Teac AG-D9260 AV Receiver Audio Problem
  • PapaFi
    • Aug 2019
    • 20
    • Philippines
    After turning ON the unit, as the 2nd relay clicks. No audio response even radio or from dvd player. During vol adj from remote/manual adj as the vol increased there's a loud "tic" sound from the speaker. Even up to max vol still no audio. As you played the adj +/- from remote/manual along with the loud "tic" sound. All of a sudden the audio turned ON but uncontrolled vol even +/- adj. looks the audio is stuck on its level of vol. Even max/min audio level is the same (but the "tic" sound still there as the adj from min to max and vice versa and of course as you reached the 0 level no audio ). Again, the audio is gone once you tried to adj the vol no matter +/-. Putting to DTS and Pro logic 5.1 the audio is blurry and very low and same as the problem and symptoms from above. I need your expert ideas on this. thanks very much in advance...God bless.
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
  • falcontech
    MOTU TRAVELER MK3 AUDIO PROBLEM
    by falcontech
    Good Afternoon
    I have a problem with this MOTU audio card, a traveler MK3, the connection to the computer is via firewire, the card is recognized by the computer (both mac and win) but I have no audio output, on the front there are a series of LEDs including the clock (44.1, 48, etc.) and that LED at the time of connection usually remains fixed telling me the clock frequency set on the computer, now at every start the LED in question remains flashing in most cases, sometimes it becomes fixed, other times it disappears, without any sign of operation, I exclude problems with the firewire chip,...
    01-24-2025, 08:47 AM
  • Gibon378
    Problem with stopping audio and video for no reason
    by Gibon378
    PC Specs:
    • CPU: Ryzen 5 1600
    • GPU: GTX 1080 Palit JetStream
    • MOBO: ASRock ab350 PRO4
    • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
    • PSU: XFX 650W (don't remember what model)
    • OS SSD: ADATA SP920
    • OS: Windows 10 21H2
    Problem description:
    Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
    11-19-2022, 09:41 AM
  • CDNBrewer
    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
    by CDNBrewer
    Hello Everyone,
    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
    Symptoms:
    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
    • I swapped the Left and Right surround
    08-05-2025, 09:29 PM
  • Cornito
    Denon AVR-2700H audio stops while receiver still works
    by Cornito
    Hello team,
    I've got a new issue with a Denon Avr-2700H.
    After several minutes working, receiver stops playing sound with a poc eared in the speakers.
    Receiver still work and display video with error message on display.
    Seems to me that is the main output relay.
    I'm looking for the service manual that I can't find for the moment.
    Does somebody have it?
    Regards...
    08-03-2025, 06:10 AM
