Sony STR-V25 Receiver - Tuner String Came Off
  • travisbklein
    • Dec 2018
    • 7
    Hey guys what's up, looking for maybe some guidance on how I can get my tuner string back on and taut like it is supposed to be.
    I took a few photos that I will show at the bottom and I tried my best to illustrate the problem.
    1st problem is that the string seems to slip on the metal tuner rod instead of catching and staying tight. I saw a video where a guy had the same problem and he just use a nail file to scrape up the small rod to allow it have some friction with the string and hence allowing it grab it and not slip.
    2nd problem is I'm not sure how the string goes around the black wheel that is attached to the capacitor in the back. There are 2 ends that both get attached to springs (which both work well), I'm just not sure how it should go around on both ends.
    3rd problem is related to the problem above. The string seems to be twisted around itself near the black wheel that is attached to the cap. The 2 ends never came undone where the springs are so I am just unsure how this string system can work.
    In the images I will put numbers 1,2,3 to show where in the image each problem I am referring to. I will use "W" to show where the 2 wheels are that guide the string around.
    Thank you so much for the help, really appreciate it.
    Also I found the service manual:
  • R_J
    • 9515
    Re: Sony STR-V25 Receiver - Tuner String Came Off
    The diagram for the string is in the manual, page #5, I don't think I could explain it any better, IE the "metal tuning rod" requires 3 turns of the string.
    • travisbklein
      • Dec 2018
      • 7
      Dude, what is wrong with me. I went through that manual, it was really late at night after I was hands on with the unit for a few hours , I think I was just really tired.
      THANK YOU SO MUCH, I'm going to get on this! thank you, really, thank you
      • R_J
        • 9515
        Just take your time with it, they can be a pain sometimes, let us know how it went.
        • travisbklein
          • Dec 2018
          • 7
          oh my god I did it, thanks to you pointing that service manual out!
          I didn't have good nail file to really get in there and grind up the metal turning rod so that more friction would be used and really grab the string.
          So I used what any normal person would use, an electric carving knife
          held it to the tuning rod and rotated it just a few times and got some good nicks and created some good friction with the rod and the string.
          Thank you R_J thank you!!!!
          Travis
          • R_J
            • 9515
            There should be no need to gouge up the flywheel shaft, 3 turns on it should be good enough, if it is still loose the string needs to be a bit tighter. You can put a knot in the string near the tuning drum to shorten it slightly
            • travisbklein
              • Dec 2018
              • 7
              I agree usually this is not the solution, but after years a combination of the string getting ever so slightly longer and the flywheel getting more slick because of the molecules lost each time there is friction between the string and the rod, then it does begin to slip. (similar to how rocks get really smooth over time, from running water)
              After putting it on correctly once I tried it and of course it was slipping so I used the trick I learned the last few days from experienced youtubers who repair electronics and decided that would help, and it did.
              Here is a video I watched where the guy did the exact same thing, however he had a handy grinder file perfect for the job, I had to improvise :p
              https://www.youtube.com/watch?v=G266dzQwNrc
              Ty again R_L you are the man
              • petehall347
                • Jan 2015
                • 4423
                • United Kingdom
                if all in proper tension rosin works to excess .. rub on wipe off .. cheap as rosin and lasts forever .
                • travisbklein
                  • Dec 2018
                  • 7
                  ahhhh I love this, if this ever happens again I will use that! Just like a baseball player holding a bat! ty ty
                  • sretchko
                    Sony Receiver STR-4800SD L/R Balance
                    by sretchko
                    Hey fellow solder fume lovers, I have a Vintage Sony Receiver STR-4800 SD that has me stumped.
                    The Balance Pot has to be set at about 30 degrees (11 o'clock) to the left for the output to be balanced (see photo). I'm using an oscope, sig gen 1kHz sine, 8 ohm dummy load).
                    When output is balanced (11 o'clock left) both channels clip at about 19 vac / 45 watts RMS, Amp is rated at 35 watts so I know the amp modules are good. Square wave also looks good when turning bass & treble pots and is in phase.
                    I pulled the balance pot, (Dual 10K MN Taper) cleaned with...
                    Badcaps Electronics Repair Forum & Schematic Search
                    04-17-2024, 06:02 AM
                  • Carlos#2003%
                    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                    by Carlos#2003%
                    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                    02-15-2024, 07:52 PM
                  • erickeri1234
                    Sony str-dn850 home receiver no left channel.
                    by erickeri1234
                    Ok start off by saying I have some tv repair but not much on the receiver end.
                    Picked up a Sony str-dn850 home receiver when I first plugged it in powered it up it came on and the system check relay clicked and about 3 seconds later it went into protection mode.
                    I powered it off and on. Comes on no problem.
                    Hooked up speakers and it started to pop and crackle but the volume was all the way down.. and I was only getting that sound out of the left channel. Right channel had no sound.. but every time I turn the volume up it has a smell crackling sound on ever volume number......
                    10-04-2021, 07:45 PM
                  • dkneyle
                    Sony KDL-46HX850 Can't upgrade/update firmware
                    by dkneyle
                    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                    09-25-2024, 10:44 PM
                  • jason123
                    Sony STR-DN1050 - No video, no BT, No WIFI, and FM is not changing stations
                    by jason123
                    Hello folks,
                    New to Audio equipment - I got this receiver, I connected speakers and I tried to connect to Bluetooth. My phone would not see the receiver (Receiver flashes the BT as if it's trying to pair). Then I put it on FM radio, I get white noise on the speakers. I click the +/- Tuner button, and it moves from saved station 1 through 28, but the frequency is 87.x MHz not changing. At this point, thinking I may need to do a FW upgrade, I connected an HDMI cable to the TV and TV reports "No Signal" - TV "Kind of" sees the receiver (When connected to greyed out port,...
                    05-27-2025, 07:26 AM
