Short cirucit across UART chip legs.
  • Califauna
    • Jul 2020
    • 28
    • Spain
    Hi all. First post here.
    I have an EKS XP10 midi controller with a Burr Brown DAC. When plugging in the controller it isn't being recognised by Windows. I have two more of the same controllers. Only this one has this problem.
    I have looked and found that two of the legs on the UART chip, at the bottom of the picture, are shorted. These are not shorted on the good boards I have. It's possible to see a little metal exposed under there between the legs. Not sure why as I didn't think there should be track there.
    What's the recommended fix for this? Snipping one of the legs if its not used? Lifting up the flat part of one of the legs so it doesn't touch the metal there? Scratching between the legs so the metal there is cut?
    If this helps, the device hardware ID is the following:
    (Without a driver installed)
    Burr-Brown USB Audio Codec 2702 (commercial 2.8.45)
    USB\VID_08BB&PID_2702&REV_0100
    (with a Driver installed)
    AudioDevice on USB Bus 2.8.45
    MEDIA\PGUSBMM3ADAPTER\9&2094A6B5&0&ID01
    Thanks in advance for any help with this repair.
    • 31044
    Re: Short cirucit across UART chip legs.
    that looks intentional - like a track.
    what is this shit that has all the numbers sanded-off anyway?
    i discourage people from ever buying from company's that play those games!
      Agree with sti, that is a copper trace of the circuit.
      The working board has the same PCB P/N and revision?
      • Califauna
        • Jul 2020
        • 28
        • Spain
        The Boards all say 'EKS XP10 V1.14' on the component side and on the other side:
        STD-1
        94V-0
        4405
        • Califauna
          • Jul 2020
          • 28
          • Spain
          Photo of chip(didn't work when trying to add as an image):
          https://drive.google.com/file/d/1ipd...ew?usp=sharing
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • Stephen
            MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
            by Stephen
            I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
            02-06-2025, 12:03 PM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • aaronkatrini
            Help me find the short circuit on this WORKING Nvidia GTX1650
            by aaronkatrini
            Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
            Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
            04-18-2024, 03:15 PM
          • Geeker007
            9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
            by Geeker007
            Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
            I am new to electronics repair, so my queries could be naive but I am ready to learn.
            So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
            01-28-2025, 03:31 PM
