Onkyo SKW-591 subwoofer is dead
  • tibimakai
    • Jan 2012
    • 3680
    Re: Onkyo SKW-591 subwoofer is dead
    The +/-12V components are visible like R912/D912/L912 same for the other side R911/D911/L911, C921/C922 are on the other side, but I can't see anything else.
    • R_J
      • 9515
      The 8C is the (NJM78L05) Q435 the other one that looks the same will be Q436 and have a 9C (NJM79L05)
      The only other thing I can think of that could cause that -12 to be high is that C912 is bad, as in almost open, find it and solder another 10µf/100v across it and see if the voltage comes down.
      D922 was showing .76V same as D921.
      that could be misleading as these are zener diodes and even though it checks ok could zener at a wrong voltage. But like I said if it did zener at -9 instead of -12 the supply from D912 would be lower, not higher.
      And the -12 being -9 might not effect the operation that much as it is only the supply for Q301, so it might effect the auto on function or the audio through q301.B might be a bit low or slightly destorted but should not stop the sub from working.
      • tibimakai
        • Jan 2012
        • 3680
        I have removed both C911/C912 and both show 10.2uF 0.42ESR, with the Chinese component tester.
        • R_J
          • 9515
          When you mesured those voltages, did you have audio going to the input? It might be that the voltages were off due to the state of the switching power supply, It was likely in standby.
          • tibimakai
            • Jan 2012
            • 3680
            It was in standby. I just plug it in and measure. I can hear a slight high voltage whistle coming on. Speaker is not connected either.
            • tibimakai
              • Jan 2012
              • 3680
              Unfortunately I don't have 10uF/100V capacitors, only lower voltage ones.
              • R_J
                • 9515
                With the sub in standby, only the switching power supply will be working and at a very low power, so those other voltages might be off. since none of the other circuits are drawing current, that cap may have charged to a higher voltage. once the sub is turned on I suspect it will drop and the -12v will be normal.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Found the 8C and 9C. These turn on only, when there is a signal right?
                  • R_J
                    • 9515
                    Not really, Its the transistor before the input to the regulators (q433/434) that turn on with signal and supply the regulator's input.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I'm about to throw in the towel. I don't even know from where to get the ground from, when I take measurements.
                      This thing is not worth $40.
                      Now I have 38V, at the speaker output.
                      At 7905 I have -4.99, but nothing at the 7805.
                      • R_J
                        • 9515
                        If you look at the schematic you will see where the ground is. That large black ground line that connects to q501 pin2. There seems to be only one voltage that does not use that ground, that is Q501 pin 12 vcc, It uses the minus of C503 or the minus of C902. If you follow the VCC (Q501,Pin12) it goes through R528, to VB Q901 (78M12) This 12 volt regulator has it's ground connected to -B so to measure THIS voltage you would just measure across C907.
                        If you used the normal ground to check this voltage it would not show correctly, it would likely show around -30 volts.
                        If you don't have VAA +5volts that will throw off the bias of the whole amp circuit so you will likely show a high voltage on the speaker terminals.
                        Again just look at the schematic, +40 comes to R433 and connects to Q433 emitter, this transistor acts like a switch, R435 should be low on the end opposite the transistor. If the transistor is turned on you should have ~10 volts on the input of Q435 and +5 on the output.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I can't find Q433 and R433.
                          I have removed 7805 and installed a regular big one in there. At the input I had 5V and at the output I had 4.3V. Something is not right, it should be higher the input voltage.
                          Course, I must of made a short because I blew up Q502.
                          I have decided to put back the original 7805, to compare the readings. I have ripped off the input trace, so the smd 7805 I had to solder in a bit crooked, to be able make contact each leg. Most likely that caused the short.
                          Tomorrow I will look into it, what happened. Before, the output it was 0V, so I'm guessing, that the original 7805 is open.
                          Can I diagnose this amp, without Q502 soldered in?
                          • R_J
                            • 9515
                            Yes you should be able to operate the sub with Q502, I suggested it in post #3
                            R433 should be there, I saw the[*] beside it and was'nt sure, but looking at the chart at the bottom of the schematic indicates it should be there and the value for different versions. 1.2k 2 watt will not be a small resistor. I wouldguess it is mounted on the other side of the board. It might be mounted closer to C901
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Oh wait, it's most likely a big resistor on the other side. Damn, I was just searching on the bottom. Thanks R_J.
                              Without Q502, how it will affect the speaker output? You know, when I want to check the output voltage.
                              • R_J
                                • 9515
                                You won't get any audio out but I suspect the speaker voltage should be near 0 volts, I could be wrong, It's hard to say how the ciruit will act but I can't see an issue.
                                The audio drive signal comes from pins 11 & 14 of Q501, so with out Q502 there will be no audio at the speaker.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Both R433/R434 are big resistors on the other side, and they have the right value.
                                  Q502 had a short between pins #14/15. I have replaced it.
                                  I have placed an order, for new amp ICs and some 7805V regulators.
                                  • R_J
                                    • 9515
                                    Q502 only has 5pins so I guess you meant pins 4 & 5 or did you mean Q501 pin 14 & 15?
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Q501, you are right.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        The parts have arrived, and of course I have purchased the wrong package(to big).
                                        I have soldered it in somehow, and now I have +/-5V now. Speaker still shows +2V, without final IC.
                                        I will solder in the final IC, and see what happens.
                                        • R_J
                                          • 9515
                                          You could check the voltages on Q501 and see what they are but looking at the ic' pdf the voltages on the output side seem to be referenced to com (pin 10)
                                          I'm not sure why there is +2 volts on VS, it could be coming from Q501 or it might be normal, there is a difference in resistance from VS to positive supply (42.1k) and VS and negative suppply (44k) and that might explain the +2 volts
                                          • redbaron1007
                                            Onkyo SKW-791 subwoofer
                                            by redbaron1007
                                            I've got an Onkyo SKW-791 subwoofer in right now that isn't powering on. Or at least the indicator light isn't coming on and the system it goes to can't detect/connect to it. It's drawing 0.7W from the wall when plugged in according to my kill a watt. It has a hissing noise constantly whenever it's plugged in, but the hiss isn't coming from the speakers this is when the board is pulled out of the housing and sitting on my bench. The hissing nose is still present even when the speaker is plugged in, but nothing comes out of the speaker.
                                            The first thing I did was replace the audio...
                                            12-20-2022, 08:08 PM
                                          • rustinjust
                                            Please help, subwoofer connected to tv, read description below
                                            by rustinjust
                                            I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                                            Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                            Is there a way of...
                                            10-28-2023, 07:09 AM
                                          • rustinjust
                                            Please help, where can I get a remote for my subwoofer?
                                            by rustinjust
                                            I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                            Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                            Is there...
                                            10-28-2023, 03:43 AM
                                          • Fripacks
                                            Onkyo model SKW780 Subwoofer
                                            by Fripacks
                                            Hi guys, I have a subwoofer Onkyo model SKW780, one zener diode is short, I don't know the value, the location is D920 in the Power Supply Board, someone know the value of this zener?
                                            12-21-2021, 03:19 PM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
