Av123 MFW-15 power supply problem
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Av123 MFW-15 power supply problem
    Originally posted by Gr33d
    I'm sorry, I'm fairly new to this, do i have to hook up the power supply board back to the amp and power up to do the volt measurement?
    Originally posted by Khron
    No, that's just to make sure the power supply board and the transformer both work as intended.
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • xXDigitizerXx
      • Feb 2018
      • 9
      Well, installed the new fets, it turned on than 20 seconds of being on it started to have a high pitch hiss and popped the fuse, replaced the fuse and I'm back to instant popped fuses. Runs fine green light stays on, with fets removed..... Any ideas? :/
      EDIT: even with the power switch in off position it blows a fuse when power is applied and the new fets are blown...
      • xXDigitizerXx
        • Feb 2018
        • 9
        Bump
        • Silverado0618
          • Apr 2018
          • 3
          • Usa
          I just got one gave up me and having similar issues. Everything seems ok except for c1 and it is gone. I am looking for the value and type to replace. I'm new and going thru this forum I'm not sure if I missed it or if someone could help.
          • Silverado0618
            • Apr 2018
            • 3
            • Usa
            I just got one given to me and having similar issues. Everything seems ok except for c1 and it is gone. I am looking for the value and type to replace. I'm new and going thru this forum I'm not sure if I missed it or if someone could help.
            Anyone know what c1 disc cap value is?
            • atul123
              • Aug 2018
              Hi Guys, my MFW15 recently died on me. I also had c1 blown up, it apparently very strongly. It also destroyed two of the underlying connections. Does anyone know the circuit layout of the power supply and help my redo the connections?
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • madan1
                555 based power supply getting too hot
                by madan1
                Good day.
                I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                06-23-2025, 04:38 PM
