Pioneer QX-949 in protect mode / no audio
  • CapLeaker
    Leaking Member
    • 7980
    Re: Pioneer QX-949 in protect mode / no audio
    Originally posted by kc8adu
    while you are in it replace at least all the light blue sanyo caps.
    working on a qx-747 now that had distortion and random relay tripping.
    none of the blue sanyo caps passed my quick test.
    1 was nearly shorted and shoving dc into one channel of the amp.
    these same caps are trouble in the kenwood ts-120-140 hf radios too.
    This PA doesn't have any blue caps. Mine are gray. I think there are 2 versions of PA's and I think I have the later version one.
    • CapLeaker
      Leaking Member
      • 7980
      gray ELNA caps.
      • CapLeaker
        Leaking Member
        • 7980
        I've got my digikey shipment yesterday and ordered a bunch of different transistors. Turns out to be a good thing I did that.
        The transistor to replace: 2SA726
        I've ordered KSA1015GTRA (higher gain ones) and KSA992FTA. Turns out, that the KSA1015GTRA don't have the gain that the 2SA726's had. However the KSA992FTA's are bang on. I am going to try a matched pair of KSA922FTA first.
        • CapLeaker
          Leaking Member
          • 7980
          Good news. The KSA992FTA did the trick and the amp is working A1! A little side note: Those KSA992FTA have to be installed backwards. The pin out is the other way around compared to the 2SA726.
          • petehall347
            • Jan 2015
            • 4423
            • United Kingdom
            easier than having them crossed legged
            • CapLeaker
              Leaking Member
              • 7980
              that is true...
              • CapLeaker
                Leaking Member
                • 7980
                Did an alignment on the FM tuner on that thing aaand? I broke the friggin slug in the discriminator (that large metal can). Here is an easy fix for that. Take a screwdriver with a magnet attached and gently break up the old slug and fish the debris out from the can, turn the unit upside down and blow the hole out with a can of air.
                This is important: Note that the IF of the tuner is 10.7Mhz. So you need a slug from a different receiver or transceiver with an IF of 10.7Mhz. In my case I used the slug out of a vintage junked Motorola Mitrek VHF transceiver. There are 2 slugs in that transceiver that are a perfect replacements for the tuner. No shimming, cutting etc required.
                • electricboyo
                  • Mar 2013
                  • 26
                  There are some batches of the small TO-92 case transistors in 1970's era audio gear that develop intermittent and sometimes persistent failures after 40 years. Intermittent crackling, popping, and hissing noise is frequently a symptom.
                  If you identify one such small transistor that failed then it would be wise to search every PC board for other transistors of the same part number and physical appearance.
                  With electrolytics in 40+ year old audio gear it is a good idea to measure both capacitance and ESR for all of them. Small capacitors may fail more often than big ones because the tiny caps contain only 1 or 2 drops of electrolyte. When it dries up the capacitor become an open circuit.
                  EB
                  • petehall347
                    • Jan 2015
                    • 4423
                    • United Kingdom
                    #29
                    capacitors are cheap enough and easier to replace with new even if old ones test good . flaky transistors can be found with freeze spray and heat .. some transistors on the hit list depend on the case style whether it might be likely to fail or not ..
                    • samson7point1@yahoo.com
                      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                      by samson7point1@yahoo.com
                      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                      The player processes the audio signal using two different reference frequencies. The "R"...
                      04-30-2024, 11:22 AM
                    • RatherLoopy
                      Pioneer VSX-44 receiver HDMI dropouts
                      by RatherLoopy
                      I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                      I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                      And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                      05-26-2023, 03:54 PM
                    • myavocation
                      Pioneer SP-SB23W soundbar: no audio-out fix
                      by myavocation
                      This post is specific to the Pioneer SP-SB23W, also known as the "Andrew Jones Edition" soundbar. Andrew Jones being well known in the audiophile engineering industry for superb audio designs. My reason for stating this is if you are looking for an inexpensive 2.1 channel TV soundbar, this one rivals many 5.1 systems -- and without littering a room with speakers (sub-woofer is wireless, can be hidden anywhere). As a 9 year old device, they should be pretty cheap on the used market -- perhaps dirt cheap if no audio-out. Bought mine off of Craigslist cheap.
                      So here's the...
                      01-29-2022, 07:42 PM
                    • CdDvdFlash
                      Hitachi HTA-DD3W AV Receiver Error Code -Protect-
                      by CdDvdFlash
                      I have a Hitachi HTA-DD3W AV receiver and when I got it I tested it working fine with speakers but it needed a clean inside because it had signs of moisture in it but it was fully dry with bits of wood chips, I guess this was left in a shed so I fully disassembled it and cleaned it with isopropyl alcohol very carefully, some de-soldering was also needed but now its very clean, luckily there was no rust on any components and all the capacitors are fine with no bulging. When I turn it on I hear a relay switch on then a few seconds later another relay switches on or off and the display has a "-PROTECT-"...
                      07-10-2023, 06:05 AM
                    • pulper111
                      Pioneer VSX-1123 Receiver - weird voltage problem
                      by pulper111
                      Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
                      I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
                      09-02-2020, 11:12 AM
