Onkyo TX-NR616 exploded, transistor cross reference help
  • illegible
    • Jun 2017
    • 5
    I have an Onkyo TX-NR616 that has expired loudly.
    It was bought new in December, 2012, and used lightly. In early 2017
    some of the audio stopped working. We found out about the DSP issue
    and that Onkyo would fix it, which they did - it came back with the
    DSP tagged "REPLACED".
    About a month later, some of the surround dropped out, with a brief
    message about an output short (there was none). I poked buttons
    randomly and was rewarded with a series of bangs and flashes from
    inside the unit, then silence and smoke.
    The SBL channel on the driver board and associated output
    transistors have gone to meet their maker. A 22uf cap on the driver
    board (C5445) blew with enough force to wrap metal shrapnel around a
    nearby power transistor, and the power transistor (Q6065) has a crater
    in it.
    Needless to say, Onkyo was no help, since it's out of warranty. It
    sounds like this exact failure isn't uncommon, so I can't really blame
    Onkyo for messing something up during the DSP fix.
    So, first question - does anyone know why this happens, and if I fix
    it, why won't the same thing happen again?
    I found a replacement driver board for $25 with free shipping, that's
    below my pain threshold for not having to deal with cross referencing
    parts and hoping I don't get counterfeit/out-of-spec parts.
    I haven't put the curve tracer on the other transistors yet, but I'm
    assuming that all the main board transistors on the SBL channel are
    blown. Digikey has the power transistors - 2SC4469 and 2SA1695, but
    the others - 2SC1740S and 2SC2229 are proving harder to find. I can
    buy them off ebay, or type "2SC1740 replacement" into a search engine
    and go with whatever's recommended. Does anyone have any better
    advice than that?
    And, do I have to do any calibration after replacing the power
    transistors and any other components that are out of spec?
    Thanks for any help!
  • mmartell
    • Oct 2013
    • 3189
    Re: Onkyo TX-NR616 exploded, transistor cross reference help
    You can probably go with whatever Digikey recommends as they came through in a few 636 and 646 threads here and no resulting problems.
    After the repair you should adjust the idle current at least for the repaired channel. DL the service manual for more info likely available at Elektrotanya.
    As to the "why" I dunno but not totally out of the norm for an amp to blow a channel occasionally and take a few good parts with it. It has been noted by myself and others that the finals don't seem snugged up to the heatsink on some models so there's a possible thermal issue there. Wouldn't hurt to have a look.
    • tibimakai
      • Jan 2012
      • 3680
      When I had issues like this, I have sent an Email to them and they recommended some other transistors for me.
      Sometimes, I have found the finals at Frys Electronics as NTE components.
      One set for example(for 636/646 NTE36/37), comes paired in one bag(!).
      I have repaired quite a few Onkyos already and on all of them, all the finals were just snug. This is my theory, that they are not tightened properly and the heat is not transferred properly.
      Most likely, that big white .22 Ohm ceramic resistor, is open as well. Not to easy to find one in 5W.
      Usually, I find the two final transistors blown, that .22 resistor and maybe one or two very low resistance resistors are blown.
      The biggest damage, is on that pre-amp board. Most likely, you have at the bottom some SMD transistors blown, the pre-final one(maybe both), capacitor, some 2.2, 33, 120 maybe 10 Ohm resistors.
      You should check everything, at that channel.
      When is all replaced and checked, at least on the models that I have worked on, 636 and newer, I had to use, a 100 Ohm resistor on each lead going to the DMM, when measuring idle current. You will have an initial measurement and then a burn in measurement after like 5-6 minutes. You should have a variable resistor, at each channel and you should adjust it accordingly to the SM.
      If the values are rising way to fast, you still have a problem.
      On the latest models, this adjustment is not required (yeahh).
      That $25 is probably is a good idea. But, how can you be sure, that board is all good?
      • dobrykamil
        • Jun 2013
        • 61
        I reckon that most of the problems like this, is caused by fricking pre-amp which runs very hot, even when idle.Next time, take a really close look at the solder joints of the faulty channel.
        In case like this, I always check that small transistor near the finals, it's Q6005 in SBL channel.
        • tibimakai
          • Jan 2012
          • 3680
          I don't have the schematics in front of me, but it is that transistor, between the final transistors?
          If yes, then for me they were always good. I have never had one blown.
          I agree, that everything is way to hot.
          I used to install a laptop cooler fan, with adjustable speed and power it, from the TV's USB port. This way, is always on.
          The latest receivers, don't have fans anymore and they run pretty cool.
          • magneh
            Behringer Eurolive B205D repair - help identifying transistor
            by magneh
            Hello
            Got this speaker from a friend , defective. Power led comes on and off , in a loop.
            Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
            After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
            I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
            Still, I need to replace this transistor....
            06-18-2025, 02:34 AM
          • FrancescoV
            Onkyo HT-R390 no sound output, video output ok
            by FrancescoV
            Good morning everyone,
            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
            The firmware reported is the following:
            M:1.00/11107BLP
            D:?.??/????????
            O:1.00/11107AL
            The DSP firmware given the question marks seems corrupt.
            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
            05-11-2025, 02:59 AM
          • elsomer
            help to identify transistor msi ms-15ck1
            by elsomer
            hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
            02-17-2025, 05:30 PM
          • Bivolalbert
            Help figuring out the resistance of this exploded resistor. gtx 1060 6gb inno3d compact
            by Bivolalbert
            Hello,I need help figuring out the resistance of this exploded resistor. I'm pretty sure it's the one labeled R37. I tried measuring it with a multimeter, but I got different values each time, probably because it's exploded. If you have a schematic, it would be really helpful!
            Its a gtx 1060 6gb inno3d compact, i you have schematic it would be very helpful....
            02-13-2025, 10:30 AM
          • rddube
            Help with blowing transistor NAD T752 receiver
            by rddube
            I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
            Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
            I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
            09-01-2022, 05:19 AM
