Electron Kinetics Eagle 2C amplifier problem
    Re: Electron Kinetics Eagle 2C amplifier problem
    The thread is long so I do not remember if you already test that Transistor already or not and compare it to the working channel. You have one working channel so you can always do the comparison test against working channel.
    • Gammaray
      • May 2010
      • 120
      • U.S.A.
      #62
      Sorry for the lengthy thread! Here are the voltages from the transistors I measured from each side:
      (CHANNEL A) Top Transistors
      #1 Sanken (2SC2774) B=.631 DCV/ C=48.0 DCV/ E=.018 DCV
      #2 Sanken (C2168) B=1.22 DCV/ C=47.7 DCV/ E=.627 DCV
      #3 Sanken (2SC2774) B=.626 DCV/ C=48.0 DCV/ E=.017 DCV
      #4 Sanken (A958) B=46.4 DCV/ C=1.22 DCV/ E=47.3 DCV
      (CHANNEL A) Bottom Transistors
      #1(2SA1170) B= .603 DCV/ C= -46.55 DCV/ E= -.012 DCV
      #2(A958) B= -1.22 DCV/ C= -46.33 DCV/ E= -.600 DCV
      #3(2SA1170) B= -.593 DCV/ C= -47.3 DCV/ E= -.002 DCV
      #4(2SC2168) B= -44.7 DCV/ C= -1.20 DCV/ E= -44.8 DCV
      (CHANNEL B) Top Transistors
      #1 Sanken (A958) B= 47.8 DCV/ C= -40.0 DCV/ E=46.1 DCV
      #2 Sanken (2SC2774) B= -21.0 DCV/ C= 46.8 DCV/ E= -19.6 DCV
      #3 Sanken (C2168) B= -18.8 DCV/ C=46.8 DCV/ E= -18.9 DCV
      #4 Sanken (2SC2774)B= -18.75 DCV/ C=46.9 DCV/ E= -19.4 DCV
      (CHANNEL B) Bottom Transistors
      #5 (2SC2168) B= -44.8 DCV/ C= -2.27 DCV/ E= -44.8 DCV
      #6 (2SA1170) B= -1.15 DCV/ C= -45.9 DCV/ E= -.63 DCV
      #7 (A958) B= -1.9 DCV/ C= -46.7 DCV/ E= -1.22 DCV
      #8 (2SA1170) B= -1.42 DCV/ C= -46.1 DCV/ E= -.75 DCV
        If you suspect that E-B junction is shorted then you should be able to use Ohm meter to check the resistance between E and B pin if the suspect transistor.
        • Gammaray
          • May 2010
          • 120
          • U.S.A.
          #64
          OK, I will do that and post the resistance. Should I discharge the caps before I take a measurement of the transistor's resistance?
          Thanks!
            Thanks!
            Yes! discharge the caps and then take the Voltage reading on the discharged caps to make sure it is discharged.
            • Gammaray
              • May 2010
              • 120
              • U.S.A.
              #66
              I measured that transistor (2SC2168) from B to E and got 1.292 M ohms..Does this seem bad?
              • R_J
                • Jun 2012
                • 9515
                Not really, but
                Read post #61 again. and check other parts the same way, you may be suprised at what you will find that way.
                  Originally posted by R_J
                  Not really, but
                  Also in post #4.
                  • Gammaray
                    • May 2010
                    • 120
                    • U.S.A.
                    #69
                    Would it be ok to take the pcb off from the amp chassis and do some resistance comparisons? I mean is this a good way to find faulty components without worrying about if I may accidently touch some live/hot and zap me or something else?
                    • Gammaray
                      • May 2010
                      • 120
                      • U.S.A.
                      #70
                      bump
                        You are taking the resistance reading so the unit should not be powered in the first place so I do not see how you will be zapping anything once the filter caps are discharged and the unit is not plugged in.
                        • redwire
                          • Dec 2010
                          • 3900
                          If you pull the board out, a schematic can get drawn up given some good pictures of the back side. The front pics have some areas I can't see.
                          Sometimes it's easier to sketch it one and then troubleshoot.
                          • Gammaray
                            • May 2010
                            • 120
                            • U.S.A.
                            #73
                            OK, I see. So would I have to de-solder these components to check for resistance, or can I leave them mounted to the pcb and check resistance?
                            • Gammaray
                              • May 2010
                              • 120
                              • U.S.A.
                              #74
                              Thanks, but not sure how I could draw up these traces for the schematics. Seems to be a little out of my noob hands..LOL
                              • electricboyo
                                • Mar 2013
                                • 26
                                What we need are very sharp clear photos of both side of the PC board. If you remove the mounting screws from all the power transistors and the input and output jacks then you should be able to lift the PC board from the heat sinks so that both front and rear of the PC board can be seen.
                                The circuit design of this amplifier is somewhat unusual. Some of us who have worked on audio amplifiers for years might be able to tease out its schematic from looking at a really good set of photos of this PC board.
                                Because you have one channel that works it should be feasible to fix the other channel. The problem could be that just 1 component is bad.
                                • electricboyo
                                  • Mar 2013
                                  • 26
                                  I suggest checking the value of all resistors on the PC board. Do this with power off and with an ohmmeter. Resistors can fail in the "open circuit" state without looking burnt or damaged.
                                  Because there are unusual DC voltages on the faulty channel I recommend that you should only apply AC mains power to the amplifier through a "dim bulb" tester. This is a conventional incandescent 120V light bulb either 60W or 100W which is wired in series with the AC power source. This can be made with a light bulb socket and an old extension cord. Cut the hot wire of the extension cord and connect the cut ends to opposite sides of the light bulb socket. Typically the light bulb will be bright when the amplifier is first powered up and then it should get dim after the large power supply capacitors charge up. there are other postings on the forum for ''dim bulb tester" that will provide more detail about constructing and using it.
                                  -EB
                                  • electricboyo
                                    • Mar 2013
                                    • 26
                                    Based on your previous voltage measurements I suggest checking all 4 of the large power resistors connected between the emitters of the channel B output transistors. One or more of these resistors is open. Or else there is a bad solder connection or broken foil on the PC board.
                                    Under normal conditions the emitters of all 4 large power transistors should be within +/- 50 mV of each other, and this should also be very similar to the DC voltage appearing at the red output terminal post on the rear of the panel for this channel.
                                    Ideally the DC voltage on the red output terminal post should be less than +/- 10 mV.
                                    EB
                                    • electricboyo
                                      • Mar 2013
                                      • 26
                                      After looking at your photos of the PC board again up-close I am thinking perhaps some of the power transistors for the bad channel aren't actually soldered to the PC board. Or rather, their solder connections broke off. As far as I can tell there isn't much of anything mechanically holding the PC board except for the soldered pins of the large power transistors and the speaker output binding posts. I don't see any bolts or screws holding the PC board.
                                      So, seriously, as suggested by an earlier post, it is really important to unbolt all of the power transistors from the heat sink and the pull out the PC board so you can inspect the back side of it. You may have to unbolt or unsolder the 4 speaker ouput binding posts in order to remove the PC board.
                                      EB
                                      • MrCommunistGen
                                        Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                        by MrCommunistGen
                                        My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                        I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                        07-12-2021, 05:11 PM
                                      • jinu_j
                                        How to test Subwoofer Amplifier with only a multimeter
                                        by jinu_j
                                        Hi Folks
                                        Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                        Problem
                                        I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                        Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                        Any advice would be appreciated...
                                        08-29-2024, 02:05 AM
                                      • UserXP
                                        Mackie CR4 amplifier no sound
                                        by UserXP
                                        Hi, people.
                                        I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                                        Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                                        10-17-2020, 05:06 PM
                                      • waspie
                                        Aiwa GX-770 Amplifier Protection Circuit
                                        by waspie
                                        I am by no means an expert on this type of troubleshooting but I can follow direction real well.
                                        I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
                                        It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
                                        11-29-2022, 09:58 AM
                                      • redbaron1007
                                        Sundown SFB-8000D What are these transistors?
                                        by redbaron1007
                                        I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
                                        My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
                                        11-12-2023, 07:30 PM
