Presonus Audiobox 1818VSL firmware dump
  • Khron
    • Sep 2006
    • 1350
    • Finland
    This is probably very much a "shot in the dark", but i have to try. Presonus support have been... well, let's just say, "less than helpful"
    The bulk of the story:
    Khron's Cave: #37 Presonus Audiobox 1818VSL teardown and troubleshooting (part 1)
    I did some more poking around tonight, and there's absolutely squat re: clocks on the ADC/DAC chips (ie. MCLK, LRCK and BCLK / SCLK). Reasonably sure that's why the Vcom and the Filt+ voltages are almost-zero-but-not-quite on those CS4272's, but the /RST are high, so they're not being held in reset as such.
    I reached out to a user on another forum, after discovering by total chance that he had an 1818VSL in use, but alas, doesn't have an SPI flash reader/programmer, nor can he gain access to one.
    So i'd be reeeeeeeeeeeally grateful if, by some miracle, someone 'round here happened to have an 1818VSL and had the means and the kindness to desolder the firmware chip, read it out, and send me the contents (one way or another)
    I also identified one of the two little chips right next to the CPU - the MSOP-10 packaged one is a CS2300-CP PLL / clock multiplier. https://cdn.badcaps-static.com/pdfs/...5b095302e6.pdf
    I'm quite sure the SOT23-5 chip right next to the 13MHz quartz is a humble logic gate, which creates an oscillator using the quartz, feeding into the CS2300. That one's software-controlled though, and there's sod-all coming out of it, hence no clocks for the ADC/DAC chips. Haven't managed to figure out what the smaller 8-pin one is, though (marked "CNAA" or "CHAA", and "NZ17" on the second row), possibly some sort of buffer.
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Presonus Audiobox 1818VSL firmware dump
    Well, i ended up finding a working unit for a reasonable price locally (180eu) and, sure enough, "cloning" the firmware to my first unit brought it back to life instantly!
    Or, well, as soon as a couple of my brainfarts cleared the air...
    http://khronscave.blogspot.com/2019/...revisited.html
    • diif
      • Feb 2014
      • 6978
      • England
      Nice work, I always enjoy reading about your new repairs.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        No thanks to Presonus' support department, though
        As the old saying goes - if you want something done right, you gotta do it yourself
        (Well, assuming you don't just wanna throw money at problems...)
        I traded the revived unit with a friend, for a 1st gen Focusrite Scarlett 18i20. He's been testing the 1818VSL for the past couple of days, and all is well
        Now... Anyone in the market for an(other) 1818VSL?
        I can sweeten the deal by throwing in an M-Audio Profire 2626 to up the solution to 16in / 16out (analog)
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • Tamo Neko
          Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
          by Tamo Neko
          I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
          What Happened:
          I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
          • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
          • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
          What I Need:
          • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
          02-12-2025, 11:29 PM
        • Mephysis
          DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
          by Mephysis
          Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
          I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
          03-27-2025, 02:34 AM
        • gun4as
          Need firmware dump for LG 23MP48HQ-P
          by gun4as
          Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
          08-25-2025, 04:28 AM
        • eurocomputerland
          Canon iSensys MF264DW II, firmware memory dump
          by eurocomputerland
          Hi, i have canon mf264 printer which is stuck in download firmware mode and I'm after a firmware memory dump for this model, so I can try to rewrite. Thanks for your kind help!
          07-22-2025, 04:48 AM
