Panasonic DMR-BCT 755EG
  • thoma
    • Sep 2012
    • 268
    Hello to all Members of this nice forum!
    I have a blue ray recorder panasonic DMR-BCT 755 EG
    Since yesterday i have no more picture over HDMI!
    Do you can help me? Does someone have a technical schematic of this equipment?
    REGARDS THOMA!
  • Ady2017
    Panasonic DMR-EZ48V DVD/VHS combo - DVD recorder part not working
    by Ady2017
    I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that...
    06-06-2025, 08:05 AM
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
    DVR recorder Switching power supply Failure
    When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
    Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
    This...
    05-27-2023, 03:03 AM
  • BOSCHNJAK
    by BOSCHNJAK
    ABOUT ME INTRODUCTION FILE
    2
    024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
    2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
    2022 BEV, PROJECT ?
    2021 BEV, PROJECT ?
    2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
    2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIÄŒNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
    12-28-2023, 02:09 PM
  • AquaMan Ua
    Problem with PANASONIC CF53 laptop after changing BIOS settings
    by AquaMan Ua
    Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
    05-17-2025, 09:40 AM
