Numark NS6 Usb problem
  • falcontech
    • Oct 2013
    • 470
    • italy
    #41
    Re: Numark NS6 Usb problem
    I wait for the chip to arrive and let you know
    • falcontech
      • Oct 2013
      • 470
      • italy
      #42
      the atmega162 chip will arrive to me on wednesday, but i still haven't been able to find the firmware, can someone help me?
      • falcontech
        • Oct 2013
        • 470
        • italy
        #43
        I tried to replace the atmega162 (despite not having the firmware yet) and now the program detects the chip via usbasp, I also tried to connect the card to the PC to see if there was any sign of life but nothing. Do you think there are other problems or is it only the lack of firmware that does not detect it from the computer?
          • 31011
          without firmware the chip will do nothing.
          • falcontech
            • Oct 2013
            • 470
            • italy
            #45
            a curiosity, if I tried to put the firmware of the numark NS6-2 (because that is downloadable), just to try, could I go back to its original once I have found it? Maybe I said bullshit but I would like to understand what happens
              • 31011
              you can write to the chip as many times as you like
              you need the fuse-bytes too - althou you can probaby work that out
              • falcontech
                • Oct 2013
                • 470
                • italy
                #47
                please take a look at the firmware of the ns6II, after downloading and extracting it, it gives me strange files, according to you which one should i use? they have no information and no extension I'm going crazy
                  • 31011
                  post it here.
                  and a sevice-manual / schematic if you can find one - to see if the chip is wired the same way.
                  • falcontech
                    • Oct 2013
                    • 470
                    • italy
                    #49
                    I can't find a service manual for ns6II
                      • 31011
                      well that's a windows exe, i cant and wont run that - if you managed to extract files from inside it then let me know.
                      i know it has an installer in it that tries to put a load of crap in the o.s. related to visual C.
                      • falcontech
                        • Oct 2013
                        • 470
                        • italy
                        #51
                        I extracted it but I don't see any firmware file, there are a series of files with no extension
                          • 31011
                          looking at the schematics again, there is no way on yours atleast that an upgrade could re-flash the atmel.
                          • falcontech
                            • Oct 2013
                            • 470
                            • italy
                            #53
                            What should I watch? I did not understand correctly, maybe I expressed myself wrong, I do not have the firmware of the ns6 and I wanted to try to load that of the ns6II but as you could see it is in a strange format, so I am facing a dead end
                              • 31011
                              i dont think that file has atmel code in it, just the firmware for the bigger main chip.
                              try to contact Numark again - the fact that they didnt say no means they may have just not got your message to the right department.
                              link them to this forum - publicity helps.
                              • falcontech
                                • Oct 2013
                                • 470
                                • italy
                                #55
                                the firmware must undoubtedly be loaded into the atmel chip, I don't know which other chip you are referring to, because the isp connector clearly says ISP ATMEL, so the firmware must be loaded into atmel, which chip are you referring to?
                                  • 31011
                                  if the firmware update runs in windows through the usb connector then it's not flashing the atmel,
                                  it's updating the Flashchip or the FPGA
                                  the only way to flash the atmel is with the programming header.
                                  • falcontech
                                    • Oct 2013
                                    • 470
                                    • italy
                                    #57
                                    so are you telling me that the firmware should not go inside atmel ??? and at this point why the controller is not detected by the computer?
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      #58
                                      The firmware goes inside the Atmel.
                                      The service schematic shows the USB port, but also J13 programming header is connected for this purpose.
                                      The thing is via USB is not possible without there already being a firmware on the device: i.e. you can update via USB, but not load the initial firmware that way.
                                      I extracted the firmware from the installer, but this does not look to be in Intel HEX format. (And also how do you know if the NS6-II model is even similar?)
                                      So it might be something proprietary, I don't really know.
                                      As stj said your best bet here might be to get some info from the manufacturer.
                                      Most likely the firmware is obfuscated, but maybe in that case they could sell you a preflashed new Atmel chip...
                                      • falcontech
                                        • Oct 2013
                                        • 470
                                        • italy
                                        #59
                                        Re: Problema Di Numark NS6 Usb
                                        what did you send me which controller it belongs to? yes I know that of the ns6II probably will not work I would just try to load it to see if at least it is detected by the pc
                                        • Per Hansson
                                          • Jul 2005
                                          • 5895
                                          • Sweden
                                          #60
                                          That is what they call the "XMOS firmware" in the above screenshot.
                                          -Whatever that is, don't ask me, I didn't design it
                                          That said it is of a size (24KB) which would be in the ballpark depending on used encoding format for the Atmega...
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                          • foshland
                                            DELL XPS 9560 Burned zone need photo please
                                            by foshland
                                            Hi to all, I have a XPS 9560 with some faults, im working on it for fun, I have a "burned" zone I need to dremel but afterwards ill need a photo of the zone for rebuilding as far as I can, I have the schematics and the boardview but will like a photo, if some of you can get any so I see the traces will be cool.
                                            It was some kind of lucky that the zone had not too much components, so I think I can deal with it.
                                            Its under the zone where PC308 PC309 and PC337 is located, next to PU300
                                            Thanks a lot for all and "pray" for me ...
                                            04-21-2022, 07:33 PM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
                                          • Gibon378
                                            Problem with stopping audio and video for no reason
                                            by Gibon378
                                            PC Specs:
                                            • CPU: Ryzen 5 1600
                                            • GPU: GTX 1080 Palit JetStream
                                            • MOBO: ASRock ab350 PRO4
                                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                            • PSU: XFX 650W (don't remember what model)
                                            • OS SSD: ADATA SP920
                                            • OS: Windows 10 21H2
                                            Problem description:
                                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                            11-19-2022, 09:41 AM
                                          • perzyk23
                                            Lenovo T580 - LCD Panel problem - error 0288
                                            by perzyk23
                                            Good morning,
                                            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                            10-25-2024, 12:42 AM
