran for hours.
      Now it can no longer be switched on.
      The device never got too hot.
      He was often on standby for a long time.
      • samtron786
        • Aug 2016
        • 161
        • germany
        nobody can help me?
        Thank you
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8179
          is it totally off or stuck in standby mode?
          • samtron786
            • Aug 2016
            • 161
            • germany
            The following error pattern:
            After switching on via the power / stby button at the front, relay R371 clicks, the display goes on and after 1-2 seconds it goes off again with another click of the relay.
            The process can be repeated over and over, nothing changes. During the time the display is briefly on, you can change settings such as volume etc.
            Nothing is connected to the device and the inside is cleaned.
            • wazzadj@hotmail.com
              Wazza
              • Nov 2017
              • 57
              Its sounds like a Output transistor is Bad or a leaking Monolythic cap on the power supply board which is separate from the main board look at the relay their are two caps their the one that runs off the relay line is leaking
              22nf from memory I don't have the schematic in front of me
              I work on these units all the time and its one of 3 things
              the other problem is the Bios chip on the Digital board can go corrupt
              check the standby circuit is getting a 3.3vdc pulse when you push the power button
              check the relay at the power supply is seeing the 2.3v signal
              • re-atari
                Denon AVR-X2000 mainboard caps bulging
                by re-atari
                I have been using a Denon AVR-X2000 receiver in my living room for several years now, works perfectly, am very pleased with it. Recently I acquired another one, advertised as defective with flashing red led a few seconds after switching on. Picked it up to try repair and use in hobby room. After switching on, the on/off indicator led indeed initially flashes green for about 2 seconds, during which the display is visible, and then starts flashing red (at 2Hz) with a switched off display.
                I'm afraid the service manual is too large to upload here (55Mb), it can be found at https:/...
                09-23-2020, 10:37 AM
              • truztruz
                TV "BLAUPUNKT"32/122I-GB-5B-HBKU-EU - ok standby - blue led on for a few seconds
                by truztruz
                Hello to all,
                I'm trying to repair a TV model "BLAUPUNKT" 32 / 122I-GB-5B-HBKU-EU with mainboard TP.MSD309.BP75.
                Red standby is present.
                By pressing the power button, the blue led lights up for several seconds (about 6 seconds) but no sign of TV life (no backlight and no video signal on the panel (verified with a flashlight)
                The LED then returns to red and then returns to blue and so on (the flashing is not fast, but as mentioned, several seconds pass between red and blue)
                I measured the voltage on the main output...
                12-01-2021, 04:19 PM
              • Scoff
                LG55UB850V no picture or audio - flashing LED's help please?
                by Scoff
                Hi, I'm looking for some help with attempting to troubleshoot and hopefully repair my trusty LG55" TV.
                I'm reasonably comfortable working with electronics, but far from expert level! I have more experience with auto-electrics than anything.
                We recently had a power cut while the TV was on, and since then, when the TV is switched on at the wall, the red standby light comes on like normal. Then. when you press the power button on the remote or the TV to switch it on from standby, the standby light flashes 3 times and then goes out. There is no audio or video at...
                01-26-2022, 06:13 AM
              • zklgfs
                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                by zklgfs
                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                08-11-2025, 02:14 PM
              • twonk9098
                Lenovo Legion 5 high fan spin turns off after 34 seconds
                by twonk9098
                I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                I have tried a few new bios but exactly...
                07-14-2024, 11:19 AM
