Sencor SCD 3554 MR - no backlight
  • perseus142
    • Jun 2017
    • 30
    • Czech republic
    Hello guys,
    I am experencing no backlight issue on detachable panel of my car stereo.
    FM, CD works fine, information are sent and shown on the display however due to no backlight it is hardly readable. There is orange backlight for buttons - works fine and white backlight for display - currently off - dont know why.
    It is not a menu settings - already checked.
    Inspected board and no problem seen.
    There are probably signs of glue ? Please see red arrows and advise. Anything to worry about ?
    Also I replaced both capacitors 2200U and 470U however no luck - issue persists. Origin capacitors measured with low ESR.
    I did measured voltage on the connector for detachable panel however I couldnt find service manual, neither schematic, so I cant compare. Do you you have an experience with the LCD panel ? What is your opinion about the values ?
    I also inspected the detachable panel itself, please see attached picture. Do you know how the backlight works here ? There is no backlight LED as used by other car stereos. There is no dedicated backlight pin on ISO connector.
    An idea/hint/direction will be very welcome. Thank you.
  • perseus142
    • Jun 2017
    • 30
    • Czech republic
    Re: Sencor SCD 3554 MR - no backlight
    Originally, it looked like
      • Jul 2011
      • 6039
      The first thing that comes to mind is
      Either one of two things
      One either the LEDs are shorted or the driver for the LEDs is not working
      Can you lift the display because I do not see the pins on the bottom of the display
      If not
      Do you have a Desoldiering Gun station that you can unsolder the display
      Because if you do not see a white plastic defuseser for the LEDs then that means that it is part of the display which would mean that if the LEDs or open or shorted then there will be nothing that you can do for it
      Or it is a VFD display which I do not know much about
      • perseus142
        • Jun 2017
        • 30
        • Czech republic
        Under the display there is following:
        - a thin white plastic foil/or tape with grey border. It is not connected to anywhere, it only sits under the display and it is partly glued on the clear panel underneath
        - under the white foil sits a plastic clear panel or plate, about 2-3mm thick, it seems on side soldered to two pins, marked on bottom side. I dont see any LEDs under this clear panel.
        I also checked all those SMD reistors - showing the value as per code, ZD and capacitor also tested good.
        Do you know what is this and how works such type of display ?
        Thank you
        Pictures:
        • R_J
          • Jun 2012
          • 9535
          That white plate can contain one or two led's on the end where the wires attach, the rest is just the light pipe. What voltage do you have on the two wires going to it?
          Could be similar to this http://www.globalsources.com/gsol/I/...htm#1139200430
          Three also is EL (electroluminescent) panel, but they require high voltage at high freq. and require a driver circuit which I don't think applies here
          • perseus142
            • Jun 2017
            • 30
            • Czech republic
            R_J you are right.
            I desolder those 2 pin in order to remove the white plate (light pipe/difuser) and found a SMD LED.
            I did measure 6,8V on the pins, so I need to find suitable LED.
            I will replace is and post some pictures after the weekend.
            Thank you for help.
              • Jul 2011
              • 6039
              Chance are you could put some new LEDs on the same board if you have a tweeter soldering iron and replace them but I have not seen orange LEDs listed before
              Or another option is to use some 3mm LEDs and carefully install them with some hot glue to keep them in place
              I have a display on one of my Desoldiering Gun soldering station that LEDs when bad and this is what I am going to do to repair it
              It might be a good idea to put a drop down resistor if the current is to high for your replacement LEDs
              If the voltage is 6.8 volts then this might be cob LEDs which means that there is more than one LEDs in it
              • Longbow
                • Jun 2011
                • 623
                The open circuit voltage across the faulty LED will not be the same as when that LED gets replaced. Order a few SMD parts of the proper size, and they will most likely work fine. There are already current limiting resistors in the LED circuit I will say 99% certain. This is a typical example of SMD led chips run near the limits, thus increasing heat and shortening the life of the part. Replace all the LED's in the string, not just the one that measures open.
                Is it plugged in?
                • Stephen
                  A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
                  by Stephen
                  Hello, got a weird MacBook Air here
                  board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
                  08-23-2023, 09:12 AM
                • zaurus81
                  Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                  by zaurus81
                  This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                  The board is equipped...
                  01-16-2025, 03:54 AM
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • DanPoka
                  by DanPoka
                  02-15-2025, 05:05 AM
                • Comp_Pro
                  No Backlight Macbook A1990 820-01041
                  by Comp_Pro
                  Hello all,
                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                  Tests performed:
                  There is no backlight even with a good screen.
                  Backlight IC is receiving the correct support voltages.
                  Fuse F8400 ok
                  Current sense resistor R8400 ok
                  Backlight IC is receiving 3.3V on enable pin.
                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                  Backlight IC receiving 5V from PP5V_G3S
                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                  05-06-2024, 10:23 PM
