Computer speakers - fixing hum
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    I've had these brand X speakers for >20 years - great sound, thought they were worth hanging onto
    But they've been developing a bad hum, which has been getting worse, until now it overpowers the sound
    Would replacing any or all of its six capacitors maybe fix the problem ?
    - 4700uf 25v - two of
    - 33uf 16v - two of
    - 1uf 63v - two of
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Computer speakers - fixing hum
    I would look at the Power Supply section and change-out the big e-caps.....Yes probably those 2 e-caps 4700uf 25V are the problem....
      • 31011
      change the lot.
        master hoarder
        • May 2008
        • 12170
        • Bulgaria
        Also check for bad solder joints on the input jacks.
        +1
        Though, you might as well change all of the other electrolytic caps then, as stj suggested. They won't be nearly as expensive as the two 4700 uF 25V units.
        Another thing worth mentioning is that, depending on the output voltage of the transformer, you may use a linear regulator to feed the amplifier. When you do that, this should eliminate pretty much all of the hum. Something like a 7812, 7815, or 317 (adjustable) should be fine, so long as you put a proper heatsink on it and don't exceed its specs. But this suggestion is perhaps more fitting if you like playing with amps an audio gear.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          curious if there's hum when no signal is presented?
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            +1
            +1 ..
            Better also change wires , they may be rusty after long use .
            • techman1025
              • Jun 2014
              • 497
              I would start with the connector ..the switch get stuck in side grounding out.
              Techman1025
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                Originally posted by jiroy
                +1 ..
                And that heatsink. Thats got to be more Oxide than Aluminium.... /s
                Follow the white rabbit.
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  Yes
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    I would scope the DC supply lines and see if your introducing hum via poor smoothing of the DC supply.
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Not an option for me, neither scope nor knowledge how to use
                      Waiting on caps from China - I know, I know - but RS Components pissed me off with their MOQ for 1uf 63v, and delivery charges rule out other top tier vendors
                        The 1 uf cap sounds like for coupling cap, may be you can use 2.2, or 4.7uf just for testing for now, but if they are coupling caps then I doubt that it will fix the hum problem. since the highest rate Voltage cap is 25V then it does not have to be rated at 63V.
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          I replaced all six caps with:
                          - 4700uf 25v - Nichicon PW
                          - 33uf 16v - Rubycon YK
                          - 1uf 63v - Panasonic EB
                          I reckon they're all genuine, otherwise pretty convincing fakes - and all tested OK on Banggood kit Transistor Tester
                          FWIW, both old 4700uf & one 33uf tested as "No, Unknown or Damaged"
                          All the old ones were marked 85 - but no way did I buy those speakers in 1985, more like 1995
                          And the outcome - no more hum and clear as a bell
                          My thanks to everyone who contributed
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            85 is the temperature rating in C.
                            Nice fix BTW.
                            • pfrcom
                              Oldbie
                              • Jun 2006
                              • 1230
                              Full disclosure:
                              I assumed 40/85 was a date, but maybe it's tolerance/temperature
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                No it's temperature rating.
                                From -40°C to +85°C
                                CD11 is the datecode
                                  master hoarder
                                  • May 2008
                                  • 12170
                                  • Bulgaria
                                  Wow, even the 4700 uF units tested open?!?!
                                  Those are some seriously crappy caps then.
                                  Nice job on the fix. Those Nichicon PW caps should not give you any trouble for at least the next 15 years (I'd say at least 25, though).
                                  • soeren
                                    A2442 - No sound over internal speakers and no video playback
                                    by soeren
                                    I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                                    All happened after the battery ran out of power overall several days when I was on vacation.
                                    I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                                    07-26-2024, 01:24 AM
                                  • ChaosLegionnaire
                                    by ChaosLegionnaire
                                    09-13-2022, 09:02 AM
                                  • dreamlayers
                                    Weird clipping on Logitech Z-10 speakers
                                    by dreamlayers
                                    I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                                    05-22-2025, 11:41 AM
                                  • StrongTester
                                    Audio Jack on hp-ec1001np detects phones and external speakers but no sound
                                    by StrongTester
                                    Hello friends, I am having trouble with a hp-ec1001np that detects the headphones or speakers when connected to the jack, but no sound comes out. The normal laptop speakers work fine. Anyone has an idea what it might be? Did a full reinstall of windows, still nothing.
                                    05-30-2023, 10:29 AM
                                  • Andreasbest
                                    Lenovo Thinkpad x230 no sound on speakers
                                    by Andreasbest
                                    Hello!
                                    A friend sent me a faulty x230 with no sound on speakers, headphones work great both channels.
                                    Speakers are good (7.8Ω each) but no sound comes on their pins, i tested this with oscilloscope.
                                    Any suggestions?
                                    Thank you in advance!...
                                    01-25-2022, 03:01 AM
