Balance slightly off on Aiwa MX-70
  • Xenon-Codex
    • 185
    • Finland
    Re: Balance slightly off on Aiwa MX-70
    There's 0,28V after two hours of not plugged in, 0,4V when I connect it to power. The volgate drops to 0,5 when muting goes off. D31 has the same voltage on both sides even with the wall socket off. Maybe it's the D31 which is broken?
    The protection circuit was faulty, and the uPC1237 had to be replaced, maybe it broke something else with it.
    • R_J
      • 9535
      If the voltage only drops to 0.5 volts going to Q21/22 base, that could be just enough to make one of them start to slightly conduct, lowering the audio signal just a little bit. Replace D31 and see if that fixes the problem
      • Xenon-Codex
        • 185
        • Finland
        D31 was kaputt. I didn't have the correct one, so tried with 12V zener (other was 6.2V). Now it works, except there's some background buzzing, and volume doesn't go all the way to zero.
        • R_J
          • 9535
          If the volume does'nt go all the way down and there is buzzing, I would suspect there is a bad ground somewhere. when the volume is turned all the way down, the signal should be taken to ground, but if at the volume control there is no ground that could explain the fault.
          I think you have damaged the traces around q21 & q22, the ground circuit runs directly through those transistor collector pads, if any one of them is damaged, the ground going to the volume control will be lost.
          • Xenon-Codex
            • 185
            • Finland
            Will it damage anything if I change the 6.2V zener to it? I took this 12V one from scrap box. There was no buzzing with the original, or when the muting was disabled.
            • R_J
              • 9535
              If by IT, you mean 12 volt zener, it won't damage anything, the schematic uses a HZ9A2 8.2
              The buzzing and volume issue is NOT the cause of D31, You likely damaged the traces around the mute transistors so now there is no ground path for the volume control
              • Xenon-Codex
                • 185
                • Finland
                #27
                It started to work quite normally when put inside its case, volume goes to zero and that buzz is gone. I measured the gound and it's good. Some crackling was heard when using the volume pot, but that went also away after a while. Maybe the temporary transistors Q21 and Q22 are causing abnormal things.
                Where did you get that super clear service manual? Mine is b&w and the numbers are hard to read...
                • R_J
                  • 9535
                  You can download the manual from here:
                  • Xenon-Codex
                    • 185
                    • Finland
                    #29
                    I finally received the correct transistors. The amp had some kind of hum/buzz (not related to volume level), but that has corrected itself(?) when it was "off the wall" whole week... Probably that was caused by earth loop via a cable from other stereo & computer.
                    Thanks to all for the advice.
                    • Xenon-Codex
                      • 185
                      • Finland
                      #30
                      If I turn the plug other way, the hum comes back. With no hum, there's 160V AC on the cover, with the hum only 70V. I now have another identical amp, it has also quite high voltage on the cover, but no hum no matter which way the plug is on the socket.
                      • R_J
                        • 9535
                        I am 99% sure you broke the circuit traces when replacing the transistors, and the volume control circuit and other parts of the circuit is loosing its ground connection.
                        The power supply uses a transformer so the amp should be isolated, check the wires on the primary side to make sure none are touching ground.
                        • Xenon-Codex
                          • 185
                          • Finland
                          #32
                          The phono-amp section had two white jump wires, which looked strange. That small board has a crack which I haven't noticed, it's not clearly visible except from a correct angle and powerful light. The crack disconnected both lines and the wires were to fix it. Touching the jump wires caused much more hum.
                          Is this a common practice to fix a fault occurred during the assembly, the wires looked like been there for 30 years? No signs of resoldering.
                          • R_J
                            • 9535
                            Can you hold it up to the monitor so I can see it? If the board has cracked traces I guess someone repaired them before.
                            I already pointed out where the hum is likely coming from. There is only one thin trace for the ground circuit on this board.
                            • sretchko
                              Sony Receiver STR-4800SD L/R Balance
                              by sretchko
                              Hey fellow solder fume lovers, I have a Vintage Sony Receiver STR-4800 SD that has me stumped.
                              The Balance Pot has to be set at about 30 degrees (11 o'clock) to the left for the output to be balanced (see photo). I'm using an oscope, sig gen 1kHz sine, 8 ohm dummy load).
                              When output is balanced (11 o'clock left) both channels clip at about 19 vac / 45 watts RMS, Amp is rated at 35 watts so I know the amp modules are good. Square wave also looks good when turning bass & treble pots and is in phase.
                              I pulled the balance pot, (Dual 10K MN Taper) cleaned with...
                              Badcaps Electronics Repair Forum & Schematic Search
                              04-17-2024, 06:02 AM
                            • Francesc V.
                              Onkyo A8200 - Not the right voltages in some transistors
                              by Francesc V.
                              Hi:
                              I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
                              With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
                              Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
                              Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
                              I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
                              04-19-2025, 07:17 AM
                            • redbaron1007
                              Sundown SFB-8000D What are these transistors?
                              by redbaron1007
                              I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
                              My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
                              11-12-2023, 07:30 PM
                            • Bob Wong
                              MSI Crosshair 15 A11UEK. Need help with Transistors!!!
                              by Bob Wong
                              Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
                              In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
                              P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
                              03-15-2025, 02:02 PM
                            • hyva_ana
                              Marantz PM-66SE Burns Transistors
                              by hyva_ana
                              While ago I replaced those big filter caps to that amplifier. After that started to happen. I connected the amplifier normally to the mains and almost immediately several transistors burned out. I really didn't do anything else (at least on purpose) than replaced those big caps C801 and C802.
                              After that I replaced those burned transistors (I can't remember exactly what they were) and measured all the others, and now everything should be ok. But, when I power up that amplifier part with two bench power supplies connected in series there is obviously still something...
                              02-11-2023, 06:34 AM
