Denon AVR-S710W Protect mode
  • ajvpb
    • Apr 2019
    • 13
    When you turn it on it will power up for a few seconds, then kicks off and the red light blinks 2x/sec.
    I fixed a Denon 4200W with the same problem which turned out to be shorted transistor on the amp.
    All transistors on the the 710 check out.
    Service manual is here: https://www.manualslib.com/manual/14...?page=2#manual
    On page 99 on the service manual, on the bottom right of the first diagram of the pcb, is a connector that has all of the protection mode feeds on it. I am getting 2.2V on the ampsig_det line.
    I am now out of my league as to how to trace whats causing this. If anyone has any experience or can point me to something obvious in the manual, I'd greatly appreciate it. I followed the flow chart on page 79 for protection mode based on the power amp, and everything checks out. The only part I can't verify is the last step that says power it on and check for an idling current.
    Thanks for any hints
    Alex
  • petehall347
    • Jan 2015
    • 4440
    Re: Denon AVR-S710W Protect mode
    basically you want to see ideally 0v on the amp outputs .you can measure this before the relay .
    as for idle bias its normally measured across an outputs emitter resistor .
    to comment further i need to see a schematic of the amp .
    try without loads connected to rule that out
    • madan1
      • Nov 2016
      • 719
      Service menu - page 20 - Special mode setting button (for AVR-S710W)
      2-1 Protection history display mode - page See page 44
      6 Protection Pass Mode - See page 49 ( do this only with current limiter )
      • ajvpb
        • Apr 2019
        • 13
        Yep, I checked protection history. 39 instances of dc protect. I'll get to the output voltages later when I get some time.
        • ajvpb
          • Apr 2019
          • 13
          Just to give an update in case someone comes along looking for a solution of their own....
          It ended up being the regulator board. Somehow I overlooked the two blown fuses on the board. Further investigation revealed someone had replaced one of the regulators on it. When they put it all back together they lost an insulating washer on the screw that holds the 7912 regulator to the chassis. The heatsink tab on the 7912 shorts to the input leg, so when it was screwed down it was shorting the 17 dc volts to ground, blowing the fuses.
          So, if all of your transistors are looking good but you're still getting a dc protect shutdown, make sure your other voltages are in order.
          • DynaxSC
            Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
            by DynaxSC
            I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
            I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
            Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
            Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
            05-04-2025, 12:08 PM
          • x16
            Lenovo Thinkpad T14 gen 1: Unlock MEC: in protect mode
            by x16
            i have Lenovo Thinkpad T14 gen 1 20S1 / SN: PF2M0XAG.
            I moved resistor like every time and read MEC chip with SVOD4. I unlocked 3 other mainboards successfully but this one could not read. SVOD 4 Software says: "MECxxxx series in protect mode, work mass erase only". Like in screenshot.
            What can i do?...
            11-14-2024, 01:31 PM
          • karatzdi
            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
            by karatzdi
            I know some might say... just buy another one. Sell it as parts..!
            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
            Spent some time downloading the Service...
            06-11-2024, 08:38 AM
          • Cornito
            DENON AVR-3313 / 3313CI Service Manual Version 6
            by Cornito
            Hello Team,
            I was working on a Receiver with no Power, and i found on a website the service manual that I share here....
            11-24-2024, 02:29 AM
          • BigOof
            Marantz SR5007 popping on volume change and mute in Direct Mode
            by BigOof
            I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
            12-12-2024, 06:15 AM
